Amazing 1st Gen Headlamp Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Neo, Jul 12, 2023.
  1. Jan 29, 2025 at 12:49 PM
    #361
    woodamsc
    woodamsc New Member
    New Hampshire
    2003 Tundra v8 4.7l 4wd sr5
    I'd say go to page 1 and watch the video to get an idea of the process. Overall it was pretty simple.
    Passenger side access was a little tight, but you can take the top off the airbox top for better access.
    They fit right in like a normal bulb does, you just have to use needle nose pliers to remove the inner reflector first.
    There really isn't too much else to it. Scroll through this thread and you'll see some people report blinkers not working after going LED, due to LEDs using less current. Ends up making things wonky.
    But there's an extra dongle thing you can plug in to resolve it.
    It's kinda black magic to me, but the point is this is a very plug-and-play project. I did it in 30mins outside in the snow freezing my hands off.
  2. Jan 29, 2025 at 3:58 PM
    #362
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    I appreciate the reply, and I'm well aware of having to modify/remove the inner reflector. I guess I should have phrased my question differently...Which bulb is the go to? Seems since the beginning of this thread, the original CO Light projectors have been discontinued, and in reading more, the newer replacements sound a bit dodgy.
    FiatRunner likes this.
  3. Jan 29, 2025 at 4:50 PM
    #363
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I'd be interested to hear from a larger sample size about people's experience with the fans on these. How common is it for them to fail? Obviously `shifty knows his stuff, and if it wasn't for his warning about fans, I would have never considered avoiding them. It's possible the newer model Y6 with a fan is a perfectly good, long lasting headlight. I don't know...
    Looks like the Y7 is the only fanless model, currently. I kept mine as backups. I love the idea. But the fact that they cycled through the different colors just from turning my high beams on & off was a deal-breaker for me. I can make them work if I had to, but they annoyed me. Otherwise they were great. It was just that they cycled through the different colors when I didn't want them to (using high beams) that annoyed me.
    ATBAV8 and FiatRunner like this.
  4. Jan 29, 2025 at 4:51 PM
    #364
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I'm not sure what people have been buying recently, but the bulbs that I bought look identical to the CO Light Y1 series. These: https://www.led-colight.com/product...ightest-h4-9003-lhd-projector-headlight-bulbs
    I've had mine in my truck for more than a year and a half now, and they still work great. I purchased mine off of Amazon, sold under the BraveWay name, but as far as I can tell they are identical to the CO Light Y1's. They're likely from the same manufacturer in china.
    I believe the Y6's work fine but they have small cooling fans instead of large heatsinks, which is another failure point.
    ATBAV8[QUOTED] likes this.
  5. Jan 29, 2025 at 5:02 PM
    #365
    ATBAV8
    Tempe, AZ
    Thank you!
  6. Jan 29, 2025 at 5:04 PM
    #366
    ATBAV8
    Tempe, AZ
    This is a DEFINITE no go for me. Looks like fans are the only option.
  7. Jan 29, 2025 at 6:54 PM
    #367
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I wonder if you use a relay upgrade harness and change from ground switched headlamp wiring to 12v switched if it would stop that color change.
    Or maybe it just doesn't matter.
  8. Jan 30, 2025 at 7:11 AM
    #368
    MT-Tundra
    Montana
    I don't know! My electrical knowledge is patchy. At best. I understand there's something with our trucks that isn't the case with every truck, in how our headlights work. They actually turn off for a fraction of a second when going from high beam to low beam? Is that correct? The way you get the Y7 to change colors is by turning the headlights on & off till you hit the color you want. So if the headlight turns off when switching from low to high...the colors cycle. Someone (maybe you?) brought something like this up months back. If there's a way to change how the headlight works and stop it from turning off when switching from low to high and high to low, the lights wouldn't change color.
    It's not something I understand enough to do my own experimenting...I'd need someone to point out what product to try, and I could report back.
  9. Jan 30, 2025 at 9:21 AM
    #369
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    This might require wiring up your own relays and harness. I haven't looked too deeply into it.
    MT-Tundra[QUOTED] likes this.
  10. Jan 30, 2025 at 11:41 AM
    #370
    woodamsc
    woodamsc New Member
    New Hampshire
    oh man didn't realize they were discontinued! I bought my Y6 right from Colight maybe 4 weeks ago?
    https://www.led-colight.com/products/y6-mini-projector-6000k-led-headlight-blub-h4-9003-hb2
    I think I was looking at the Y12's as an alternative, but I can't remember why I landed on Y6. The website does a pretty poor job of explaining the differences and why you'd want this one vs that one, so I was half expecting to receive something that didn't work.
    I can say that the upgrade is pretty stellar (so far). Wipers + headlights really make it feel like a new truck
  11. Jan 30, 2025 at 11:47 AM
    #371
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    i cant do a projector because the sharp cutoff blocks the hills. My aux beams might not catch the deer (they’re set high enough to always work), but the stock headlights see a bit further, but gently.
  12. Jan 30, 2025 at 11:49 AM
    #372
    MT-Tundra
    Montana
    The Y6 aren't discontinued, they just "upgraded" them with a fan. Can't get a fanless model anymore. I'm guessing yours have fans. I was looking months ago and the Colight site no longer had the fanless model. A few of us found them on Amazonia.
  13. Jan 30, 2025 at 11:50 AM
    #373
    woodamsc
    woodamsc New Member
    New Hampshire
    Ohhh gotcha. Yeah mine have fans
  14. Jan 30, 2025 at 11:55 AM
    #374
    ATBAV8
    Tempe, AZ
    Either way, can't get the Y6 from CO Light. Sold out. I was hoping to find the fanless model.
