1st Gen 4WD Issues Diagnosis/Prevention Guide
Discussion in '1st Gen Tundras (2000-2006)' started by FiatRunner, Oct 8, 2024.
  1. Oct 8, 2024 at 4:38 PM
    FiatRunner
    FiatRunner [OP] 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    This guide is intended to help diagnose and fix 95+% of 4WD issues, on V8/auto trucks. If this thread doesn’t help you much, or you have feedback on the guide, let me know. I'll continue to update and improve this guide as needed. Very open to feedback. Thanks!
    STEP 1: UNDERSTANDING YOUR 4WD SYSTEM
    The 4WD systems on our trucks consist of five main systems. Understanding how these systems work individually and with each other is key to diagnosing accurately. These systems include:
    • 4WD switches on dashboard
    • 4WD computer control unit
    • Transfer case shift actuator
    • Front differential shift actuator
    • Transfer case shift position switches
    Dashboard Switches
    The switches on the dashboard of the truck are pretty simple and are not frequently the cause of 4WD problems. The 4HI switch can be pressed anytime as long as the vehicle is traveling straight, on level ground, and is at a speed below 55 mph. The 4LO switch can be pressed when the truck is already in 4HI, stopped, in neutral, and without the wheels turned.
    4WD Control Computer
    Often referred to as the “4WD ECU” the 4WD computer is located on the right side of the passenger footwell, underneath the plastic kick panel. (see image HERE) This computer takes information from the dashboard switch, both shift actuators, and position switches to determine what is happening and what action needs to happen. This computer also houses the relays, which can be heard clicking when a 4WD shift is prompted.
    4WD computer failures are not common but have happened in the past.
    Transfer Case Shift Actuator
    The transfer case shift actuator is located on the rearward side of the transfer case. (see image HERE) It’s job is to shift the transfer case between 2WD HI, 4WD HI, and 4WD LO. It receives signals from the 4WD computer to shift between the three aforementioned positions. Unlike the Front Differential Actuator, there are no internal position switches. It is what engages and disengages the front driveshaft, which goes between the transfer case and front differential. The actuator itself consists of a small electric motor and a set of reduction gears. These gears move a shift selector shaft in and out of the transfer case, which controls the components inside. The actuator also features a spring mechanism that allows the gears inside the actuator to turn even if the shift selector shaft cannot move. The spring mechanism maintains tension on the selector shaft, ensuring that a proper shift is accomplished once the selector shaft is able to move. The ADD actuator also features a similar mechanism.
    4WD failures often are due to a faulty transfer case actuator.
    Front Differential Shift Actuator (ADD)
    The Front Differential Shift Actuator’s official name is the Automatic Disconnecting Differential, or ADD for short. For this guide I will be using the term ADD. The ADD is located on the back of the front differential, on the passenger side. See photo HERE. It’s job is to connect and disconnect the front wheels to the front differential by moving a collar back and forth to engage a splined shaft, which connects the two front wheels together. On the inside of the ADD actuator, there are metal contacts that complete circuits when the actuator is in one position or another. This tells the 4WD computer what position the actuator is in. The actuator itself consists of a small electric motor which turns a set of reduction gears. As mentioned above, the actuator also features a spring mechanism, which allows the actuator to move, even when a shift cannot be accomplished. This mechanism holds tension on the splines between the differential and axle, ensuring that a shift is accomplished once the splines are lined up. Having the front wheels disconnected from the front differential during normal 2WD operation can increase fuel mileage and reduce wear on components.
    ADD failures are common, just like the transfer case actuator.
    Transfer Case Shift Position Switches
    The transfer case shift position switches are attached to the top/rear of the transfer case actuator. These are simple switches that complete or disconnect circuits, in order to tell the 4WD computer what position the transfer case is in.
    Shift Position Switches failures are not common.
