Brakes and Rotors
Discussion in '3rd Gen Tundras (2022+)' started by Yurt, Jul 2, 2024.
  1. Oct 5, 2024 at 10:43 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Nice! Any links to those and boys?
  2. Oct 5, 2024 at 10:57 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  3. Oct 8, 2024 at 6:00 AM
    Black widow TRD
    Manuel
  4. Nov 1, 2024 at 9:40 AM
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    Just brought my truck in for its last free service with 15,000 miles on it. Been having some shimmy issues when I get off the highway and would skweak when I come to a stop. I was just told that my rotors are warped and the pads need replaced.
    Service manager refused to warranty out the breaks. Looking at over 700 to replace.
  5. Nov 5, 2024 at 9:23 AM
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    So was able to get my pads and rotos replaced under the TSB T-SB-0043-24 but I had to really fight with the dealership to accept it. When I first reported the issue to the service tech I told them that the breaks were squeaking when backing up and when coming to stops periodically. The service tech wrote down the wrong description and said that the truck was shimmying. Basically my local dealership was not going to replace because they claimed that I said shimmy and not squeak so that's why they didn't bother to look up the TSB.
    Luckily the original service tech that checked me in told the service manager that they had entered the wrong description and that I did say squeak and not shimmy. They made it right in the end but it was a fight.
    If your breaks are squeaking when coming to a stop or backing up, make sure to use the following TSB and tell them that they are Squeaking or Squealing. Those are the magic words. The TSB covers your breaks up to 3 years or 36K.
  6. Nov 5, 2024 at 10:57 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    My dealer had no problem with my description and after a tech verified the squeaking they ordered the kit and are replacing everything next Thursday.
    I had the fuel line recall done and mentioned the brakes.
    Having the TSB printed out and on the passenger seat may have helped. :)
    AZBoatHauler likes this.
  7. Nov 14, 2024 at 7:01 AM
    daverxa
    daverxa New Member
    Dave
    2024 White Tundra Limited TRD Offroad & TRD Lift
    Leer 100xl, ggoffroad DRV camera relocation, Decked drawer system, BF Goodrich TKO3 275/65R20, Diode Dynamics Fog lights, Go Rhino Dominator D6 Running Boards,
    Did this fix the squeal? My dealer said Toyota stopped replacing because it wasn't fixing the squeal and they are looking at other options.
  8. Nov 14, 2024 at 7:05 AM
    Timmy23
    Timmy23 New Member
    OR
    None
    I’ll find out later today, shop appointment is today in about an hour.
    daverxa[QUOTED] likes this.
  9. Nov 14, 2024 at 7:52 AM
    RayRay27
    RayRay27 New Member
    Mile High City
    2023 SR5
    Stock
    I would dispute this with your dealership. This is an active open TSB that affects 2022-2024 model Tundras. If they are refusing to repair or replace then you may need to take it to another dealership.
  10. Nov 14, 2024 at 5:03 PM
    Timmy23
    Timmy23 New Member
    OR
    None
    Picked up my truck and didn’t notice any squeaky brakes driving home.
    I’ll see how it is in the morning which is when it usually did it.
    Saw what they charge Toyota for the job, about $850 or so!
    This is my invoice. Glad it isn’t what they would charge to have done off warranty…
  11. Nov 15, 2024 at 6:07 PM
    Timmy23
    Timmy23 New Member
    OR
    None
    Drove around today and no squeaky brakes! :)
    Kap1 and Tundrastruck91 like this.
  12. Dec 29, 2024 at 12:14 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Went and had them check my squeaky brakes the end of Nov, talked to the Part Manager and got this back, looks like they have 1958 Pad Kits on back order.image.png
  13. Feb 17, 2025 at 5:25 PM
    jb trd
    jb trd New Member
    22 Tundra CrewMax Limited 6.5
    Update. I installed new front rotors only at 20k. with factory rotors from Sparks. Reused the pads as they looked good. The rotors are now at 39k miles no shuddering super smooth. I haven't used the adaptive cruise as much the last 20k miles. I'll use it but not in traffic, more in open road situations like regular cruise. I swear going down a hill instead of coasting adaptive will brake to maintain speed but I havn't had anyone follow me to confirm. Everything else the same. Either adaptive cruise is partially at fault for over braking or else the original rotors were lower quality.
  14. Feb 17, 2025 at 6:45 PM
    PickupMan2008
    PickupMan2008 Gladys Knight Industries Two Thousand
    Quentin
    Orange City, FL
    2008 Black Double Cab 4x4 5.7
    Cover King seat covers, weathertech rain guards and floor mats NFab Light Bar w/ KC Lights 2010 Limited Grill mod topper bedrug Amazon tailgate handle with rear backup camera still working on mods
    Does Sparks still have a discount code? I need to order some stuff, but couldn't locate anything.
  15. Feb 18, 2025 at 6:48 AM
    HerdManager
    HerdManager New Member
    Stephen
    2023 Limited Hybrid Crewmax
    I feel like this is solely a driving habit thing. I get over 100k miles out of brakes, regardless of the vehicle. Dudes need to learn to coast......if you are always on the gas or brake you are going to destroy your vehicle. And I tow quite a bit.
    Raven67 likes this.
  16. Feb 18, 2025 at 6:52 AM
    sudobash
    sudobash New Member
    As an FYI, T-SB-0043-24 is now OBSOLETE and T-SB-0022-25 has replaced it. The only change is that the 2025 model year is now included.
    Kap1 likes this.
  17. Feb 18, 2025 at 9:31 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I only got 20k miles but my Toyota shop says that rear brake pads are almost gone and need replacing. I do use self driving once in a while.. Maybe couple times a month on the highway.
    I drive pretty mellow and don't brake hard at all.. So this may some sort of defect that rear pads need to be replaced, and not front pads which usually the ones to go first because they work harder.
    Doesn't seem to matter if trying to be light on the brakes. Oh and your truck is hybrid so your brakes will be saved by the regeneration system
