Amazing 1st Gen Headlamp Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Neo, Jul 12, 2023.
  1. Nov 12, 2024 at 3:42 PM
    #331
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    Outside of PDX OR
    2003 SR5 V8 AC TRD 4x4
  2. Nov 12, 2024 at 4:43 PM
    #332
    bfunke
    bfunke Tundra Curmudgeon
    A really long Phillips
    dirtnsmores likes this.
  3. Nov 12, 2024 at 6:22 PM
    #333
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
  4. Nov 20, 2024 at 7:45 AM
    #334
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Warning - Fog Light Reply, not Headlight
    I ordered the Auxbeam mini-projector LED fog light bulbs and the resistors that @shifty` posted earlier in this thread.
    They arrived yesterday. They seem built well enough for $50. I'm not crazy about the 'cooling fans' , but what are you gonna do?
    The included instruction pamphlet doesn't seem specific to these bulbs and is very generic.
    I'm very much a newbie to LED, or any tech for that matter . . . a question I have before I climb under the truck is that I don't see a 'top' or 'bottom' for these bulbs. Other models of this brand include an allen wrench to loosen a set screw for clocking adjustments . . . but these don't have that.
    Does anyone know if these are these just a 'spray pattern' with no top or bottom ?
    Looking closely at the lens and body, I can't see anything that would give me any orientation.
    G_unit3000 and dirtnsmores like this.
  5. Nov 20, 2024 at 9:46 AM
    #335
    Projectors are normally for driving and not fog light patterns, interested to see the light pattern for these
    G_unit3000 likes this.
  6. Nov 20, 2024 at 9:52 AM
    #336
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Maybe they aren't a traditional 'Projector' and more of just a spreader beam through a lens.
    I tried calling their customer service to ask a couple questions with no answer 'shocking' . . . so I sent an email.
    I'll report back more findings here if anyone cares.
  7. Nov 20, 2024 at 10:57 AM
    #337
    dirtnsmores
    Southern CA
    Damn looks like you're a pro at this now. Want to do mine? I can bring a case of beer over! :drunk:
    I ended up going with the Y7S because the more softer white color intrigues me. Super white/blueish LED color always throws off my eyes.
    https://www.led-colight.com/product...HdomDqAVHIJYdwR32GSbfsZxUZN3N1ninl5i4toMbegna
    I think I'll get started in my driveway tomorrow hopefully everything comes out easy.
  8. Nov 20, 2024 at 12:00 PM
    #338
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Did you find a way to keep them from running through the different light colors while you're driving? With mine, switching the high beam on & off caused the low beam to cycle through all 3 colors. I could have tolerated having to switch the headlights on/off every time I start the truck, to get to the color I want. I wasn't ok with the color changing on it's own while I was driving, because of having to turn high beams on/off.
    dirtnsmores[QUOTED] likes this.
  9. Nov 20, 2024 at 12:25 PM
    #339
    dirtnsmores
    Southern CA
    I haven't installed them yet... But I'll let you know. I almost never have to use my hi beams so it won't be much of an issue for me. Will check on that though.
  10. Nov 20, 2024 at 2:29 PM
    #340
    MT-Tundra
    Montana
    Ah alright. Yeah I really liked the color spectrum and the option of using amber instead of the harsh blue/white of most LED headlights. But every second or third time I'd cycle my high beams, the low beam color would change. On the interstate out here it's pretty much constant on/off with the high beams. The amber color doesn't cut it at 70+mph after dark, and the only way to get off that color was either completely on/off with the headlights, or on/off multiple times with the high beams. Either way oncoming traffic would get distracted or pissed.
    dirtnsmores and G_unit3000 like this.
  11. Nov 20, 2024 at 6:22 PM
    #341
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Well, I got a brief reply email from Auxbeam… they’ve been discontinued. Wonder if I should even install them …. Hmmmmm
  12. Nov 23, 2024 at 2:52 PM
    #342
    Jones03Tundra
    Jones03Tundra New Member
    2003 Tundra Access Cab V8 SR5 4WD
    Installed Auxbeam headlights and fog lights today. I did need to add a resistor to both sides, but everything works/looks great!
    Question: Where/how do we put the resistors so they are out of the way and not just loose moving around?
    These threads have been SO helpful! Just purchased a 2003 AC SR5 4WD for my son who will be 16 next month. He loves doing all of this himself, but we have a lot to learn!
    Neo[OP] and Leo's first like this.
  13. Nov 23, 2024 at 3:43 PM
    #343
    The resistor and drivers can get hot. Ideally mount them on sheet metal in-around the housings. I like industrial commercial Velcro for mounting. Lots of other stuff you may need to look into here.
    Jones03Tundra[QUOTED] likes this.
  14. Nov 23, 2024 at 3:58 PM
    #344
    Jones03Tundra
    I would much prefer velcro to screws! I saw a post that said to use a self-tapping screw to attach it. I’m going to try the velcro.
    I have the post you linked book marked. We’ve gone through it a lot
    shifty` likes this.
  15. Nov 24, 2024 at 7:20 AM
    #345
    team ziptie here. The ultimate in secure, removable, repeatable and relatively clean attachments. Use any existing hole. TWSS
  16. Dec 6, 2024 at 2:22 PM
    #346
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Well I finally got those Auxbeam mini-projector headlight bulbs installed.
    I had purchased the resistors with them as well . . . but when I plugged everything together . . . no dice.
    I took out the resistors and plugged the bulbs straight to the factory plug and everything works as should.
    Just a guess, but 'maybe' since I already had put in resistors at the headlights, and the DD LED Flasher relay as well, there was no need for relays at the fogs . . but who knows.