    STEP 2: DIAGNOSING YOUR 4WD ISSUE
    Typically, 4WD issues boil down to one of two things: being stuck in 2WD, or being stuck in 4WD. It’s easy to tell when one of these things is happening.
    Stuck in 2WD
    Being stuck in 2WD can be easy to see. The truck should drive totally normally, with smooth turns, braking, acceleration, etc. On dirt or gravel, you should be able to spin at least one of the rear tires with a stomp on the gas pedal. Another dead giveaway- the 4HI light flashes when the button is pressed.
    Stuck in 4WD
    This situation is a bit more unfortunate than being stuck in 2WD. Again, it’s often easy to tell when 4WD is stuck on. If the 4HI light on the dashboard wasn’t enough of a sign, the bucking, hopping, or tire chirping around turns should be.
    First Steps Of Diagnosis
    The first part to diagnosing your 4WD issue is understanding what is happening, and what should be happening. This can be one of the most straightforward ways to determine what part is broken or acting up.
    Things to check first
    • Ensure 4WD fuse (in dashboard) is good
    • Make sure both actuators and position switches are plugged in tightly, and that wires aren’t burnt/melted/chewed/torn
    What should happen in 2WD
    • The front driveshaft should spin freely by hand
    • When spinning one of the front wheels, only that wheel should turn.
    • No lights on the dashboard
    What should happen in 4WD
    • Front driveshaft should be locked, unable to turn
    • Both wheels should spin when one is spun.
    • 4HI or 4LO light on dashboard is on
    After testing these criteria, you can use the process of elimination to determine what is and isn’t working as it should.
    When to suspect a shift actuator
    A faulty shift actuator is often the first thing to be suspected. Failures among shift actuators are the most common culprit when it comes to 4WD issues. If your truck isn’t known for electrical issues, the shift actuators should be the first culprit.
    It is possible to “bench test” the ADD actuator. This process is outlined at the bottom of this guide, in the “tips, tricks, and links”. This can further confirm that a part is/isn’t working properly.
    When to suspect the position switches
    Although significantly less common, the transfer case position switches can fail. Since they are less common, replacing the position switches is not advised until both the transfer case actuator and ADD have been replaced with good new parts, or confirmed to work reliably.
    One giveaway that the position switches are bad is if the transfer case shifts fine, but the ADD does not shift, even with a new ADD actuator. This is because the 4WD computer will not shift the ADD until it can confirm that the transfer case has successfully shifted. Since it cannot tell what position the transfer case is in, it will not shift the ADD.
    When to suspect the 4WD computer
    It is hard to specifically say “this is when the 4WD computer is bad”, as there have been only a handful of cases on here where replacing the computer has solved the problem. I personally would be hesitant to replace the 4WD computer unless both actuators and position switches have been confirmed to be good.
    However, if your truck has a history of significant corrosion or has had issues with water leaks in the past, check the computer and it’s wires for corrosion.
    The above information in theory will fix your 4WD issue. If you are still having issues, please let me (@FiatRunner) know so I can help!
    STEP 3: PURCHASING THE CORRECT PARTS
    Purchasing the correct part can be key to ensuring consistent and reliable 4WD operation for years to come. I, including others, strongly recommend only using OEM parts. Non-OEM parts, while cheaper, are never as long lasting, and sometimes simply don’t work.
    Listed below are the part numbers for the correct shift actuators and position switches.
    ADD Shift Actuator:
    41400-34013
    Transfer Case Shift Actuator:
    36410-34015
    Transfer Case Position Switches:
    84222-12010
    When ordering these parts, make sure to purchase from a reliable source. Buying parts from Amazon or ebay is not advised. There are thousands of counterfeit products on those websites, which are nowhere near the same quality as OEM parts.
