Torque Specs
Discussion in '1st Gen Tundras (2000-2006)' started by TX-TRD1stGEN, Sep 20, 2019.
  1. Jan 1, 2025 at 5:26 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    A 2wd drive trd 2.5 gen lol, You’re lost Holmes.
    The Black Mamba likes this.
  2. Mar 31, 2025 at 1:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok this is actually the one I need! Thanks
    Edit: I guess they're the same as 04
  3. Mar 31, 2025 at 8:38 AM
    olegrey
    olegrey New Member
    2005 SR5 Grey DC 4x4 V8
    Anyone know the torque for inner tie rod to the steering gear? Thanks
  4. Mar 31, 2025 at 9:00 AM
    You already know that info, because you've been to this thread, and downloaded the Service Manual for your truck, that's linked around the 4th or 5th line of the 1st page, right? Download a copy, and you'll never need to ask for a torque spec again. All suspension/steering related stuff starts at section "SA-1" of the PDF.
  5. Mar 31, 2025 at 10:43 PM
    olegrey
    olegrey New Member
    Thanks for guiding me to the FSM. Page SS-81 has the tie rod locking nut at 55 ft/lbs, but no reference to the inner tie rod end torque. It has all other torques for the outer tie rod end. I’m looking for the inner tie rod torque, and am using the long tie rod tube extension tool for removal and replacement of the inner tie rod end.
    shifty` likes this.
  6. Mar 31, 2025 at 10:50 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @Sirfive do you remember what you torqued the inner tie rods to? I want to say like 60 ft lbs. I remember you did it by feel with the pipe wrench haha
  7. Apr 1, 2025 at 12:02 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That's because in the FSM it's referend to as "rack end".
    FrenchToasty, shifty` and BubbaW like this.
  8. Apr 1, 2025 at 1:39 PM
    olegrey
    olegrey New Member
    Bingo thanks! The ole rack end. Slippy slappy samsonite….I was sooo close.
