General Supercharger Thread
  1. Dec 4, 2024 at 2:18 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    It has to be extra wear on the belt and pullies being that tight, but there isn't really another option that I've seen... I tried to run the stock green belt with the 76mm pulley and it slipped way too much
    Mdl likes this.
  2. Dec 4, 2024 at 2:19 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    oh did you? i didn't even attempt it. not too surprised it slipped a lot, it wasn't all that tight (imo) from the start.
    I guess we will see. I'm going to swap the belts out when the new one shows up in a few days via Amazon and check pulley conditions at that point. fingers crossed.
  3. Dec 4, 2024 at 2:39 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Could try sand blasting the pulley ribs, I've thought about trying that.
    Mdl likes this.
  4. Dec 4, 2024 at 2:40 PM
    carn_dogg
    Pat
    Eastern Shore MD
    instead of replacing the belt? or when i replace the belt?
  5. Dec 4, 2024 at 2:41 PM
    snivilous
    SW UT
    Either or. The pulley is really smooth, roughing the surface could do a lot.
  6. Dec 4, 2024 at 2:43 PM
    carn_dogg
    Pat
    Eastern Shore MD
    oh you mean for the other belt to prevent slip and have a less tight belt?
    e30cabrio likes this.
  7. Dec 4, 2024 at 2:47 PM
    snivilous
    SW UT
    You have newish belt.
    Your belt slip.
    New belt will slip again.
    Fix? Make belt not slip.
    Same belt, and roughen surface.
  8. Dec 4, 2024 at 2:58 PM
    carn_dogg
    Pat
    Eastern Shore MD
    lol i have new ish tight belt. no slip.
    but yes i see what you're saying.
    Mdl likes this.
  9. Dec 4, 2024 at 2:59 PM
    snivilous
    SW UT
    I must be retarded and not following, I thought you said it was squealing?
  10. Dec 4, 2024 at 3:00 PM
    carn_dogg
    Pat
    Eastern Shore MD
    lol it is but not slipping. just making noise
    e30cabrio and Mdl like this.
  11. Dec 4, 2024 at 3:00 PM
    snivilous
    SW UT
    Semantics :rolleyes:
    Wynnded, e30cabrio, Mdl and 1 other person like this.
  12. Dec 4, 2024 at 3:25 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    ive been having what i think is a squeal too not sure if its a belt or pulley. dont know if its the same belt
  13. Dec 4, 2024 at 3:26 PM
    NatesNightMare
    Pinetop Az
    odd i domt have a prob getting mine on and off
  14. Dec 4, 2024 at 3:27 PM
    carn_dogg
    Pat
    Eastern Shore MD
    fairly certain you have the same belt. i remember talking to you when you purchased the 76 pulley from sniv and needed the belt. so you have about the same wear on yours... and it's starting to make noise.
    might be the fact that it's so tight. i'll replace this weekend and see how the belt looks.
  15. Dec 4, 2024 at 3:46 PM
    art64
    art64 New Member
    I ordered the kit through their ebay store because I wasn’t very trusting to this company. Very little reviews in the US, back then 2021. So with ebay, there’ll be a protection.
    No customs fees. Regular ebay fees only.
    Total price was $650.
    Shipped by Australia Postal, the EMS(Express Mail Service) took over afterwards. I just don’t remember if it was delivered by DHL or USPS to my address. It may have been DHL cause there was an email stating they weren’t able to deliver on that particular day. Shipped Feb 22, 2021 and recieved Mar 8, 2021. It’s a small package.
    Silver17 and Mdl[QUOTED] like this.
  16. Dec 4, 2024 at 3:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks!
  17. Dec 4, 2024 at 3:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You need a bit of deflection on the belt. Don't want to stress idler/tension bearings. Or shred a belt...
    ARES35 and Wynnded like this.
  18. Dec 4, 2024 at 4:35 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah I agree. Just not sure how to achieve that. Wish there was a known belt in between sizes. I have new idlers and new tensioner from when I installed the blower so we will see how they look this weekend (along with inspection of the belt)
    NatesNightMare likes this.
  19. Dec 4, 2024 at 5:00 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    https://a.co/d/7BIoFig
    Could always use one of these to check. I’m sure there are some specs out there to reference. What I read as a rule of thumb was you want 1/64” of belt deflection for each inch of belt span between 2 pulleys at 10 lbs of pressure.
  20. Dec 4, 2024 at 5:22 PM
    snivilous
    SW UT
    In my experience the belt will stretch if it's too short and has too much tension. I tried a belt setup on my buggy where I had to use a ratchet strap to stretch the fucking belt to get it on, and nothing bad happened and after a few hours the belt ended up not needing the ratchet strap to install (ie it stretched). So personally I wouldn't be too worried.
    The 2.3 Magnuson pulleys are the same way where they are a bitch to install with the slightly smaller belt. I wouldn't sweat running a tight belt.
    Now if the tight belt is slipping or squealing, it's probably not a belt fitment issue but is a traction issue. I suspect the squealing in the morning is from the belt not being flexible from the cold, or the pulley is cold and traction drops, etc. That's why I've thought of roughening the pulley surface, I think something as simple as sand blasting (even wire brushing) the ribs would considerable increase the belt traction.
    ARES35 and helidave like this.
  21. Dec 4, 2024 at 5:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When it gets cold, all of your pulleys shrink making your belt too loose. ;):rofl:
    Silver17 and helidave like this.
  22. Dec 4, 2024 at 5:50 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
  23. Dec 4, 2024 at 5:53 PM
    NatesNightMare
    Pinetop Az
    even after being warm and driven i still have this slight squealing
  24. Dec 4, 2024 at 5:57 PM
    carn_dogg
    Pat
    Eastern Shore MD
    blast from the past. just did this. hope to see some results
    PolishedTRD[QUOTED] likes this.
  25. Dec 4, 2024 at 6:06 PM
    Silver17
    Eastern PA
    Try some belt dressing. It’s a bit of a bandaid fix. Really good on salads.
  26. Dec 5, 2024 at 1:26 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    If someone told me the cheapest way to get a 2-ton hoist was Bed Bath and beyond I'd have called bs.....
    Mdl, Abell207, helidave and 3 others like this.
  27. Dec 5, 2024 at 2:36 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Something interesting happened when I tested my wiring project...no I didn't let the smoke out...my fuel pressure went up 5PSI...testing showed 50PSI when base was previously set at 45PSI. Same power/ground wire sizes, Key-on engine off.
  28. Dec 5, 2024 at 3:15 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
  29. Dec 5, 2024 at 3:44 PM
    pursuit2550
    pursuit2550 New Member
    They've talked about using Lexus coils from the turbo engines. They fit and they work but something about the ECM not taking full advantage of the Lexus coils. It was something to that effect. So I would figure that any so-called high performance coils would be the same thing.
    Abell207[QUOTED] likes this.
  30. Dec 5, 2024 at 3:48 PM
    Silver17
    Eastern PA