    If you need help purchasing the correct part using Toyota’s part lookup system, check out this guide: https://www.tundras.com/threads/howto-use-the-toyota-parts-system-to-find-order-parts.113808/
    STEP 4: REPLACING/FIXING YOUR BROKEN PART
    Once you’ve determined what part is faulty or acting up, you can often go one of two routes:
    1. Attempt to disassemble your part and fix it
    2. Replace the part
    Attempting to fix your actuator
    Some members have been successful in removing the plastic covers on the actuators, and cleaning/removing corrosion on the inside. Do this at your own risk! Removing the plastic covers also comes with the risk of mis-timing the gears on the inside. This can unsync your two actuators and confuse your 4WD computer, but it’s still possible. Videos explaining the process are linked below.
    https://www.youtube.com/watch?v=3TqnZqi4Iw4&t=939s
    https://www.youtube.com/watch?v=TmuEVv1neVQ
    Front Actuator Replacement
    https://www.youtube.com/watch?v=ePU4x8cLdg8&t=598s
    Transfer Case Actuator Replacement
    https://www.youtube.com/watch?v=Bux-qK3Ze-A
    STEP 5: PREVENTING FUTURE 4WD ISSUES
    The fragility of our 4WD systems is due to the fact that one malfunctioning component causes the entire system to stop working. Everything must be in tip-top shape to work reliably. Thankfully, preventing future issues can be very easy and simple.
    Shift Actuator Vent Hoses
    One of the most common causes of corrosion inside of the 4WD actuators, both Transfer Case and ADD, is due to the vent hose dry rotting, cracking from age, or becoming dislodged. On both the transfer case and ADD actuators, there is a small nipple protruding from the plastic covers. This attaches to a small rubber hose, which acts as a vent. When this hose becomes cracked or damaged with age, water/salt/dirt/etc can get inside of your actuator and corrode the metal contacts and motor components. Checking to ensure your vent hose is properly attached can be crucial to actuator survival.
    Use Your 4WD!!!!!!!!!!!
    The other (and most common) reason for 4WD failure is from a lack of use. Parts get stuck, corroded, seized with age and lack of use. It is recommended to drive in 4WD for a handful of miles every month to properly lubricate and heat cycle the 4WD components. However, don’t just throw it into 4WD at any time. If you’re not in a low-traction situation, (e.g. rain, snow, dirt/gravel) only drive in a straight line. Turning on dry pavement with 4WD engaged will put excessive force and strain on driveline components, which can damage them. I like to cycle my 4WD in and out a few times, why not?
    TIPS, TRICKS, AND LINKS
    FIPG
    Form-In-Place-Gasket is Toyota’s gasket maker. Yes, it’s worth it. It’s better. Be sure to use it when attaching your ADD actuator. Part #00295-00103
    Both 4HI and 4LO lights flashing all the time
    The 4WD computer is recognizing that the transfer case actuator is not plugged in.
    Bench testing ADD actuator
    The front ADD actuator can be bench tested using a 12v power supply. Connect wires to pins 1 and 5 of the electrical connector. Apply voltage. To reverse actuator direction, swap wire polarity. If the actuator is working correctly, the actuator should move back and forth quickly and easily. Be careful not to hold the wires on for too long, I'm sure it's easy to fry the connections inside.
    Not working? You might be viewing the connector from the wrong side. Ensure that the connector’s lock tab is facing upwards and you are counting left to right. See photo HERE. Also check the wiring diagram linked below to confirm wire colors.
    4WD wiring diagrams
    4WD 2UZ FE (1).pdf
    Video Showing How ADD Works:
    (Start at 4:00)
    https://www.youtube.com/watch?v=rnS4bgFhWCM&t=296s
    gzip, Voss, The Black Mamba and 13 others like this.
  2. Oct 8, 2024 at 5:05 PM
    Great write up! Should be a sticky.
  3. Oct 8, 2024 at 6:13 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Nicely done. Definitely needs to be a sticky.
    w666, FrenchToasty and FiatRunner[OP] like this.
  4. Oct 8, 2024 at 6:55 PM
    shifty` Oh, I have felt Cobain's sarcoma
    I’ll link it in the Megathread in a bit!
    w666, Schcoman, FrenchToasty and 2 others like this.
