Blown Head?
Discussion in '1st Gen Tundras (2000-2006)' started by SunRunner34, Mar 21, 2025.
  1. Mar 21, 2025 at 11:46 AM
    SunRunner34
    SunRunner34 [OP] New Member
    2003 Toyota Tundra SR5 3.4 AC Manual Transmission
    Just purchased a 2003 tundra SR5 3.4 with around 230k miles on it. Told these motors were bullet proof but now i’m concerned it may have a blown head gasket or cracked head. Seems that it seeps oil between the engine block and cylinder head that was cleaned before selling it but it doesn’t loose coolant. Looses a bit of oil without having an obvious leak where I park it. Any advice?
  2. Mar 21, 2025 at 11:51 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Tighten your valve cover bolts first before you panic. 10mm and just snug'em up. Doesn't have to sasquatched, or really torqued too awfully correct unless you're putting a new gasket in
  3. Mar 21, 2025 at 12:05 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  4. Mar 21, 2025 at 12:16 PM
    Fedtime
    Fedtime New Member
    That first pic just looks like spillage or leakage from the oil fill.
    Tundra2 and G_unit3000 like this.
  5. Mar 21, 2025 at 12:51 PM
    And it looks like it has the typical valve cover leakage. Sadly, there's no info on valve cover gasket replacement for the two different V6 they put in our trucks, but Bubba linked the thread @SunRunner34 needs to read to get the Service Manual, understand what the hell they just bought, and understand if there are bigger problems at play than the valve covers. These trucks have much bigger known issue.
  6. Mar 21, 2025 at 1:01 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    ^^^THIS^^^
    These VC bolts will loosen over time. With the plenum on, you won't be able to get to all of them, but you'll get to most of them. Mine were so loose at one point that I could turn them by hand. The torque spec is very low. 108 in lbs which is like 9 ft lbs. Clean it all up with some brake clean after tightening and keep an eye on it.
    Most likely it's your VC gaskets leaking. Here's a link to the parts list when I did mine. You won't need everything on this list, but everything for the 5VZ is in this list.
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1984#post-3495496
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1913#post-3519185
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1914#post-3519783
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1919#post-3524815
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1929#post-3535095
    Edit: This video was helpful https://youtu.be/N5fAXAuGozI
    SunRunner34[OP] and G_unit3000 like this.
  7. Mar 21, 2025 at 2:12 PM
    SunRunner34
    Bolts were definitely pretty loose. I just got done snugging them down and cleaning around it. I’ll keep an eye on it for now. Thank you for all the help. 1st gen community is strong I can see.
  8. Mar 21, 2025 at 2:25 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    All these guys are on it!
    It's a great thing
  9. Mar 21, 2025 at 2:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've had the 3.4 for a long while, and the 4.7 for a short while.
  10. Mar 21, 2025 at 5:25 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Bulletproof is, of course, relative. No matter how good an engine is, there can be manufacturing or assembly flaws. And no engine, no matter how good, can stand up to years of abuse and neglect.
    But yes, before you go to worst case scenario, see what the valve cover nuts do.
    I had a Tacoma with the 3.4 and just sold it last year with 330,000 miles, still going strong. No major work. I have a friend with the same truck, less than 200,000 miles, plagued with problems. His was a ranch truck, did work meant for a full size, rarely got out on the highway - lots of stop & go.
    SunRunner34[OP] likes this.
  11. Mar 21, 2025 at 8:03 PM
    Mr Badwrench
    Mr Badwrench New Member
    I'm betting your engine is okay. You mentioned you were not losing coolant and didn't mention over heating. 20+ years on valve cover gaskets is pretty good. Don't go crazy if you tighten it or it will really leak.
    Valve cover gaskets aren't too involved to replace on the 3.4, especially with Tundra engine bay space.
