2022+ TUNDRA SR5 HEATED STEERING WHEEL RETROFIT?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Feb 1, 2025.
  1. Feb 1, 2025 at 9:50 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    does anybody know if it is possible to retrofit a factory heated steering wheel into an 3rd gen SR5 model? TIA
  2. Feb 1, 2025 at 10:01 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Yes, multiple threads if you search
    6rian likes this.
  3. Feb 1, 2025 at 10:07 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    present me with a couple of SR5 specific threads then bud, because it seems that you’re seeing some threads that im not seeing..
  4. Feb 1, 2025 at 10:43 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Goobax likes this.
  5. Feb 1, 2025 at 3:27 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
  6. Feb 1, 2025 at 5:09 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
  7. Feb 1, 2025 at 5:24 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Clearly you are a rookie. The link I provided, as well as the same link provided by Goobax, answers your questions.
    To summarize, your SR5 will need a steering wheel with a heating element and a switch.
    Hope this clarifies your confusion.
    wkearney99 likes this.
  8. Feb 1, 2025 at 5:46 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    :facepalm::facepalm::facepalm:
  9. Feb 1, 2025 at 6:47 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Dude, did you even bother to open the threads? They both walk you through EVERYTHING. I’ve posted on both, multiple discussions on SR5 trim specific items. Don’t be dense when you’re wrong, just admit it and move on.
  10. Feb 1, 2025 at 9:58 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