    I'll update with a picture tonight . . . but so far in the garage they appear much brighter then the halogen, and the color match is much much closer. 6500 headlights, & 6000 fogs.
    Still not crazy about the 'cooling fans', but we'll see . . . with the truck off you can just barely hear them running if you're standing at the hood.
    KNABORES likes this.
  17. Dec 6, 2024 at 6:25 PM
    #347
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Tlar25, Filthyphil, MT-Tundra and 3 others like this.
  18. Jan 12, 2025 at 10:05 AM
    #348
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Alright Team,
    What's the latest and greatest for mini projectors and longevity?
    I am having a hard time parsing all the Co-Light options. The only fanless option from them right now is the Y7s, which I do not wish to use because you have to cycle through the colors...
    Anyone use the Y9 Plus? Or the Y16 with success? Or.. a "tried and true" fanless model from another brand?
    Thanks all for your time!
  19. Jan 28, 2025 at 12:36 PM
    #349
    woodamsc
    woodamsc New Member
    New Hampshire
    2003 Tundra v8 4.7l 4wd sr5
    Just installed mine, Y6 with the fans. Not in love with the fans but whatever.
    Are people running the wire out the boot jammed against the fan? Seems like water will get in eventually. There are clearly 2 exit holes meant for wires on my dust boots, but they're too small to get the twist plug through I think.
    I'll also mention that the spring clip doesn't fit true anymore. The LED lights sit farther back (into engine bay) so that spring clip has more tension on it than it should.
    There's nothing to hold the lights in without the spring clip though, unless I drilled and tapped a hole for the provided screw to hold on.
    I have cheapo headlights from Amazon - the reflectors are actually screwed in, so you can just unscrew them and then needle nose crush em out.
    I also bought those extra in-between dongles that prevent blinker issues. No idea if I need em or not, but things seem to be working.
    Hoping I don't need to align the lights much. One of the lights is ziptied down and don't think it will respond to the alignment screw.
    I will almost definitely need to align them >->
    Honestly the whole thing feels jerry rigged, but I'll take a better stab at it in spring
  20. Jan 28, 2025 at 12:49 PM
    #350
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Yeah, I have cheapo housings too and it was a bit of extra work to get the projectors to fit well. I ended up having to fab up a bracket to hold the bulb in place, as I had broken the tabs that the spring clip goes into. Like this: https://www.tundras.com/threads/2000-limited-trd-refresh-repair-story.116395/page-8#post-3189586
    Are you able to send a photo of how the wires exit the projector assembly? My fanless ones have the wire coming straight out of the heat sink. I assume yours are different?
  21. Jan 28, 2025 at 3:43 PM
    #351
    woodamsc
    woodamsc New Member
    New Hampshire
    Sure, will do. My wire just goes straight out the back through the main hole in the boot.
    I had to carefully pull the wire away as I screwed in the fan, else the edges would have shredded the wire sheathing off.
    Certainly not water tight, but it's around 5F here so...water currently doesn't exist lol
    Just drove around and these Y6 bulbs are pretty nice. I think both my headlights are aimed way low
  22. Jan 28, 2025 at 4:39 PM
    #352
    FiatRunner
    Jack
    So I took a look at COLight's website just because I was curious. Check out what I found, this is the description for the Y6 bulbs:
    Maybe that's why you're having issues. The bulbs that I got look the same as the Y1 series.
  23. Jan 28, 2025 at 4:48 PM
    #353
    We discussed this one quite a while ago. Maybe even in this thread? It's when we were talking about the Y7. The info from CO is wrong.
    FiatRunner[QUOTED] likes this.
  24. Jan 28, 2025 at 4:50 PM
    #354
    FiatRunner
    Jack
    Ah. That makes sense. Maybe I need to be refreshed- but there is a reason that the Y7 or Y9 is better than the Y1, which is what I have on my truck? My Y1s have been flawless so far.
  25. Jan 28, 2025 at 4:57 PM
    #355
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    :spy: Gonna need to spend some time snooping
    Would loveeeee some brighter headlights :D
    FiatRunner likes this.
  26. Jan 28, 2025 at 5:00 PM
    #356
    Y7 is the tricolor IIRC and is apparently really shitty/annoying. And no real improvement on the weird blue-purple abberation at cutoff.
  27. Jan 28, 2025 at 5:06 PM
    #357
    FiatRunner
    Jack
    Sometimes it requires some trial and error to get these set up right, but the performance is really awesome for the cost of mini projectors. I'm really happy with mine, and I do all kinds of driving, highway, city, inclement weather, etc. Here's some examples:
    https://www.tundras.com/threads/2000-limited-trd-refresh-repair-story.116395/page-11#post-3543898
    https://www.tundras.com/threads/2000-limited-trd-refresh-repair-story.116395/page-9#post-3191557
    Nicklovin[QUOTED] likes this.
  28. Jan 29, 2025 at 7:01 AM
    #358
    MT-Tundra
    Montana
    Yes we talked about that statement on their website, in this thread. I asked them about it. Someone (maybe multiple people) reached out to them with issues, likely some of the same issues people here have had, so they added that language. But as we've found here, these headlights are more or less plug & play for some, but not others. Others have definitely needed to make other modifications. They installed and worked with no issues for me.
    I managed to snag a set of fanless Y6's when I saw they were on their way out from Colights lineup. Amazon still had stock and a few of us bought them up. So far I've been very happy with them.
  29. Jan 29, 2025 at 7:01 AM
    #359
    Mine are still going strong.
    MT-Tundra likes this.
  30. Jan 29, 2025 at 7:25 AM
    #360
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Okay. So if a guy wanted to do the projector conversion today, what should be the first I look at? I want to do it right the 1st time.