  5. Oct 8, 2024 at 8:50 PM
    FiatRunner
    Jack
    4WD Photo Dump
    Location of 4WD control computer (w/ labels)
    **This is a 2000 model year truck, yours might looks a bit different under here, but the ECU is in the same spot.
    Location of transfer case actuator, also shows location of position switches
    Transfer case actuator with plastic cover removed
    ADD actuator with cover removed
    ADD actuator showing shift fork
    ADD actuator showing electrical connector pin numbers
    Voss, w666, Teutonics and 4 others like this.
  6. Oct 9, 2024 at 2:56 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Amazing write up. Fantastic job.
    FiatRunner[OP] likes this.
  7. Oct 9, 2024 at 7:41 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    @FiatRunner what you're doing here is SO valuable! I really appreciate you taking the time. I plan on keeping my 4x4 1st Gen for the rest of my life, and having great references for repair is essential to that goal. Great work!
  8. Oct 9, 2024 at 7:45 AM
    FiatRunner
    Jack
    Thank you! Fixing my own 4WD was a huge debacle and so many times I’ve thought to myself “why don’t we have a guide for this?”
    w666 likes this.
  9. Nov 30, 2024 at 2:27 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    FiatRunner[OP] and ColoradoTJ like this.
  10. Nov 30, 2024 at 4:25 AM
    Done. Great suggestion.
    FiatRunner[OP] and shifty` like this.
  11. Nov 30, 2024 at 4:58 AM
    w666
    Maryland
    Yay!
  12. Nov 30, 2024 at 1:02 PM
    FiatRunner
    Jack
    Thanks guys!
  13. Dec 2, 2024 at 5:11 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    @FiatRunner
    3 positions of the TC shaft.
    (With the actuator pulled by removing the small gear)
    Fully out =?
    Middle =?
    Fully in =?
    Not going to mess with it now that winter set in here, but I have the blinky 4lo/won't go into 4lo issue.
    A greater part of me feels like this could end up spiraling/breaking something... when 4hi would have been good enough. But if I ever want to seriously "wheel" this thing, plow, or pull some stumps (do stupid shit), I'm going to want 4lo.
  14. Dec 2, 2024 at 7:35 AM
    FiatRunner
    Jack
    I honestly can’t remember for sure what the positions are. Don’t want to tell you something that might be wrong, but I think it was:
    Fully out = 2HI
    Middle = 4HI
    Fully in = 4LO
    I think. With the actuator removed, you should be able to manually shift the rod just by pulling it in/out.
    BroHon[QUOTED] likes this.
  15. Dec 2, 2024 at 7:56 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I remember trying that exact thing (moving it by hand and light smacks with a deadblow) and it wouldnt budge... but I was pretty ignorant of ALOT of things back then... like how all these moving parts worked together.
    Knowing what I know now, I would block the whole truck up, put in nutral, and have someone roll a wheel to get things to mesh while I tried to push/pull the shift rod.
    That's what I need to do first to determine if my TC even has the ability to get into 4lo. Like if it's a mechanical issue inside the case, or an actuator problem.
    I think you are right on the positions.
    Thx Fiat :fistbump:
  16. Dec 2, 2024 at 7:59 AM
    FiatRunner
    Jack
    Unless something is really wonky I'd be surprised if it was an issue inside the TC. Mine shifted into 4LO just fine after 10+ years of not being used. Not sure why it would work fine for 2Hi/4HI but not for 4LO.
  17. Dec 2, 2024 at 8:04 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Ahhh haaa... those are words I needed to hear.
    Have read that i just don't have the inner wheel clocked right... has to be on the Very Last tooth on the shaft or something. Supposedly 15min fix :eek::rofl:
  18. Dec 2, 2024 at 8:10 AM
    FiatRunner
    Jack
    Yeah, I remember spending a lot of time getting the inner wheel and the pinion gear clocked correctly. I think you're on the right track- last tooth on the shaft sounds right. If fully out is 2WD and fully in is 4LO, then shouldn't the pinion gear start or end at one side of the shaft?
