RainMan Fabrications - Switch Panels and More
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by RainMan_PNW, Dec 23, 2023.
  1. Dec 24, 2024 at 11:14 AM
    #301
    Wallygator
    Warpen Buffet can afford titanium pens.
  2. Dec 30, 2024 at 10:02 AM
    #302
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    bulldog93 likes this.
  3. Jan 29, 2025 at 4:39 PM
    #303
    94Toy22re
    94Toy22re New Member
    I placed an order and sent money through Paypal last night!
  4. Jan 29, 2025 at 4:42 PM
    #304
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’ve got a few orders that came in this week. The order tracking link in the first post is updated with status (payment confirmed on all those orders).
    I’m currently out of town for work but will be getting these orders printed on Friday and in the mail Saturday after I get back.
    thanks for the support!
  5. Jan 29, 2025 at 4:52 PM
    #305
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Sounds like you need to hire an assistant
    :wave:
  6. Feb 2, 2025 at 1:03 PM
    #306
    RainMan_PNW
    Casey
    Clark County, WA
    How long will it take you to build my empire up to that of your current paycheck provider?
  7. Mar 16, 2025 at 6:08 AM
    #307
    bigmace
    bigmace New Member
    Oregon
    2021 Silver Tundra Limited / 2019 Black Sequoia SR5
    Just wanted to say thanks! Ordered late last week and arrived in like 2 days (helps that I am only 100 miles away). Now I have a spot to mount my anytime camera switch and lightbar switch!
  8. Mar 16, 2025 at 9:02 PM
    #308
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Ordered me one,thanks rainman appreciate it. It just makes sense to have some controls at ur fingertips. Definitely doing rear window, and most likely tow haul. So when I’m up against a dodge ram they don’t see me reaching up to push a button before I step on it. Also think I’ll use rear window more.
  9. Apr 14, 2025 at 5:57 AM
    #309
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    @RainMan_PNW do you think you could print a panel for the switch pro 12 (or 6 but 12 would be better) footprint for small Toyota switches? My idea is to use the SDHQ overhead panel but modified to look more oem for heated seat switches and whatever else I come up with. Thanks.
    edit- adding a drawing of where my mind went for the class to discuss. My thought is to cut the red line leaving a small lip, then hopefully slide a flush fit panel with as many small switches as possible into the recessed area that is secured with hidden screws from the backside.
    Tripleconpanna likes this.
  10. Apr 14, 2025 at 2:01 PM
    #310
    RainMan_PNW
    Casey
    Clark County, WA
    You will find that there is not enough "depth" to the overhead area to fit the OEM (or OEM-style) switches. You are looking at 2.5-3 inches of total depth from face of switch to the back of the wiring connector without figuring on some non-kinking bend in the actual wires. Even cutting a hole in the headliner and passing the switches through it you'd be looking at hitting the cab sheet metal before you had room to actually fit a standard switch.
  11. Apr 14, 2025 at 2:04 PM
    #311
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Damn, I was hoping the drop in the SDHQ piece would provide enough room. I appreciate the feedback though.
  12. Apr 14, 2025 at 2:10 PM
    #312
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - I looked at it briefly early on and it's just not a good spot for something that doesn't hideously drop down below the main compartment.
  13. Apr 14, 2025 at 2:11 PM
    #313
    DiamondW
    Kent
    CenTex
    ‘17 CM
    With a bench seat and all my options used I’m thinking hideously dropped down may not be so bad:rofl:
    I had the Meso one for the sunglass holder in my Tacoma and loved it, if he ever makes them again a may order one and plastic weld and body filler it to work.
