2001 2UZ-FE Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by txk131, Feb 15, 2025.
  1. Feb 15, 2025 at 1:29 PM
    txk131
    txk131 [OP] New Member
    2024 Tundra SR5 - 2001 Sequoia SR5
    I Recently bought an 01 Sequoia and it needs a new timing belt. This is my first time changing a timing belt. I have a Haynes repair manual and it states to align the cam shaft sprockets at TDC prior to removing the existing timing belt. I’ve noticed on some YouTube videos that they align the cam shaft sprockets on the “T” to prevent them from moving once existing belt is removed. Which method is correct? Can I just trust the Haynes book to guide me through it? Any other advice is appreciated.
  2. Feb 15, 2025 at 1:48 PM
    shifty` Oh, I have felt Cobain's sarcoma
    Welcome to the forum, couple of things
    We have sticky thread for 1st gen info, want to know the official process? The Toyota service manuals for 05+ and 04- are linked in the 3rd or 4th paragraph: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    We have a sticky on timing belt parts/info/process: https://www.tundras.com/threads/timing-belt-master-thread-sticky.107240/
    This thread is crucial to setting timing correctly: https://www.toyoheadquarters.com/threads/toyota-2uz-fe-timing-belt-marks-4-7l.335/
    I think the most important part is this: You only use the Aisin timing belt kit from a reputable source (i.e. not scAmazon, not fleaBay, not Temu, or other common sources of convincing-looking counterfeit parts).
    Don't fuck with other brands, Aisin made the factory/OEM parts. Toyota tells you "change every 90k miles or 9yrs", but that only applies if you use OEM parts. If you choose to go aftermarket, given the lackluster quality of aftermarket parts these days, you may get 40k miles? 50k miles? And with something that can snap and destroy your 2UZ-FE mild-interference engine, that's not cool.
    Not only that, but you need more than just a belt. Replacing the tensioner and pulleys and water pump while you're in there is pretty crucial, since any of those things failing can and will brick your engine too. Especially the pulleys and tensioner.
    Haynes and Chilton are always going to give you the 'shadetree, practical' method of handling things. I've used both of their books for more than 30 years. Regardless what anyone on YouTube tells you, either way should suffice.
    G_unit3000 and ATBAV8 like this.
  3. Feb 15, 2025 at 1:49 PM
    KreachR
    KreachR New Member
    Brandon
    2005 Tundra, Limited, Double Cab, 2WD
    CAI (AirRaid), Exhaust (Unkown)
    This might help to verify. EM-16 and EM-23.
    G_unit3000 likes this.
  4. Feb 15, 2025 at 1:55 PM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    I have an 01 Sequoia as well with over 300k on the clock. I’ve changed mine three times. Nothing difficult. Just lots to take off. I used a compact impact to remove the crank bolt and made a holder to
    Aid in torquing it down. If I remember correctly, it’s close to 188 ft pds. All good advice here. Buy nothing but the Aisin kit.
  5. Feb 15, 2025 at 1:57 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The attached pdf is from the toyoheadquarters.com that was linked above by @shifty` .
    Even tho you're a Sequoia, it will still be applicable.
    G_unit3000 and shifty` like this.
  6. Feb 15, 2025 at 2:16 PM
    txk131
    Thanks everyone! I’m going to dig through all your links, this is very helpful. I bought an Asin kit from rock auto. It includes water pump/gasket, tensioner, pulleys, orings.
    Weagle and shifty` like this.
  7. Feb 15, 2025 at 2:23 PM
    As long as it was the kit ending in '-021', you're golden! If the one ending in '-001', it lacks a couple of pieces.
  8. Feb 15, 2025 at 2:31 PM
    txk131
  9. Feb 16, 2025 at 4:07 PM
    txk131
    What is the thread count of the two outside bolts for the puller? The one I have doesn’t feel right and I don’t want to force it.
  10. Feb 17, 2025 at 8:05 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Not sure without checking, but I’d guess 8x1.25.
  11. Mar 2, 2025 at 3:00 PM
    txk131
    Got it done successfully. I’m no mechanic at all so it took me a few weekends. Thanks again for all the information. Very helpful.