  15. Jan 30, 2025 at 11:59 AM
    #375
    MT-Tundra
    Montana
    Yeah I noticed that. Sold out.
    Here's their comparison chart, grabbed from this page, which is the best explanation you'll find of the differences. Better than nothing...
    Neo[OP] likes this.
  16. Jan 30, 2025 at 12:01 PM
    #376
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    What's your budget? I have the CO lights on one car, morimoto D2s retrofit on the sequoia and morimoto H1 on the Tundra. The D2s is at least 3 times brighter than the CO lights, but way more expensive. I'm itching to find an excuse to go with the morimoto Mled
    CO lights are inexpensive and super easy and much better than OEM, but if you have the budget, time and desire (need) for better lights go full retrofit. The process is actually really easy.
    Tlar25 and G_unit3000 like this.
  17. Jan 30, 2025 at 12:27 PM
    #377
    MT-Tundra
    Montana
    For me, the Y6 is plenty bright. But...we're stuck with very few options once doing the minor mod to make them work. Of course you can always buy a new aftermarket headlight housing and go back to stock. But for me, now that I'm setup for the Y6, I'm kinda stuck. If they burn out, I'm in the same situation as ATBAV8.
    Doing a true retrofit that allows me a variety of modern bulbs and not having to chase discontinued parts is pretty appealing.
    ATBAV8 likes this.
  18. Jan 30, 2025 at 1:38 PM
    FiatRunner
    Jack
    Wait, what about the Y1? What I have on my truck looks identical to the Y1 and don't have fans.
  19. Jan 30, 2025 at 3:19 PM
    #379
    ATBAV8
    Tempe, AZ
    Did you have to install the CANBUS decoder? The Y1 doesn't have fans.
    FiatRunner[QUOTED] likes this.
  20. Jan 30, 2025 at 4:49 PM
    #380
    FiatRunner
    Jack
    I didn't have to install anything else to get it to work on my '00. I did buy a cheap resistor so the high beam indicator and fog lights work, but I didn't need it.
  21. Mar 11, 2025 at 1:14 PM
    #381
    DocHolliday3841
    DocHolliday3841 New Member
    2005 Blue Tundra Double Cab Limited 4x4
    I tried this upgrade but the only problem is you cannot aim it where you want, my Tundra has a 2-inch leveling kit and my cut off line is in the trees. People have flashed their headlights at me for this and I recently tried going back to the reflector housing with LEDs but I can't aim them exactly where I want either.
  22. Mar 11, 2025 at 3:45 PM
    #382
    rock climber
    There's an adjuster to lower the headlights.
  23. Mar 11, 2025 at 3:54 PM
    #383
    DocHolliday3841
    What? Where? I didn't see it
  24. Mar 11, 2025 at 5:34 PM
    #384
    Yeah, found that one using Search in about 30 seconds.
    It may be different between old and newer face styles. Read both replies.
    There's a copy of the service manual in the community megathread. You're doing yourself a disservice if you don't read the first two replies of that thread.
  25. Mar 11, 2025 at 8:48 PM
    #385
    DocHolliday3841
    I see you're the author of that enormous "So you're thinking of buying a first gen Tundra" post.
    I actually read that thing a few times over before I bought my 1st gen Tundra 1.5 years ago.
    But what I'm talking about are the aftermarket co-light LED projector bulbs. I've looked at the manual and read the box but I'm not finding instructions anywhere on how to aim them down. The factory adjustment screw doesn't work with these.
  26. Mar 11, 2025 at 8:50 PM
    #386
    It absolutely does. I adjusted mine several times using the adjustment screws on the housing.
    The bulb is locked in place, just like a halogen. There is no other way to adjust the bulb, other than using a ratchet on the back side of the adjuster.
    If you have aftermarket housings, cheap ones, those adjustment screws are shit. You may need to use a wrench on the back of the adjuster with the blinker out.
    You either mounted the bulb incorrectly, your adjusters are fucked, or you aren’t using the correct length and type of screwdriver, or you aren’t getting the angle right. The latter two are genuinely often the problem. But all four have happened. Repeatedly. To the point you’ll find about 10 other threads like the one I linked using the Search.
    I only posted that thread. I didn’t create all the content. I’m not a fucking genius. I did stay at a Holiday Inn Express last week, though.
    G_unit3000 likes this.
  27. Mar 12, 2025 at 5:24 AM
    #387
    My aftermarket housings with Colight mini projectors aimed waaaay the fuck down using the factory adjusters.
    bfunke and G_unit3000 like this.
  28. Mar 12, 2025 at 5:35 AM
    #388
    This is a good picture to highlight one big difference between the earlier-year trucks with metal bumpers and the later year trucks with plastic bumpers: In earlier years, the entire housing pivots up/down. In the later years, the housing stays stationary, there's apparently something mechanical inside the housing that pitches the seat for adjustments.
  29. Mar 12, 2025 at 5:52 AM
    #389
    For DC or for the later model AC headlights too?
  30. Mar 12, 2025 at 6:00 AM
    #390
    I feel like there may be chatter about it in the thread I linked above. I pitched my 2006 headlights up and down about 4-5 turns, and the front of the headlight housing appeared to remain flush with the blinker. That would suggest the movement is in the bucket, or maybe the aiming on the housing is a different design between years.
