  1. Oct 8, 2024 at 6:33 PM
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    you might be able to find what you need on t2's crackhead build thread. Maybe whodatchrome also played with the actuators.
    Does this work?
    chrome://external-file/4WD%202UZ%20FE.pdf
    FiatRunner[QUOTED] likes this.
  2. Oct 8, 2024 at 6:39 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Do you have the factory service manual (FSM)? It is covered there with pretty much everything you need to know except what size wrenches you use. The torque specs are in there as well for when you put everything back together. The SST in the third diagram can be ordered as a "Pitman arm puller" from the parts store.
    Links to the FSM can be found in Shifty's megathread:
  3. Oct 8, 2024 at 7:13 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I only carry liability as well, but this was damage from a Tornado which was covered. I like to keep "glass" coverage with $0 deductible too. I think that is like $8 a month or something.
  4. Oct 8, 2024 at 7:16 PM
    Neo
    Neo New Member
    Alabama
    Thanks! Yep, I've got the electronic copy from the megathread and my dad has a hard copy for his 2003. The parts seem relatively inexpensive. On a scale of 1 - 5, how difficult is the job?
    des2mtn[QUOTED] likes this.
  5. Oct 8, 2024 at 7:18 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, hope no one ever pisses off @JakeJake right? :rofl::welder:
  6. Oct 8, 2024 at 7:19 PM
    des2mtn
    SW
    Tonto cover
    I'm not good at assigning numbers, but if you can change your brake pads and rotors, you should be able to do this job.
  7. Oct 8, 2024 at 7:21 PM
    Neo
    Neo New Member
    Alabama
    Yep, again. I just replaced the front pads and rotors last month. Thanks.
  8. Oct 8, 2024 at 7:31 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  9. Oct 8, 2024 at 8:39 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    How is grandma shrinking my shirts? When i do laundry everything fits as expected, but when grandma does it they shrink. No, i'm not making her, she does a load of laundry every day, and sometimes i throw my stuff in as 'filler', but i've gotta pull my shirts down & the arms & shoulders are noticeably smaller. Is the dryer too hot? I noticed the vent duct isnt optimum. My stuff is electric, her dryer is gas.
    455h0le_dachshund, BroHon and bmf4069 like this.
  10. Oct 8, 2024 at 8:40 PM
    Always dry on low heat or just hang them outside.
    JakeJake likes this.
  11. Oct 8, 2024 at 8:43 PM
    Oh, and always dry with like items in weight. If you dry a shirt with jeans, the shirt will be bone dry and shrink before the jeans are nearly dry.
  12. Oct 8, 2024 at 8:44 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, i bet its too hot. Noticed i dont catch as much lint, too. Might not be enough airflow.
    she also uses dryer sheets, that effed up the auto dry sensor on her last dryer, but shes set in her ways. I scrape off the sensor every time i show up.
    BroHon likes this.
  13. Oct 8, 2024 at 8:46 PM
    I wash everything together. Dry it all together on high. I hang the shirts up then just dig through the rest for the week. Bachelor life. My gf makes fun of me for it.
  14. Oct 8, 2024 at 8:50 PM
    You can get away with that if most of your clothes are poly blends. I go for pure cotton myself. It’s getting harder to find though.
    BroHon likes this.
  15. Oct 8, 2024 at 8:52 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I do laundry batches, and the normal setting is fine. 1 offbrand tide pod (that tastes like snozberries) and i just have piles of halfassed folded clothes, and wear the top stiff first... she has special dark detergents, a seperate load for coloreds, and oxyclean bleach pods (that taste terrible) for the whites. Some of her clothes get pulled & hung after 37 minutes. I get it, shes turned it into a hobby, but if i mess with it, itll probably ruin her day.
    BroHon, Jack McCarthy and bmf4069 like this.
  16. Oct 8, 2024 at 8:53 PM
    Uhhhh, the shirts are made out of shirts. I think the pants are made out of jeans. The socks are for sure made out of socks. I'm not sure what the unders are made out of. I need to replace them. Some are turning into skirts.
  17. Oct 8, 2024 at 8:53 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    How does one get a thread stickied?
  18. Oct 8, 2024 at 8:55 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Groveling & sacrifice.
  19. Oct 8, 2024 at 8:57 PM
    First a committee must be formed
  20. Oct 8, 2024 at 8:58 PM
    Asking a mod. I don’t know if it has to be someone other than the author though.
  21. Oct 8, 2024 at 8:58 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Seconded & witnessed.
  22. Oct 8, 2024 at 8:58 PM
    Dammmit. I forgot the rules! @Outbound !
    Outbound, bmf4069, BroHon and 3 others like this.
  23. Oct 8, 2024 at 9:09 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    But before that we need a poll to select committee members.
  24. Oct 8, 2024 at 9:34 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    All the elders have 5k posts.
  25. Oct 9, 2024 at 3:11 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Hahaha... I live this shit bruh, it's fkn ridiculous... o_O:rofl:
    (We need a pre meeting warmer to decide who designs the poll and the proper color sceme so no one is triggered) etc... etc... :facepalm:
    bmf4069 and 455h0le_dachshund like this.
  26. Oct 9, 2024 at 3:13 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Sounds like Grandma's feeding ya good.
    bmf4069 and BroHon like this.
  27. Oct 9, 2024 at 3:15 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    This is the way.
  28. Oct 9, 2024 at 4:11 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    So today was a little cooler morning, 38. When I started my beast it kinda barked at me.
    For a while the exhaust note (drivers side) has been what I would call gravely/growly.
    I haven't reached up around the cat or dump to feel for holes... partly because it doesn't sound like an exhaust leak typically does.
    Only thing I've done there has been a hose clamp on the heat shield, which is still goodntight.
    Just throwing this out there... in case I need to start pawning shit to pay for a new cat :rofl:
    EDIT: I'm betting ECU read temp and gave a little more fuel than it has been. It was kind if a pop.
  29. Oct 9, 2024 at 5:25 AM
    Outbound
    Aaron
    Northern Alberta
    I agree to chair the committee to send the request to the review board.
  30. Oct 9, 2024 at 5:28 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    The issue of shrinking cotton clothes depends on the brand and the cloth itself. I buy Carhartts medium shirts and they fit when new, I dry them in the gas dryer and they still fit. I buy large Wrangler flannel shirts, dry them a couple times and they're too small. But if I buy large Wrangler denim shirts and dry them, they still fit. It costs a lot of money to learn this.
    bmf4069 likes this.
