Steering rack failing?
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Sep 15, 2020.
  1. Sep 15, 2020 at 9:55 AM
    KNABORES [OP] Sarcasm incoming
    Getting a clunk when turning right and braking or releasing the brake while turning right. Front end is essentially new within the last 15k miles. All bushings including the steering rack and shocks are new. Wheels off the ground, left front tire is solid, right front tire has a little clunking play side to side, but solid up and down. Visual inspection with inner tie rod boot removed shows no play in the inner or outer tie rods, but the steering rack shaft clunking in and out. Is the rack shot? I'ts the original with 255k or so miles on it. I've done a complete fluid flush on it once and keep it topped off. I doubt it, but is there any kind of adjustment for this play on the right side of the steering rack? Thanks in advance.
  2. Sep 15, 2020 at 10:46 AM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    I just had a lot of front end work done and mine is doing the same thing. I took it back to the shop and they couldn't figure it out, so they said. Curious to find out if anyone knows anything to check
  3. Sep 15, 2020 at 10:58 AM
    Lots of things to check. Tie rod ends, sway bar end links and frame bushings. Steering rack bushings. Upper and lower ball joints. Strut mounts and bushings. Upper and lower control arm bushings. Wheel bearings etc. All of mine seem to be fine on inspection, I can actually see the piston arm that comes out of the Steering rack clunking in and out when I rock the wheel side to side. Curious if that means it's toast.
  4. Sep 15, 2020 at 11:06 AM
    bmf4069 Captain wtf
    Sure sounds like it to me. I'd check your sway bar links too, but I'm betting on the rack too.
    Weagle and N84434 like this.
  5. Sep 16, 2020 at 8:50 AM
    I guess my other question is, if the rack is failing, has anyone had similar symptoms prior to the fail? what did the fail look like? Just gradual decline, but continued function? total loss of power steering? The clunk, while it bothers me, I can live with if that's all it is. I'll replace it eventually.
  6. Sep 16, 2020 at 11:17 AM
    bmf4069 Captain wtf
    You might pull the boots back and take a peek while someone else turns the wheel. Maybe something between the inner and outer came loose.
  7. Sep 16, 2020 at 12:11 PM
    I had the boot pulled back during inspection. Appears the right side has a clunk internally when the passenger wheel is rocked left to right. you can see the shaft clunking in and out slightly with movement. Inner and outer all look good with no play in them. Appears to be inside the rack..
  8. Sep 17, 2020 at 5:49 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  9. Sep 17, 2020 at 6:29 AM
    Thanks, I'll check that as well. Just curious if anyone else had observed the same clunking in the rack prior to failure and what the failure ended up looking like.
    Weagle likes this.
  10. Sep 20, 2020 at 11:29 AM
    Cacoleman2014
    Louisiana
    Mine was leaking and I used some of the Bars stop leak. The 2 part kind. Put in a quarter of the bottle and it stopped leaking pretty quickly and it seems the noise is not near as oft but it is still present. Had sway bar bush, inner tie rod ends and ball joints replaced
  11. Apr 1, 2024 at 4:01 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Had the same thing happen to me today. I was pulling into a driveway and the steering made a clunking noise and the steering got very stiff when turning the wheel to the right. I was a full lock or close to it and steering was hard to turn both ways after that, it then popped again and everything went back to normal. This happen at very low speeds while parking, truck is 2wd on the original steering rack 210K only outer tie rods have been replaced. I haven't jacked it up yet to check, just did a visual inspection and nothing is leaking, my inner tie rod boots are torn at the bottom. The fluid is probably original, I haven’t changed it.
    I checked the trans crossmember to make sure all the screws were there, since iv read that can be a clunking issue. Im thinking its the steering rack might be on its final days or can it be just the inner tie rods being old or a rock got in there?
  12. Oct 15, 2024 at 9:23 AM
    Super long term follow up here, clunking and poor steering performance solved by replacing the mounting bushings and the lower ball joints. Nothing seem to be wrong with the rack at all. Steers like new.
  13. Oct 15, 2024 at 9:47 AM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    Which mounting bushings? In the OP, you mentioned the rack bushings were newly replaced. Did you redo them as well as the LBJs?
