  1. Nov 12, 2024 at 12:39 PM
    Ok, so Denso clearly works. Here's what I paid for mine from RA (this part is for us). I know, not ideal $$$ but they last 15-20 years, so you won't be buying again soon.
    And this sensor DiscountTire installed appears to be 100% compatible with the TPMS ECU in my 2006. Maybe it'll work for you and cost less. I've actually got 4 of them that are a few months old (used) in my hand right now I'm happy to let go of.
    It's the Continental REDI-Sensor, model # SE10007 (this part)
    jerryallday and Burgmane[QUOTED] like this.
  2. Nov 12, 2024 at 12:42 PM
    I'm leery of replacing my battery terminals with any of the really cool looking ones that would clean up the wiring due to this very problem.
  3. Nov 12, 2024 at 12:45 PM
    And on the DiscountTire topic, found the first fuckup when I pulled the Method wheels out of the bed.
    Random alloy washer. Of course, it's for a TPMS sensor. This should be really damn fun to get back on without blowing the seal on the sensor and deflating the tire. If I can figure out which one it was, guess I'll jack it up, deflate the tire to release pressure, them manage. Lame.
    This is why I hate people touching my vehicles.
    Hi06silver and oscardog86 like this.
  4. Nov 12, 2024 at 1:20 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    I wish someone made a 4 gauge upgrade of the cables and grounds similar to these.image-3372034287.jpg
  5. Nov 12, 2024 at 1:24 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I made my own out of 2/0, but there are these:
    https://www.jeepcables.com/products/toyota-tundra-big-7-battery-cable-kit-gen-1-2000-2006
    or through
    @baraynavab
  6. Nov 12, 2024 at 1:26 PM
    02TundraIdaho
    02TundraIdaho New Member
    LG
    02 Tundra / 11 ES350
    no Mods... has new headlights and some dings on the side... just purchased a dent puller and Bilstein 5100's for it..... absolutely love it in the 2 weeks I've owned it...
    TURNS OUT THAT IT WAS A 5 AMP FUSE UNDER MY DASH HAD BLOWN AND AFFECTED EVERYTHING.... CRAZY!
  7. Nov 12, 2024 at 1:35 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Thanks for posting that. I've learned to not even use my wiper fluid while I'm driving unless I want most of it to end up on my driver side window, dripping into the cab if the window's open. I try to only use it when I'm not moving. I just ordered these. Excited to see the improvement.
  8. Nov 12, 2024 at 2:02 PM
    Shit, I got so tied up today I totally forgot I read this. I was going to tell you to check EFI 1 and EFI 2 fuses. Which one was it, in reality?
  9. Nov 12, 2024 at 2:03 PM
    @baraynavab does, actually. He's a good guy, I've dealt with him in the past.
    baraynavab and des2mtn like this.
  10. Nov 12, 2024 at 2:06 PM
    Oh, and hat trick post here.
    Not apples to apples angles here, but here's 285/75r17 (32.9") versus 275/75r17 (32.5") on the same truck, same wheels, same lift. You'd see a slight width difference from behind, but honestly, that half inch (er, quarter inch top & bottom) of added tire diameter is negligible to me, visually.
    Wildpeak AT3W in 285:
    Mickey Baja Legend EXP in 275:
  11. Nov 12, 2024 at 2:12 PM
    Another angle, 285 first, 275 second.
  12. Nov 12, 2024 at 6:40 PM
    Desert Dog
    @shifty` & @des2mtn , tu both for pointing out a source for upgraded cables and grounds!
    shifty` and des2mtn like this.
  13. Nov 12, 2024 at 6:43 PM
    Personally, I like the silver wheels over the gold.
  14. Nov 12, 2024 at 7:05 PM
    02TundraIdaho
    LG
    Shifty.... Not looking at it now it was the 5A in the middle - related to dash operations (weird how many things are tied to it...) Number 23
    shifty`[QUOTED] likes this.
  15. Nov 12, 2024 at 8:09 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    BroHon[QUOTED] likes this.
  16. Nov 13, 2024 at 5:04 AM
    Yup, I forgot there was a dash fuse tied to MP/SMP EFI. 23 in the 2002s handles SRS airbag, fuel injection system, discharge system, ignition system. I would expect with that fried, you wouldn't get ignition or fuel.
  17. Nov 13, 2024 at 6:39 AM
    importxpresions
    importxpresions New Member
    2001 SR5 AC Imp Jade Mica 2WD
    It's a great improvement and takes all of maybe 10 minutes or less to do. I should have done them sooner
  18. Nov 13, 2024 at 6:56 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Do you have a part number for the FJ nozzles? Thanks!
  19. Nov 13, 2024 at 7:22 AM
  20. Nov 13, 2024 at 7:50 AM
    importxpresions
    Sure thing, you need two x 85381-34030
  21. Nov 13, 2024 at 9:32 AM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Painted my rear bumper, it was replaced by the previous owner but never painted. Looks a million times better now. PXL_20240829_210031153.jpg PXL_20241111_180842393.MP.jpg PXL_20241111_180849632.MP.jpg
  22. Nov 13, 2024 at 9:56 AM
    oscardog86
    Southern California
    The infamous step side!
  23. Nov 13, 2024 at 12:53 PM
    Desert Dog
    So, 2 other changes I've noticed since changing out injectors and logging some seat-time to allow the ECU to relearn is, 1, the slight lag in throttle response/transmission engagement at very low speeds while turning a sharp corner is gone, and, 2, the shift from 2nd to 3rd is higher up in the rpm range. May be other things I haven't noticed yet, but those 2 things definitely stand out.
    455h0le_dachshund likes this.
  24. Nov 13, 2024 at 1:26 PM
    I'll preface this by saying, not trying to piss on your upgrade with this comment, so don't take this my reply wrong way.
    A lot of what you're describing can be attributed to swapping out some very, very tired and dirty 230,000 mile injectors with brand new injectors. It's clearly a great upgrade for that reason alone.
    That said, I gained some solid perspective from this video.
    G_unit3000 and Filthyphil like this.
  25. Nov 13, 2024 at 4:02 PM
    Desert Dog
    I don't disagree, and no offense taken. Just sharing my experience for the sake of other high-mileage owners who may be on the fence and some of what to reasonably expect.
  26. Nov 13, 2024 at 4:26 PM
    I've been teetering on it and I've only got ~80k. :rofl:
  27. Nov 13, 2024 at 5:13 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Installed some Firestone RideRite bags on the Tundra today. Reason is because with the bed shell and tools/misc. in the bed, I was getting a little bit of squat. No bueno. However, I was really liking the braking performance with a bit of squat. Question is: If I adjust the LSPV, can I achieve the same amount of brake performance? If I understand the adjustment, it should be initially set at 4.72" from axle nut to arm nut. I think I understand that if I shorten that, I will increase braking, as if there is a load on. Is this correct thinking?
    455h0le_dachshund and FiatRunner like this.
  28. Nov 13, 2024 at 5:29 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Replaced window mouldings front drivers and front passenger. The replaced the hose to hose, turbo brass, over priced thingy. It was a plastic T fitting with a cap. Probably gain like 5.25 HP from this mod!.YB!
    Tlar25, Kimosabe, oscardog86 and 4 others like this.
  29. Nov 13, 2024 at 5:50 PM
    Desert Dog
    80k? I doubt very much you would any performance benefits from replacement, so not a good value for the $. Besides, don't you have some tires or wheels to buy? :rofl:
    Seriously, you're better off taking your wife or wife & family out to dinner.
  30. Nov 13, 2024 at 6:28 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    The higher up towards the bed the arm is, the more braking power it will apply to the rear.
