Damaged Hood Bulge
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cthenbest54, Apr 1, 2025.
  1. Apr 1, 2025 at 8:14 AM
    Cthenbest54
    Cthenbest54 [OP] New Member
    The plastic clips on my hood bulge have broken and now when I am driving down the road either in strong winds, I live in Kansas so it is every day it seems, or passing a semi and the air hits the front of my Tundra, it pops it out of place. I have tried to do the plastic JB Weld compound with new clips and it worked for a short amount of time. The compound broke off the bulge and I am back in the same spot. I have tried to look online for replacements but all I am getting are covers. I want to either replace the entirety of the hood bulge, black bulges would be preferred, trying to do a chrome delete but am open to just keeping the chrome, or come up with a new way to permanently fix the issue. I have looked and there is no way to get to the inside of the hood to replace the clips with bolts. Any help is appreciated!!
  2. Apr 1, 2025 at 8:35 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    dundunDUN and equin like this.
  3. Apr 1, 2025 at 8:46 AM
    RobertD
    Robert
    DFW, Texas
    Hard to tell if you have now damaged your bulge or if it's still in original shape minus the clips.
    Lots of us have had this issue, and replaced the black push clips with these. Resolved the issue and have held up great.
    Here are the clips I used that are holding much better than the stock ones that came in my bulge.
    $7 GOOACC for Toyota Trim Door Panel Clips Retainer for Tacoma Tundra Camry Corolla Avalon Sienna Replace OEM: 90467-10188,9mm Hole - 40pcs
    https://www.amazon.com/gp/aw/d/B0040CTTH4?ref=ppx_pop_mob_b_asin_title
  4. Apr 1, 2025 at 8:52 AM
    Cthenbest54
    Thanks man!! I have replaced the push clips with just the black OEM ones when I tried to fix the pieces on the bulge that you mount these to. I can replace the clips all day, the issue is that the "holders" on the bulge are broken.
    Tundra9880 and RobertD[QUOTED] like this.
  5. Apr 1, 2025 at 8:52 AM
    Cthenbest54
  6. Apr 1, 2025 at 8:53 AM
    RobertD
    Robert
    DFW, Texas
    Once you get a new bulge, probably wouldn't hurt to jump straight to the grean/teal clips I linked.
  7. Apr 1, 2025 at 8:55 AM
    Cthenbest54
    Yeah, that is what I will do! Do you know what is different about them? Are they just a better material and hold better?
    RobertD[QUOTED] likes this.
  8. Apr 1, 2025 at 8:55 AM
    centex
    centex New Member
    Those green clips and JB Weld fixed mine and I just drove through a 40mph head wind at 70mph and it stayed solid.
  9. Apr 1, 2025 at 8:57 AM
    RobertD
    Robert
    DFW, Texas
    :notsure:
    Not really sure. The look the same minus the color but they work when the oem black ones didn't. Probably a slightly different plastic and maybe a hair larger. It's still easy to install and remove the bulge if needed but I'm going a few years with these new push pins and have had zero issue. For the price, definitely recommend for piece of mind.
  10. Apr 1, 2025 at 8:59 AM
    Cthenbest54
    You live in Kansas too? lmao But it is nice hearing another person say they recommend the green clips! I am scared that one day the damn thing will just break off or snap in half. I love my Tundra but wowza isn't that a design flaw!
  11. Apr 1, 2025 at 9:01 AM
    Cthenbest54
    Regardless, I am gonna have to get a new bulge. I have JB welded once and broke again so the holders are shot and broken. Thank you for this information!
  12. Apr 1, 2025 at 1:00 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I use these, they are flatter.
    Amazon.com: Rexka 30pcs Rocker Molding Clip 75867-33030 for Toyota Lexus : Automotive
    Replaced mine last week because the winds were popping it out of place.
    Hasn't popped out since.
    I've tried them both.
    For me, the green ones seem to leave more of a gap between the hood and the bulge.
    The mother lode...
    I'm on my 2nd hood bulge on my 2014.
    One end of the speednut bracket broke on mine.
    I tried glues, epoxies, JB Weld, etc, but nothing would hold it.
    If you replace the hood bulge just finger tighten those bolts with a socket and give it maybe another 1/4 turn.
  13. Apr 1, 2025 at 1:19 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Not bulge related but since we're talking clips and retainers, does anybody have a link or part# for the plastic retaining nuts that holds the kick panel by the parking brake in place?
    The one that you can hand screw. TIA
  14. Apr 1, 2025 at 1:23 PM
    TacomaTRD4x402
    Southern California
    Added both to Cart
    :spending:
    Always good to have all these clips on hand.
  15. Apr 1, 2025 at 1:46 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I agree.
    I can't remember the situation, but the green one worked better than the black one for it..:confused::cool:
    If you ever remove the kick panel between the floor and the dash, these are a must.
    I ordered 25 and then gave half of them away on the forum..
    Amazon.com: Rexka 25pcs Cowl Trim Clip for Toyota Lexus 90467-09212 Avalon, Camry, Sequoia, Tacoma, Tundra : Automotive
    [​IMG][​IMG]
  16. Apr 1, 2025 at 1:58 PM
    TacomaTRD4x402
    Southern California
    Ah yes, those ones I already have and definitely are a must have but I'm referring to this lil guy here...
    This is my passenger side but it's my driver side that I lost when I installed my AMP running boards.
  17. Apr 1, 2025 at 2:21 PM
    TacomaTRD4x402
    Southern California
    RobertD likes this.
  18. Apr 1, 2025 at 2:26 PM
    The black OEM clips were the weak ones. Thr Toyota redesigned bulge clips are white.
  19. Apr 1, 2025 at 2:29 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  20. Apr 1, 2025 at 2:33 PM
    TacomaTRD4x402
    Southern California
    Trying to see if Amazon has a 20 pack available for 9.99 :D to add to my Tupperware that I never gave back full of clips :rofl:
    Corndog123 and 1lowlife[QUOTED] like this.
  21. Apr 1, 2025 at 2:39 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    OEM cost more to ship than they are worth..:eek2:
    I've had no problem with the black Amazon clips.
    Just have to replace them every couple of years, just like the OEM clips..:cool:
    Sparks show them to be black.
    75867-AA010 - 2002-2024 Toyota - Rocker Molding Clip | Sparks Parts
    Let's see, 20 from sparks - $166
    30 from Amazon - $10
    Corndog123 likes this.
  22. Apr 10, 2025 at 7:41 PM
    Tundra9880
    Tundra9880 New Member
    2019 Cement CrewMax SR5
    Leveled, wheels and tires, Line X on the grille surround and bulge, Line X in the bed, Retrax rolling Tonneau cover, Flowmaster Outlaw cat back exhaust.
    Been having the same issue. Top of the bulge popped up on a trip, was able to pop it back, but it popped up again. Bought these exact clips and see the have a bit more girth (haha) than the stock clips so I'm hoping they'll hold. Turns out the PLASTIC bracket the the middle of the 3 10mm bolts screw into is broken. So, I only have the two 10mm bolts on either end (plus the new clips) holding the bulge on. I'm guessing I'm going to have to replace the entire bulge if it keeps popping up.
  23. Apr 10, 2025 at 7:44 PM
    Tundra family
    Tundra family New Member
    Ask around on here, some folks have swapped and will gladly sell ya whatever you need. I scored most of my parts for a collision repair here, and got a lot of great advice in the process
  24. Apr 10, 2025 at 7:51 PM
    Tundra9880
    Same. Flimsy plastic these seem to be made of. I got hit with strong winds near Desert Center CA where all of the huge turbine fans are. Top of the bulge popped out and somehow broke the entire bracket the center of the 3 10mm bolts as well. Now it's just the clips and the 2 bolts on either end holding he bulge on. I bought the green clips from Amazon which seem to be a bit thicker (and were a bit harder to pop through when reinstalling the bulge) so I'm hoping I can postpone replacing the entire bulge. I did Line X bed liner on the bulge and grilled surround as well so that'll have to be done again on a new bulge. Ugh.
  25. Apr 16, 2025 at 9:11 PM
    Tundra9880
    Hey all just FYI. With the broken middle bracket and only the two end bolts holding, I used the green GOOACC clips from Amazon. Huge difference! I went through a car wash and the multi high pressured dryer blowers did not effect the hood bulge at all! It didn't even budge, let alone pop out again. Even with the broken middle bracket where the bolt goes, I don't think I'll have to replace the bulge. The clips are holding strong.
  26. Apr 16, 2025 at 9:14 PM
    Tundra9880
  27. Apr 17, 2025 at 4:58 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I am on my third bulge. I replaced OEM with OEM. This last time I went with cheap Amazon part. Fit is not perfect but no issues for at least 50k miles.
  28. Apr 17, 2025 at 5:23 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    coTony and 1lowlife[QUOTED] like this.
  29. Apr 18, 2025 at 4:37 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Just used those green clip to secure my hood bulge. Best tip so far, Thanks
  30. Aug 4, 2025 at 11:08 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Well, after 10 years and about 170K miles, my original hood bulge blew off. It had been shaking at highway speeds for a while, so I guess it was just a matter of time. Unfortunately, the plastic brackets are completely broken, so I ordered a less expensive aftermarket bulge from Amazon and the green plastic clips.
    RobertD likes this.
