I'm thinking electrical
Discussion in '1st Gen Tundras (2000-2006)' started by 01 Tundra SR5, Jan 22, 2025.
  1. Jan 22, 2025 at 10:05 AM
    01 Tundra SR5
    01 Tundra SR5 [OP] New Member
    2001 Tundra SR5 extended cab 3.4 - 4X4
    Hello everyone, I'm new here & I hope someone might be able to help me figure out what's wrong with my 2001 Tundra SR5 3.4 - 4X4 I had just stopped to put oil & power steering fluid in it since they both leak & as I was driving on the freeway it just shut off, it turns over but doesn't start, could it be the crank shaft censor? Or any other suggestion would be appreciated...
  2. Jan 22, 2025 at 10:15 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Jan 22, 2025 at 1:15 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Bob, FrenchToasty and AZBoatHauler like this.
  4. Jan 22, 2025 at 1:26 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Welcome to the forum. were here to help.
    Possible, but could be a bunch of other things too. It does have gas in it, right?:rofl:
    Let's start with the basics. The fact that it turns over tells me that it's got power so you can rule out battery and alternator. (Does the starter sound normal or does it sound like a cordless drill?)
    Pull a plug and check for spark. If you have spark, then next you'll need to check fuel.
    Check that your injectors are getting power. If so, pull an injector and test for fuel.
    What work have you done to it recently? The more info you can give us, the better.
    Here's a thread that has TONS of First Gen info along with a link to the Field Service Manual, Electrical Diagram and much more. So ... you wanna buy / just bought a 1st Gen Tundra, eh? | Toyota Tundra Forum
    Here is a little light reading if you're so inclined to do so as I don't believe that we will be able to properly assist you without any further info from you.
    Another Cranks, Won't Start Issue | Toyota Tundra Forum
    Crank No Start - Diagnosing and Solving | Toyota Tundra Forum
    No-start issue but starter cranks and battery is new | Page 2 | Toyota Tundra Forum
    Slow crank/no start | Toyota Tundra Forum
    Crank but not starting | Toyota Tundra Forum
  5. Jan 22, 2025 at 3:27 PM
    Welcome from NY.
    How many miles on it? Could be the timing belt.
  6. Jan 22, 2025 at 6:40 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Have you checked the ignition fuse? I always used to remove mine on the 3.4l as a theft prevention.
  7. Jan 22, 2025 at 6:56 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    It’s the 3.4L motor
    Yota303 likes this.
  8. Jan 22, 2025 at 7:10 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Since it just died instead of sputtering out, i’m thinking electrical, too. Check engine light come on?
  9. Jan 22, 2025 at 7:35 PM
    The Black Mamba and Sirfive like this.
  10. Jan 23, 2025 at 3:12 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Can confirm as I’ve replaced mine 3 times. Good thing is, the 5VZ is a non-interference motor. That’s why I asked initially if the starter sounds normal or like a cordless drill.
    Jim LE 1301 likes this.
  11. Jan 23, 2025 at 6:50 AM
    This.
    Timing belts, pretty universally in Japanese cars I've owned, must be changed every 100k. They're rubber. Just like tires. They get old. And when they snap, they can destroy a lot of shit, just not internal to the engine like the V8 4.7L. When was yours last changed, @01 Tundra SR5 ?
