EEF Qi Charger v2 Release and Dual Charger Sneak Peek…
Discussion in '3rd Gen Tundras (2022+)' started by Front_Range_Pro, Oct 28, 2022.
  1. Oct 10, 2024 at 7:44 PM
    #511
    jwhite82059
    jwhite82059 New Member
    2023 Toyota Tundra Limited
    It is now working, but for a while it was a wix error page. There is now a TEST TEST item in the shop with a $10 price. I wonder if that is a placeholder for their Dual Charger?
    EFF told me it was a place holder for the Dual Charger, which will not be a the $10 price point. A few days after that the TEST TEST item was gone, but still no duel charger is listed
  2. Oct 12, 2024 at 8:30 AM
    #512
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Got a question for anyone who replaced their factory qi with the slee. Does it register on the screen like the factory one does?
  3. Oct 12, 2024 at 9:01 AM
    #513
    Breathing Borla
    Northern Illinois
    that comes from the phone, not the charger
  4. Oct 12, 2024 at 9:39 AM
    #514
    matth66
    matth66 New Member
    matt
    Nor cal
    it does? That seems strange since if you put a phone on that charger that isn’t connected by a Bluetooth it still registers
  5. Oct 12, 2024 at 5:18 PM
    #515
    matth66
    matth66 New Member
    matt
    Nor cal
    In the non CarPlay the qi charger shows up in the top right, and it will say in a banner across the top charging or charging has stopped
  6. Nov 2, 2024 at 12:07 PM
    #516
    RatPanda
    RatPanda New Member
    2022 Tundra 4x4 CrewMax 5.5
  7. Nov 2, 2024 at 1:33 PM
    #517
    matth66
    matth66 New Member
    matt
    Nor cal
    Does the kit where you have the QI charger ready simply plug into the factory plug?
  8. Nov 6, 2024 at 5:32 PM
    #518
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Those who have ordered from EEF, slow response? Ordered 4 days ago, no shipping notice and no response to email.
  9. Nov 7, 2024 at 2:40 PM
    #519
    jctmundra
    Northern VT
    To follow up, EEF has responded, part is on it's way.
    Mr Rick likes this.
  10. Nov 7, 2024 at 2:48 PM
    #520
    HNTR918
    HNTR918 New Member
    2022 Toyota Tundra Limited TRD-Offroad
    Fox 2.5 DSC Shock Package 3'' Front 2'' Rear - Accutuned SCS 17.5x8.5 +20 Blaze10 MT Baja Boss 37x12.5r17 Dobinson 2'' Rear Springs RC Forged Upper Control Arms Westcott Design Tire Clearance Kit
    @Front_Range_Pro
    Is the dual charger ready for sale?
    If not, what is the ETA?
  11. Nov 18, 2024 at 7:15 PM
    #521
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Any see these OBD chargers use them? Need to start looking at better snug chargers as the wifi connect uses to much battery.
  12. Nov 20, 2024 at 6:00 PM
    #522
    Mr Rick
    Mr Rick New Member
    Did you get the part and get it installed? If so is it working out better than the factory POS?
    TIA
  13. Nov 24, 2024 at 6:19 PM
    #523
    jctmundra
    Northern VT
    Yes, was shipped promptly after contact. Installed it tonight, works much better than the OEM, at least it immediately connects to my S21 with otterbox where as the OEM required finding the best spot. I'll reports back after some longer term usage.
    Here is an image of OEM vs EEF. Interesting that OEM has a fan where eef is passive cooling.
    sudobash and Mr Rick[QUOTED] like this.
  14. Nov 24, 2024 at 7:40 PM
    #524
    Mr Rick
    Mr Rick New Member
    Thanks, does it plug into the oem power source or do you have to plug into a usb-c in the center console? I have seen it being done both ways.
    Thanks again.
  15. Nov 24, 2024 at 9:18 PM
    #525
    jctmundra
    Northern VT
    Used the OEM connector. Plug-n-play
    Mr Rick likes this.
  16. Nov 25, 2024 at 2:51 PM
    #526
    jctmundra
    Northern VT
    Ran it a bit today. With OEM, my otterbox'd s21 would intermittently connect while leaning in it's spot. Never gained charge, but loss slowed. With the EEF, same phone/box, it says connected. In all cases, running AA, maps and streaming XM through the phone, it gains about 1% charge over 10 minutes. Now that the charger is functional, have to contain the natural tendency to clutter the cubby where it lives.
    Mr Rick and sudobash like this.
  17. Dec 1, 2024 at 9:08 AM
    #527
    matth66
    matth66 New Member
    matt
    Nor cal
    Was looking at the install video, it showed plugging the charger into the usb in the center console. Your version you didn’t need to?
  18. Dec 1, 2024 at 9:13 AM
    #528
    jctmundra
    Northern VT
    correct. I replaced the factory unit, plugged into the factory connector.
    Tundrastruck91 likes this.
  19. Dec 1, 2024 at 10:02 AM
    #529
    Frank_TRD23
    Frank
  20. Dec 1, 2024 at 10:39 AM
    #530
    matth66
    matth66 New Member
    matt
    Nor cal
    With the eef does it pop up and register on the head unit like the factory one?
  21. Dec 1, 2024 at 11:48 AM
    #531
    jctmundra
    Northern VT
    My factory did not, neither does the EEF.
  22. Dec 1, 2024 at 1:30 PM
    #532
    matth66
    matth66 New Member
    matt
    Nor cal
    It doesn’t display (see images)
  23. Dec 1, 2024 at 4:05 PM
    #533
    jctmundra
    Northern VT
    So that is what that symbol is - curiosity never rose to the level to break out the manual. I've seen it, always been the same which I expect as my phone seldom charged. The EEF uses two pins on the connector, the OEM appears to use 8 pins which explains the feedback to whatever module (BCM?) updates the display.
    Took a few moment to interrogate the OEM - impressive. EEF uses brute force to connect with 3 coils. The OEM is smarter in that the charge coil searches (XY motors) for the optimal position to charge, or at least it appears to be designed that way or it knows the phone model and has a lookup table for position. It also has a cooling fan.
    "The more they overthink the plumbing, the easier it is to stop up the drain" - Scotty
    KClav, manapiko and mrfreeman like this.
  24. Jan 6, 2025 at 1:36 PM
    #534
    jwhite82059
    It is now 2025, and still no dual charger is on their website.
    sudobash likes this.
  25. Jan 6, 2025 at 1:48 PM
    #535
    BillorJackorPeteorDennis
    BillorJackorPeteorDennis New Member
    Washington, DC
    ‘25 TRD Pro - Mudbath
    I have now had a 2022 and a 2025 and the original factory charger didn't have the moveable motor to find the "sweet spot" and it never stayed connected to any of my phones to charge at all (a Samsung Android and two different iPhone's).
    Not to denigrate an honest start-up who is trying, but the EEF that I purchased actually connected to my phones but only charged enough to keep Android Auto from sapping my devices battery.
    The factory charger in my 2025 has the moving motor and usually stays connected, but still doesn't charge much, especially with Android Auto connected. I can drive for an hour and my phone battery goes up 2 - 4 percent.
    I gave up. Just use the corded method. It keeps the hair on my head from turning grey and keeps me from tearing apart the console for little to no gain.
    sudobash, Woocawachie and Raven67 like this.
  26. Jan 6, 2025 at 6:35 PM
    #536
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Wonder if it’s backwards compatibles. Taking the part number off of 2025 truck and using that charger in 22-24 model trucks.
  27. Jan 6, 2025 at 6:41 PM
    #537
    jctmundra
    Northern VT
  28. Jan 9, 2025 at 11:19 AM
    #538
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Anyone interested in a v1 charger? Never got around to installing it and won't now that I have my dash mount
  29. Jan 9, 2025 at 3:42 PM
    #539
    matth66
    matth66 New Member
    matt
    Nor cal
    Is this the one that plugs directly to the factory harness?
  30. Jan 9, 2025 at 3:55 PM
    #540
    eddiefromcali
    Eddie
    100% Stock
    yeah, its the oem replacement
