  1. Jan 20, 2025 at 11:55 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    When it rains it pours, as they say. Anyone wanna tell me how in the hell….
    So, after I replaced my accessory belt tensioner pulley, truck seemed to run a lil rough. Pulled codes and see a P0171. First thought was - vacuum leak. Couldn’t find one. CEL on and misfiring. Drove maybe a mile, and CEL starts flashing. Engine noise bad. Misfire code on cylinder 2. Pulled coil and it was a little burnt and cracked at the end. Pulled the plug and found this.
    des2mtn likes this.
  2. Jan 20, 2025 at 12:11 PM
    What in the actual fuck?!
    I've seen a center electrode blown to shit, but I've never seen the ground arm and center electrode missing. And that's gotta be down in the cylinder somewhere. Shit man.
    Time to rig up a vacuum hose onto the vacuum and get vacuuming. Fingers crossed for you, brother. Go with Iridium plugs next go-round?
    BroHon likes this.
  3. Jan 20, 2025 at 12:12 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    :eek2: Thats rough man.
    The focus of the photo is a little out, hard to tell what were working with in regard to what's left of the plug. Is that corrosion around the threads and the electrode strap?
    Regardless of what caused it, if that electrode was bouncing around the top end its gonna be ugly. I'd start with a borescope in that cylinder.
  4. Jan 20, 2025 at 12:12 PM
    What plugs are these and where did you get them?
  5. Jan 20, 2025 at 12:13 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Champion plugs. 7346
  6. Jan 20, 2025 at 12:14 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    des2mtn likes this.
  7. Jan 20, 2025 at 12:15 PM
    Is that anti sneeze on the threads?
  8. Jan 20, 2025 at 12:15 PM
    Champion? Like for a lawn mower? That seriously sucks man. I hope there isn’t significant carnage and the cylinder can be saved! I would be concerned about counterfeit plugs the way that one fell apart.
    FirstGenVol and BroHon like this.
  9. Jan 20, 2025 at 12:17 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Champion makes plugs for vehicles too but yeah, idk. I only buy plugs from vatozone or o’reallys
  10. Jan 20, 2025 at 12:18 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Them threads are damaged/burned/chewed up.
  11. Jan 20, 2025 at 12:19 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Should probably pull a few more plugs eh?
  12. Jan 20, 2025 at 12:21 PM
    Need to borescope the cylinder for sure to see cylinder walls, cylinder surface, valves, check for remaining debris and even the spark plug threads. Would also check the oil for glitter.
  13. Jan 20, 2025 at 12:21 PM
    JakeJake
    2000 Tundra AC 4X4
    Yeah, I'll be shocked if that cylinder is salvageable.
  14. Jan 20, 2025 at 12:24 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    That center insulator looks like it's poked out 1/4' farther than it should be. :eek:
    I'll start chanting and meditating for a good outcome for you...o_O
    Jack McCarthy and FrenchToasty like this.
  15. Jan 20, 2025 at 12:25 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Dont say that
  16. Jan 20, 2025 at 12:27 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Whatever came off the plug probably just burnt up completely and cleanly, exiting thru the exhaust. Trying to be unrealistically optimistic here.
  17. Jan 20, 2025 at 12:30 PM
    JakeJake
    2000 Tundra AC 4X4
    The Black Mamba likes this.
  18. Jan 20, 2025 at 12:32 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
  19. Jan 20, 2025 at 12:37 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Completely possible to bounce out the exhaust with minimal damage if you are lucky.
    Got someone to run you home or run it out to you from home? Otherwise uber/lyft round trip?
    I've had a friend try autolite plugs in their honda ONCE. Immediately fried the ignition coil due to wrong resistance.
    Ngk or denso only for imports.
  20. Jan 20, 2025 at 12:48 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Just found one near me for $30 on FB marketplace. New in box. Waiting for a response
  21. Jan 20, 2025 at 12:50 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Haven’t heard this before.
    No Bosch?
  22. Jan 20, 2025 at 12:51 PM
  23. Jan 20, 2025 at 1:00 PM
    I got my Iridium Densos from Advance Auto Parts.
    It's NGK for me, unless it's Denso. Fuck everyone else. Advance Auto carries both brands.
  24. Jan 20, 2025 at 1:10 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    I’ve never seen that on a n/a engine. You running boost or nitrous?
    non-vvti engines call for copper plugs.
  25. Jan 20, 2025 at 1:23 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    @shifty` @JakeJake @KNABORES @assassin10000 @anyoneelse
    How does that happen? I first got a p0171 code, then just misfire codes but; Is it possible that a lean condition would cause a plug to fail like that?
  26. Jan 20, 2025 at 1:32 PM
    A plug firing too hot would cause the electrode to melt off and explode. Defective part will do it. Best guess that's what happened if you're running Denso coil packs.
    It happened to me on a catering box truck I was driving back from catering someone's Bar Mitzvah in Melbourne FL while working for a catering company in central FL. We had to bail and leave the truck on the side of the road, had already worked a 16hr shift, driving inclusive, and we were all too tired to deal with it at the time. But even then, only the very tip of the hooked ground electrode was toast, the center electrode was mushroomed, and part of the ceramic had cut burned into it. Yours looks like you melted it threads and all.
  27. Jan 20, 2025 at 1:40 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    So you’re saying I could throw a new plug in it and run it. Good as new. Gotcha. Another shitty part- I never did find a vacuum leak
    Sirfive likes this.
  28. Jan 20, 2025 at 1:44 PM
    JakeJake
    2000 Tundra AC 4X4
    A lean mixture can generate enough heat to get things melty, as can poor valve sealing, and to far advanced advanced ignition timing. Probably a cascade of failures as it continued to run.
    Like @Sirfive said, not really common in NA engines. We sometimes forget that these things are just controlled explosions :rofl:With the right air/fuel/timing jet fuel can melt steel beams.
    bmf4069, JasonC., oscardog86 and 2 others like this.
  29. Jan 20, 2025 at 1:45 PM
    JakeJake
    2000 Tundra AC 4X4
    Send it (with video)
    or
    inspect it, then send it.
  30. Jan 20, 2025 at 1:46 PM
    You asking if it were me?
    I'd scope the cylinder to make sure there's nothing in it.
    If it's not clear, I'd vacuum it.
    If it was clear, I'd pop a plug in it and send it.
    When I got home, I'd mark that coil pack with a scratch in the top, proceed to pull every damn plug and put new NGK or Denso in it, then reinstall that coil pack on another cylinder.
    I'd check the plug in that one cylinder with the scratched coil pack in 1k-2k miles, and the plug in the cylinder that just had the plug disintegrate and make sure they both look OK.
    EDIT: Only reason I recommend marking that coil pack is for reference later. By putting it on another cylinder, you can monitor that plug and know if it's too hot because the coil pack is failing, and you can monitor the spark plug on the cylinder that had the issue just the same, in case it's something specific to that cylinder, like running lean.