  19. Dec 2, 2024 at 8:21 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yes. Mirror on a stick required to eyeball it.
  20. Jan 30, 2025 at 12:56 PM
    wstevenb
    wstevenb New Member
    Brandon
    Colorado Front Range, North of Denver
    Green 2000 Tundra Limited, Access Cab, 4.7L V8, 4x4
    2" Lift - Front/Rear, Alcan Leaf Springs, OME Shocks/Struts, 33" tires on Black Rhino wheels, updated front seat upholstery.
    Can the 4WD functionality be tested with the vehicle up on stands, the key in the on position, but the engine not running? Anything that would prevent me from doing that? I've been testing circuits for days and getting some strange readings at the ECU. The rear actuator engages into 4H just fine. The position switches both tested bad and have been replaced. The front actuator has been rebuilt and bench tested. ECU isn't even trying to send power to the front actuator. Wondering if anything would be unhappy that the engine isn't running. I'm not ready to start it yet because of other repair work going on.
  21. Jan 30, 2025 at 1:45 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Have you looked at this, behind the passengers kick panel?
    Check for water intrusion/corrosion on the connections.
    Some people have had water leak in that area.
    Just something to check. (I think this is the applicable year/model 2000-2003 FSM)
    Not sure about complete functionality when the truck isn't running.
    But I do remember testing my front ADD with just the key on and I swear it worked/moved the fork.
  22. Jan 30, 2025 at 2:26 PM
    FiatRunner
    Jack
    I don't believe the engine needs to be on for the 4WD to shift. I've done all my 4WD work with the engine off.
    I have a spare 4WD ECU for a 2000 model year truck that I might be able to send to you to test it out. PM me if you'd like it.
  23. Jan 30, 2025 at 2:30 PM
    wstevenb
    wstevenb New Member
    Brandon
    Hey, thanks for the advice! I have got to the point where I'm testing directly at the ECU now, as you suggested, so thanks for that. This has been a very tough issue to figure out. Everything going to the transfer case actuator seems fine, with the exception of the H2 position switch input voltage seeming a bit low at 10.4V compared to the 4L position switch which tests at system voltage. Did a voltage drop test and found it's the ECU itself providing the 10.4 volts, measured at the ECU harness connector. They both pull to ground when the switches activate though, which I'm thinking should provide a successful detection. I've been taking direct readings by backprobing at the ECU or using an insulation piercing test lead. All the body grounds seem to be fine, measured there at the ground harness by the ECU to the battery negative terminal. I don't see signs of water intrusion, thankfully. My biggest worry is that, based on the power flow diagram, the ECU DL1 and DL2 pins (10 & 23 on the connector) which provide position detection at the front actuator seem like they should be supplying voltage so they can be pulled to ground depending on switch position, but there's nothing there except some voltage flutter close to zero, even with the ADD actuator harness disconnected. I disconnected the ECU end of the harness and ran a resistance check from the wires to body ground to see if maybe there was wire damage grounding them out somewhere, but got nothing. I also thought maybe something was shorted downstream and pulling a lot of current through the ECU, causing voltage drops, but my amp clamp meter was reading well under an amp - maybe in the 40mA range while the controller was idling. I'm getting close to pulling the trigger on a new ECU since those pins don't seem to be behaving normally and I get no relay click for the front actuator. My 4WD has been broken for close to a decade :( which has made this more of a restoration than a troubleshooting, lol. Sooo many things gone wrong while it hasn't been used. At some point in time the ADD wiring harness got disconnected, probably for years, and was dangling down (probably young me trying to fix it at some point). No idea if that could cause something on the ECU to short and cause damage, but that's my working theory. I did replace that section of the wiring harness to be safe, since the female connector end was questionable with oxidation and corrosion. Any suggestions would be appreciated!