  14. Oct 15, 2024 at 12:25 PM
    My then newish mounting bushings were completely shot by the time I replaced my LBJs. They were energy suspension black ones I believe.
  15. Oct 16, 2024 at 8:56 AM
    If I ever get around to doing mine, I honestly think I'm going w/OEM rubber. I think with a lifted truck, it's probably a bit too much torsion for a poly bushing to survive for much more than a couple years
  16. Oct 17, 2024 at 10:04 AM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
    @KNABORES:
    in conclusion, which was more likely causing the symptons that got your attention?
    St Rack bushings or LBJs?
    Just want to make a mental note on the issue.
    Thx for posting thr thread
    tried to edit.
    Not sure where the 'strike-thru-text' button is....
  17. Oct 17, 2024 at 11:34 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Edit: should have read the entire thread first
    Mine didnt fail but I did a preemptive replacement since most everything else on the front end was new. Never had a clunk but was amazed how much tighter the new steering rack is. Inner TRE's may have been a factor? Didnt inspect them to see how they connnect to the rack
    Kinda glad I didn't just buy a rebuild kit and replace the seals. Still may do that on my old one and examine the inside.
    2nd edit: was probably just the bushings on mine as well. I mean it isnt like that worm gear has constant wear like a shock, u-joint etc. if it is worn it would most likely be near the most used area in the middle
  18. Oct 17, 2024 at 12:54 PM
    ps8820
    ps8820 New Member
    joe
    If referring to my post [#16], please enlighten me, since I may have missed his essential meaning after reading entire thread and b4 my post...thx.
    Weagle[QUOTED] likes this.
  19. Oct 17, 2024 at 1:32 PM
    Weagle
    Prattville, AL
    I was referring to the OP's post.
    specifically the part about the play in the steering wheel. It had nothing to do with wear on the internal worm gear. When I replaced mine, I noticed how much tighter my steering was and I attributed that to the worm gear, which was surprising cause you wouldn't think it would wear that much
    Well he replaced his bushings and that took care of the play so I'm almost positive when I replaced my steering rack and put new bushings on it was the bushings that eliminated the play in the steering
    I really doubt you could feel play from the LBJ's being worn
    There are different tests for LBJ's but if you've got over 120-140K or so I would replace them.
    But There are better experts in this forum than myself
  20. Oct 17, 2024 at 1:54 PM
    ps8820
    ps8820 New Member
    joe
    OH.
    Yeah, reason I ask is b/c i just replaced LBJs and Rack bushings [all Toyota] and some other frt suspension...
    My 06 AC SR5 w/174k feels like a very minor 'thud-like' sound when at stop, in drive and when brake pedal releases; its extremely minor and may have more to do w/brakes, but the steer rack is orig w/out any obvious issues [other than 174k mi's]. The new rack bushings probly stopped any movements other than rack-screw/piston travel?
    Havent studied the Rack drawings w/cross section illustration of internals- hoping not to need to.
    I tend to be hyper-sensitive to drive sounds and behaviors, especially since I did lose a Drvr wheel LBJ in a 01 Taco; survived that mainly because failure came at end of 40 mi frwy drive and at less than 5mph, during a rt turn in business street. Also no damage otherwise and truck gave me another 15k mi's b4 I sold it in Aug. Only symptom there was a slightly more stiff steering and slow to return to ctr position of steering wheel. I wrote it off as being a "dying steering rack..i'll get to it in acouple weeks"...
  21. Oct 17, 2024 at 2:02 PM
    Weagle
    Prattville, AL
    Judging from what I've read on this forum so far, I think most failures on the steering rack are either the bushings, which is not the rack at all, or they start to leak. in retrospect I would've simply put some AT205 in mine in the PS fluid for the seeping/slow leak and changed the bushings and been good to go
  22. Oct 17, 2024 at 2:24 PM
    Lower. Ball. Joints.
    Weagle likes this.
