  1. Feb 19, 2025 at 5:44 PM
    I don’t know man. Decent work there I guess, but I don’t see no feather duster.
  2. Feb 19, 2025 at 5:45 PM
    I’m not done….. my hose does have a feather pattern……
    bmf4069 and KNABORES[QUOTED] like this.
  3. Feb 19, 2025 at 5:47 PM
    Acceptable as long as appropriate hand yoga was utilized.
  4. Feb 19, 2025 at 5:49 PM
    Not pictured was feather dusting the block drain bolt, with a wire brush, and then blasted a can of parts cleaner down its home to clean out the threads, some beginner hand yoga was needed to get the bolt back in without pre stretching
    BroHon, Sirfive and KNABORES[QUOTED] like this.
  5. Feb 19, 2025 at 6:38 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    My rear brakes needed to be adjusted, so I applied the parking brake a bunch of times today. Really cranked down on the pedal, and snapped the cable.
    Not very annoyed with the broken cable as it’s rusty and I assumed it would happen at some point. Actually have a new one at home.
    That said- the brakes still need to be adjusted. Does anyone know which direction to turn the adjuster, and how many clicks I should do? I don’t have a means of jacking up the rear axle here at school. Also would like to minimize the amount of time spent laying on the ground in the cold.
  6. Feb 19, 2025 at 6:42 PM
    Will be difficult to dial in without getting the tires off the ground. But when you pull the plug on the brake shield, you’re prying the star wheel from bottom to top, so grab the low side and crank it upwards. Flathead screwdriver works fine. Without lifting the wheels up, you won’t know if you’ve gotten to the point of barely dragging.
  7. Feb 19, 2025 at 6:42 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I only use my parking brake when jacking up the truck or parking on steep grades off-road. I drive off with it still set more often than I'd like to admit. I blame the trail sodas.
  8. Feb 19, 2025 at 6:43 PM
    I use my parking brake every time I park in every vehicle.
  9. Feb 19, 2025 at 6:46 PM
    FiatRunner
    Jack
    Hmm. Might have to wait then. Do you think I could do say, 3 clicks, drive it, and see how it feels? Maybe do 3 more if it feels like it needs it?
  10. Feb 19, 2025 at 6:57 PM
    Generally when mine are out of adjustment it takes about 5-8 clicks minimum. 3 at a time would be safe.
  11. Feb 19, 2025 at 8:36 PM
    Superdave1.0
    Superdave1.0 New Member
    Dave
    LX470, 2025 Civic Si
    I'll never understand it. Why do people that live in extremely cold climates complain about the snow. "I can't drive my sports car, I have to shovel my driveway, I have to scrape my windshield daily." Like why do they live there if they hate their lives 3-4 months out of the year? Why not move to a warmer climate? I'll never comprehend.
    Tlar25 likes this.
  12. Feb 19, 2025 at 8:48 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I mean, I hate the summer in Texas unless I'm on the water or the AC. So I guess it's kinda the same same but different
    Tlar25, Filthyphil, MT-Tundra and 2 others like this.
  13. Feb 19, 2025 at 9:41 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    This diagram should help, ignore the highlighted parts. They sell it on rockauto alone. dealer only sells it as a complete set. Hose connects to the the steering rack
    this thread has some info on the hoses and what ppl have done. I just fixed my leak from the reservoir
    https://www.tundras.com/threads/power-steering-leak.48461/
    Voss, Kimosabe[QUOTED] and shifty` like this.
  14. Feb 19, 2025 at 11:52 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Can confirm. Reputation is valid.
    If I’m not mistaken, (and i could be, it’s been a minute) I think both sides adjust in opposite directions, as the star adjuster is not side-specific and neither are reversed threads. No?
    As you should. People that don’t-
    are automatically disqualified from ever being housesitters or godparents, for obvious reasons.
  15. Feb 19, 2025 at 11:53 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  16. Feb 20, 2025 at 12:01 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Congrats and nice timing. Do share the PNs for the cool colors. I've got a bulb out behind the speedo so time to do this. Looks like a 1st gen taco.
  17. Feb 20, 2025 at 12:05 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Good, I didn't want to do that anyways. :laugh:
    oscardog86 likes this.
  18. Feb 20, 2025 at 12:07 AM
    ToyotaDude
    ToyotaDude Member
    With both wheels off ground I just pull the wheel and drum then can adjust easier from the inside and get senstive feel of the drum drag on the shoes. Also can clean out dust accummulation etc. Then rotate tires and done.
    BroHon likes this.
  19. Feb 20, 2025 at 12:08 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I believe it's mostly like four 168 bulbs and a 94. These in my 03 are from superbrightLEDs.com
  20. Feb 20, 2025 at 12:13 AM
    ToyotaDude
    ToyotaDude Member
  21. Feb 20, 2025 at 12:59 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  22. Feb 20, 2025 at 3:33 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    As much as that red would totally eff with my eyes, that dash lit up.looks pretty cool. Congrats on your mileage, nice catch :rofl:
    That grill and wheel choice really made your truck look better too, IMO. Gotta get those TRD caps in there!
  23. Feb 20, 2025 at 4:39 AM
    For the denso and koyo rad on RA. Part numbers are one off and pics look like the hoses are opposite.
    oscardog86[QUOTED] likes this.
  24. Feb 20, 2025 at 4:47 AM
    Bottom to top expands the adjuster bracket. Doesn’t matter if it’s facing left to right, or right to left. They adjust same direction on both sides.
    G_unit3000 and oscardog86 like this.
  25. Feb 20, 2025 at 5:02 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    b->t from the wheel side or the backing plate side?
  26. Feb 20, 2025 at 5:08 AM
    backing plate
  27. Feb 20, 2025 at 7:29 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Because this is where my family, my career, my friends and my life is. lol I love winter for the first 2 months of it but about this time is when it gets old and I'm ready for the warm up. Then I’ll complain when it’s been 90 degrees and no clouds for 3 months this summer.
  28. Feb 20, 2025 at 7:38 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Post from @Tundra2 with video https://www.tundras.com/threads/rear-drum-brake-adjustment.89649/#post-2254653
    BTW @Tundra2 I feel this belongs in our sticky thread Rear Brake Adjustment, theory and practice. | Toyota Tundra Forum
  29. Feb 20, 2025 at 7:46 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm always afraid to put the cap on the funnel when I'm bleeding it in fear that it'll build pressure. I guess if you leave it open just a bit, it'll keep it from spraying fluid out as it splashes around. Good idea, I'll have to try it next time.
    What's your determining factor for knowing when yours need to be adjusted?
  30. Feb 20, 2025 at 8:35 AM
    Yeah the lid was loosely setting on the funnel