  24. May 24, 2025 at 5:24 PM
    Firemedicman
    Firemedicman New Member
    2004 Tundra DC TRD Offroad
    wstevenb:
    I know it has been a few months since your last post but I was wondering if you found a solution to your problem. I am having the same issue that you are having. The only difference is that my front actuator will engage after the truck has had some time to cool down. No front axle engagement when hot, usually after driving for 20 minutes. I also have the same voltage readings as you. At this point I am thinking about adding 12v directly to the actuator after I engage the system. My transfer case engages just fine.
  25. May 24, 2025 at 9:39 PM
    FiatRunner
    Jack
    That’s an odd set of symptoms. Give us some more specifics. Are you sure that the reason it won’t engage is an electrical issue? I would try some identical tests with the truck both cold and hot. Maybe test for voltages when it’s warm? I haven’t heard of a no-shift when hot before.
  26. May 25, 2025 at 5:17 AM
    Tagging @wstevenb properly so maybe he gets notified. I see he hasn’t logged into the forum since Feb 22, a couple months ago now.
  27. May 25, 2025 at 8:31 AM
    Firemedicman
    When the truck has been sitting overnight, the truck will shift into 4x4 without issue. Voltage at the the front diff actuator is 10.8. Voltage at the connector/junction at the main wiring harness under the engine is 10.8. New front actuator. After driving for 10 minutes, truck will not shift into 4x4. 4h light blinking. Transfer case is operational. Front diff will not shift collar. No sound coming from the actuator. Turn the truck off and wait 20-30 minutes and the truck will shift into 4x4 and front actuator is working. Tried another new actuator with same results. I was thinking that one of the internal relays in the 4wd ecu may be bad. I even went driving with the truck in 4x4 for approximately 12 miles, truck stayed in 4x4 until I stopped and turned it off. Turning off the 4x4 worked as it was supposed to by pressing the button. I then immediately pressed the button again to turn the 4x4 back on and all it will do is flash. No corrosion found. I also replace the engine ground to the body. I was wondering if 12v was required at the actuator to operate consistently. If so, then I thought about running a separate power line to the actuator and adding a switch/relay to press after pressing the 4H button.
  28. Jun 3, 2025 at 4:46 PM
    Firemedicman
    Updating.
    I figured out that the actuator on the front axle can be triggered with external voltage. Top pin on the actuator is fed by a green wire, bottom pin is fed by a red wire. With the connector disconnected, apply 12 volts to the top pin, and ground the bottom pin. This will activate the actuator and engage the collar. To disengage, simply reverse the application (changing polarity) and the collar shifts back out of engagement. When the 4wd module is cold (not energized) then when engaging 4wd you can hear 3 clicks and the system engages. After the truck has been running for a short time, I am assuming the circuit board is energized and something stops working. When pressing the swith, only 1 click can be heard. I am assuming these clicks are coming from the internal relays. So I believe that I have a bad module. I did start to rig a go around by applying voltage to the correct pins with a separate relay, but my 1st attempt resulted in some shorting out. Doesn't appear to be any lasting damage as the system still engages when cold. Any one have a spare module for 2004 CC SR5? I can manually activate the collar if necessary but a module is the permanent fix.
  29. Jun 3, 2025 at 6:43 PM
    FiatRunner
    Jack
    Sounds like you’ve got a culprit. I’ve got a spare module for a 2000 model year truck that I’d be willing to send you, but I don’t know if it’ll work on your double cab. I’m on vacation on the moment and I’m not able to confirm if it’ll work or not, but I’ll be home this weekend.
  30. Jun 8, 2025 at 4:10 PM
    Firemedicman
    Thanks for the offer but I need 2003-2005 according to Toyota. I found one on ebay and I am waiting for it to get to me. When it does I will post back if it solves my problem or not so that the information may help others.
