Front sway bar removal ?
Discussion in 'Suspension' started by TheBeast, Oct 8, 2017.
  1. Oct 8, 2017 at 9:10 AM
    TheBeast
    TheBeast [OP] The Beach
    now that I have a decent suspension up front: KING coilovers + TC UCAs. I'm thinking of removing the front sway bar to get the full benefit of it. what do you guys think ?
    I also have the TRD rear sway bar.
  2. Oct 8, 2017 at 9:14 AM
    I've been hearing if ya do lots off roading it's good to remove front sway bar due to more articulation...and remove rear as well if off roading...IMO
  3. Oct 8, 2017 at 9:17 AM
    TheBeast
    yeah I'm wondering if removing the front and leaving the rear would control the body roll that I will get from removing the front only.
    Rear I'm thinking of disconnecting the links when O/R
  4. Oct 8, 2017 at 9:20 AM
    QTunDrA
    QTunDrA New Member
    Q
    2014 Tundra Platinum
    I wonder if the new 2018 TRD Sport front TRD sway bar makes a difference?
  5. Oct 8, 2017 at 9:24 AM
    TheBeast
    that's a good question
  6. Oct 8, 2017 at 9:25 AM
    TheBeast
    I wish we had some kind of sway bar quick disconnect system
    Mountun Goat and Theonlyway like this.
  7. Oct 8, 2017 at 9:36 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I have not heard of anyone removing the front sway bar without removing the rear one. Try disconnecting rear one first and see if you like the ride. Then remove the front. If you find the body roll to be too much, you could always reinstall it.
    TheBeast[OP] and Wynnded like this.
  8. Oct 8, 2017 at 9:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What @chphilo said, trial and error.
    TheBeast[OP] likes this.
  9. Oct 8, 2017 at 9:55 AM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    +1 for removing the sway bars
    I've taken corners fairly quick and never felt like I was in any sort of danger. Those Kings will definitely shine without the sways.
  10. Oct 8, 2017 at 10:20 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
    Take it off. Both of them:D
    Once I upgraded the suspension I took that off. Works great on and off-road.
    joonbug, speckmon and TheBeast[OP] like this.
  11. Oct 8, 2017 at 10:21 AM
    TheBeast
    ok. I think it's going away this afternoon..LOL
    joonbug and Tacotundra like this.
  12. Oct 8, 2017 at 10:21 AM
    TheBeast
    you guys are bad influence..whats next ? triple bypass KING 3.0 ? :spy:
  13. Oct 8, 2017 at 10:22 AM
    Tacotundra
    Vegas
    2017 Tundra
    Yea buddy:thumbsup: and if you don't like it slap them back on.
  14. Oct 8, 2017 at 10:23 AM
    Tacotundra
    Vegas
    2017 Tundra
    That you definitely need in your life!!!:stirthepot:
  15. Oct 8, 2017 at 10:25 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Triple bypass FTW.
    4x4_Angel and TheBeast[OP] like this.
  16. Oct 8, 2017 at 10:28 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    I'm running ADS and TC upper's w/o the front sway and I'm most likely going to put the bar back on. Riding trails is fine but on the hwy I think it could be better. Has a lot of sway and driving fast around corners and with dips feels unsafe . I'm waiting for an appointment to install King 3.0's, if I can't fix the problems with the secondaries, the sway bar will be put back on.
  17. Oct 8, 2017 at 10:33 AM
    Tacotundra
    Vegas
    2017 Tundra
    Your on a bracket lift?
  18. Oct 8, 2017 at 1:11 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Yeah, 7" BDS
    Junior 88 likes this.
  19. Oct 8, 2017 at 1:16 PM
    Tacotundra
    Vegas
    2017 Tundra
    Yeah on a bracket lift I would run the sway bar. Body roll is more prominent that high up.
    trayday[QUOTED] likes this.
  20. Oct 8, 2017 at 1:18 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Think it can be fixed at all with tuning of secondary shocks?
  21. Oct 8, 2017 at 1:26 PM
    Tacotundra
    Vegas
    2017 Tundra
    Might help a little. Your center of gravity is really high now so that's alot of mass way up high. And when turning that big truck its gonna lean.
    831Tun likes this.
  22. Oct 8, 2017 at 1:33 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Yeah, I was doubting I could fix it. I'll just toss it back on
    831Tun and Tacotundra[QUOTED] like this.
  23. Oct 8, 2017 at 1:47 PM
    Tacotundra
    Vegas
    2017 Tundra
    Probably best. Sorry couldn't be more help bud.
    trayday likes this.
  24. Feb 10, 2018 at 4:45 PM
    TheBeast
    alright front sway bar is gone...you guys leave the 2 bolts there or keep them with the bar ?
    Tacotundra likes this.
  25. Feb 10, 2018 at 4:49 PM
    Tacotundra
    Vegas
    2017 Tundra
    The ones at the control arms? Nope just leave them off.
    TheBeast[QUOTED][OP] likes this.
  26. Feb 10, 2018 at 5:00 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Left the rear bar? Lmk how it feels. I been thinking of doing the same.
  27. Feb 10, 2018 at 5:10 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    Keep us posted. I'm planning on taking off both sway bars.
  28. Feb 10, 2018 at 5:23 PM
    Vizsla
    Vizsla ☠️☠️☠️
    If I ever need to go hardcore off road, I will remove mine, it’s easy. I drive my family all over the country in my truck. Had the most unfortunate experience of a completely wasted person cut across 4 lanes entering the on ramp completely unconscious. It barely caught my front bumper, but I was heavy. Loaded down moving from CO to AZ, so family of 4, 2 dogs, and stuff to live for 2 weeks. The stability system, and to a far greater extent the sway bars kept me from flipping on my lid going into the median, only casualty was a few fish... Mine stay.
  29. Feb 10, 2018 at 5:40 PM
    TheBeast
    yes, the ones that attached sway bar links to LCAs
    Tacotundra[QUOTED] likes this.
  30. Feb 10, 2018 at 5:41 PM
    TheBeast
    I hear you. Now that I have another commuter car, it's my week end toy :)
    if I don't like it, I will probably add a sequoia or trd front sway bar..:spy:
