Front camera mounting, 2020 SR5 grill
Discussion in '2.5 Gen Tundras (2014-2021)' started by ChesterTundra, Dec 6, 2024.
  1. Dec 6, 2024 at 6:38 AM
    ChesterTundra
    ChesterTundra [OP] New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I'm looking for some advice on mounting a front camera on my 2020 SR5. I have this grill, and I'm aiming for the center hole below the toyota emblem.
    I found this mounting bracket that I think will work. Toyota Tundra Sport / SR5 Universal Mounting Bracket | Lights & Camera | Yota Leds
    Has anyone tried this one, or have another recommendation for camera mounting on this grill? I'm working toward the FRAC installation, but want to make sure I can actually mount the camera first.
    Here's the camera I'm considering: https://www.amazon.com/dp/B07H852D49 (have read the FRAC threads).
    TIA folks! :)
  2. Dec 6, 2024 at 8:19 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    ChesterTundra[OP] likes this.
  3. Dec 6, 2024 at 8:21 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    The one on my '19 SR5 is down in the open slot in the valance, (considerably lower than where you're talking about and I quite like the placement and the view it provides.
    I can see my bumper edge in the picture, so getting within inches of an object or car is really easy, as long as I can see daylight I know I'm good.
    I use mine mainly for parking, and it's nice to have off road. It's not for any kind of dash-cam duty.
    Just something to think about... if you do put it up in the grill maybe do it temporary first with some slack so you can compare different spots/views.
    It REALLY helps with parking, without front and rear cams I wouldn't have even tried this late night park job. :bananadance:
  4. Dec 6, 2024 at 8:30 AM
    SD Surfer
    Bruce
    So Cal
  5. Dec 6, 2024 at 9:38 AM
    Bullshawrk
    Bullshawrk New Member
    I like your route. I got the old trd style grill so i do have room to put under my emblem
  6. Dec 6, 2024 at 10:19 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    You folks are awesome, this is exactly what I as looking for. I read through the links BrandonL812 posted and like
    SD Surfer's location too. Good advice to try some spots. I ordered my FRAC and am looking at cams. Will do some testing and find a good spot.
    Thanks again!
    BrandonL812 likes this.
  7. Dec 6, 2024 at 10:24 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    Do you know which camera this is? I really like how the viewing angle shows the edge of your valance at this location, and tight parking is my use case.
  8. Dec 6, 2024 at 10:32 AM
    SD Surfer
    Bruce
    So Cal
    I gotta' say, the front cam is one of the best things I've done to my truck.
    I have a decent sense of spatial awareness, and have always been pretty good at knowing where my corners, bumpers, wheels, etc. are, but something about the sightlines and hood on this pig... 2 years in and I really have no idea where the front end is.
    I always think I'm way closer to objects in front of me than I really am.
    Another nifty feature since I installed the new HU and using the Maestro interface to retain steering wheel controls, is that I was able to program on of my steering wheel buttons (left side, UP arrow) to bring up the front cam if I Press & Hold so I don't even have to take my hands off the wheel.
    I chose that button 'cuz it kinda' points forward, so it's intuitive to "press forward" if I want to "look forward"
  9. Dec 6, 2024 at 10:38 AM
    SD Surfer
    Bruce
    So Cal
    I don't know for certain (got it from the stereo shop that did my install for this and the HU) but I think it might be this one.
    https://www.crutchfield.com/p_301HCAMC01/Hertz-HM-CAM-C01.html?tp=83
    I can probably find out.
    Yeah, having the valance edge in the frame really helps as a reference point.
  10. Dec 6, 2024 at 10:39 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    I have the same issue. I think I'm inches away, and when I look I've got almost two feet. That's what this should solve. I have used Maestro for a couple head-unit installs and am familiar with the programming process you describe. They make a neat unit. So far I'm staying stock on the Tundra though...my wireless carplay adapter is good enough and FRAC seems like a slick solution for the camera.
  11. Dec 6, 2024 at 10:47 AM
    SD Surfer
    Bruce
    So Cal
    Oh good, it's not just me! :rofl:
    It was kind of embarrassing actually... I'd be parallel parking, creeping a couple inches at a time being all careful thinking I was close, than I get out and look and I'm a foot and a half away.
