Rear brakes, any advice?
Discussion in '3rd Gen Tundras (2022+)' started by 389 24/7, Apr 14, 2025.
  1. Apr 14, 2025 at 1:14 PM
    389 24/7 [OP] 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    If you've done rear brakes on the gen 3, did you encounter any issues or hardware hang ups?
    Any pointers?
    Special tools?
    Is it just a straight forward as the front brakes? (Cuz I've done those easily)
    Im doing oem parts btw
    Thanks yall!
  2. Apr 14, 2025 at 6:30 PM
    Dmoeller1
    Dmoeller1 New Member
    2022 SR5 Crew Max Off Road Supersonic Red
    Just added a cat protection shield.
    Ended up doing rear pads only. Only had 30,000 miles and discovered rear pads significantly worn. I did not change rotors because I figured if I had a problem I could replace them then. Removed the e-brakes and used a torx to back them off. The procedure to put the e-brake in service mode does not work on the Tundra. Made sure to lubricate the slides. Like you said just straight forward.
    I ended up getting new pads from rock auto. I got the Power Stop Z36 pads.
    389 24/7[OP] and 22whatwedo like this.
  3. Apr 14, 2025 at 6:50 PM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    I wanna do mine also. Tired of waiting on the dealership with the reversing noise
  4. Apr 15, 2025 at 6:28 AM
    Oregona
    2022 TRD OR
    Nada
    I've had zero issues or noise with mine
    (Front & back)
    Replaced the front set @ 50k & 100k
    I do new rotors always, no turning for me
    Sometimes I hear a light squeek if I have not driven my tundra for a few days & moisture sets up on the rotors, dried out to light rust & the noise I hear is the rust being scrapped off
    Man o man I love this truck
    New oem rear brakes & shocks for $270 with shipping....thanks Fred Anderson toyota
    Tundrastruck91 and oddhours like this.
  5. Apr 15, 2025 at 8:57 AM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Tundrastruck91 likes this.
  6. Apr 30, 2025 at 12:23 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    How’re those pads holding up? The couple we’ve put on customers cars have squeaked in the morning but once they warm up they’re quiet.
  7. Apr 30, 2025 at 12:25 AM
    joseph_womack
    Joe
    Louisiana
  8. Apr 30, 2025 at 8:01 AM
    chrisgibbs707
    Socal
    2022 Tundra SR5 4x4
    They’re great! No squeaking from mine, good stopping power.
    joseph_womack[QUOTED] likes this.