  23. Oct 17, 2024 at 2:49 PM
    Weagle
    Prattville, AL
    Yeah I should be more careful in my replies
    just to clarify, I was not talking about the clunk. I was talking about the play in the steering
    that's good to know about the LBJ's, but I'll be replacing mine much much sooner than 300,000 miles like I did last time. I was living on the edge
  24. Oct 17, 2024 at 4:03 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Just for clarity- Are you refering to outer TRE bushing to "REAR LBJ" bushing as pictured below on right side? Screenshot_20241017_190106_Gallery.jpg
  25. Oct 17, 2024 at 4:07 PM
    Referring to the 3 steering rack bushing points and both LBJs.
    Weagle and BluegrapeVr6[QUOTED] like this.
  26. Oct 17, 2024 at 5:48 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    I think racks get a bad rap. Bushings and fluids are bigger problems. No one changes the fluid properly. The varnish fucks everything. Belt and tencion is cheap. Flush the fluids. Sea foam trans cleaner busts the clogs. at-205 refreshes the seals. there is a way. There is a pessure valve in the pump that varnishes. 200k fluids block that flow. New fluids will clean it. LBJ etc is a seperate issue, clean your steering lines.
    Weagle likes this.
  27. Oct 17, 2024 at 8:04 PM
    ps8820
    ps8820 New Member
    joe
    Weagle likes this.
  28. Oct 20, 2024 at 7:52 PM
    10 blue trucks
    04 4WD RCLB
    Good luck with that. I pumped a bunch of new fluid , a bunch of seafoam trans tune, and some at-205. I cant say it will work for everyone. but I think first gen fluids are mostly original and neglected. I could have removed and cleaned the pump, but it seemed to be too much work. Mechanics wanted tons of cash, to replace parts. I flushed , it steers normal now. b ut it wasn't fast. I think mostly the pump valves clog, but its just a theory. good luck.
    Weagle and shifty` like this.
  29. Oct 22, 2024 at 8:06 AM
    Weagle
    Prattville, AL
    I'm glad I bought a new third-party rack instead of a third-party where you had to return your core. Now I'm just going to get a rebuild kit (seals and o-rings) and I have full confidence mine will be good as new when I need it and just slap it on with new bushings
  30. Jan 30, 2025 at 7:20 AM
    TenderTundie
    TenderTundie New Member
    2001 SR5 4.7L V8 4WD
    Interesting thread!
    I am having the same issue as the OP. Clunk from the front end while hitting bumps at low speed while turning. Side-to-side play in the both front wheels with truck in the air. When I remove the steering rack bellows and have a helper grab the tire to rock it back and forth I can visually see no play in tie rod ends, but can see the ~1" shiny metal shaft that comes out of the steering rack clunk up and down or side to side within the steering rack body.
    Steering rack bushings do not move at all when having a helper turn the wheel side-to-side with tires on the ground.
    Steering feels fine to me, but the clunk and play in the front wheels have me worried! Is this a "rack going bad" and I need to replace the whole rack? I hope not. Is it a dangerous failure like OP asked about?
    There seems to be a lot of confusion around this issue, I suppose because there are so many things in the front end that can cause a clunk like that. But if I'm understanding right, OP and I are both experiencing this specific issue of the steering rack shaft clunking around within the rack. Not the steering shaft that goes up the the steering wheel, but the shaft that connects to the inner TREs.
    I did research the "steering rack guide" which allows one to adjust play in the rack shaft by tightening or loosening an adjustment on the drivers side. For me, this took up a little slop in the steering feel, but did not fix the clunk/play. See photos:
    Here's the adjustment, with marks showing the small amount I tightened:
    Here's what it looked like opened up. When grabbing the tire and shaking you could see that shiny shaft in the center move up/down and side/side:
    And here are the four parts that make up the rack guide adjustment:
    So, OP, there's your adjustment, although it's on the L side, not the R side, it should affect the whole setup.
    However, I'm having the same issue as OP and adjusting that 24 year old rack guide did not fix it! I called Ourisman, and they say the part is discontinued. They actually said, "no chance of replacing it unless the Tundra forum guys have figured out a part number that works - if there is one they'll find it!!" Lol!
    So some of OPs questions remain:
    • Is the rack shot, or is there a part # for a new Rack Guide to try replacing?
    • Is it a dangerous failure, or OK to just tolerate the clunk and wheel play?
    • If rack needs replacement, anyone have success with a yota reman?
    Thanks everybody.
    Jack McCarthy and Dook55 like this.
