  1. Oct 5, 2024 at 5:34 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Blang blang
  2. Oct 5, 2024 at 5:36 PM
    Autozone is closed sorry
    Sirfive, Filthyphil, BroHon and 5 others like this.
  3. Oct 5, 2024 at 8:05 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    @Baller was nice enough to reference it in his build thread. Here’s the link https://www.tundras.com/threads/tpms-bypass-shut-off-disable.52317/
    I’ve read mixed results about the TPMS light staying off permanently or being temporary off. But it could be worth a shot before doing the wire grounding.
  4. Oct 6, 2024 at 5:44 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Or you could just fix the problem the right way, or the programmatic way and not cut any wires. :rofl:
    NUDRAT and Kimosabe[QUOTED] like this.
  5. Oct 6, 2024 at 6:47 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Lock actuator driver side - should’ve done it a while back.
  6. Oct 6, 2024 at 11:46 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    That’s how I’ll fix the ABS light at least. I’ll add that a wire was tapped, not cut.
    **No wires were harmed in the making of this update. Haha.
  7. Oct 6, 2024 at 12:01 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I managed to get my ditch lights wired up. I had to get a new wire harness because I ripped mine during install. Harness was quite a bit thinner than the previous one. Both from Rigid.
    But, I went to install the button and there was a harness connected to the blank. Has anyone seen this, or know what it could be for?
    oscardog86 and 455h0le_dachshund like this.
  8. Oct 6, 2024 at 12:54 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Might be the elusive dikfer I hear a lot of guys asking about on here.
  9. Oct 6, 2024 at 12:57 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Maybe heated mirrors?
  10. Oct 6, 2024 at 1:53 PM
    It’s for whatever function that button normally is used for. I have an AC or I would tell you. AC and DC are different on that panel. My AC order is different too.
  11. Oct 6, 2024 at 2:23 PM
    What’s a dikf…… oh, gotcha
    BroHon, Kimosabe and FrenchToasty like this.
  12. Oct 6, 2024 at 3:34 PM
    Is that a working switch in place of the blank or is the blank still fixed?
    If the blank is still fixed, what are you using for your ditch lights switch?
  13. Oct 6, 2024 at 4:05 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    That spot is the on/off switch for the side airbags. Dunno what color wires they would be if that's to them.
  14. Oct 6, 2024 at 4:13 PM
    Rear side curtain airbags. Our 4r has that switch, supposedly for high angle off-roading so the bags don’t deploy
    NUDRAT[QUOTED] and Jack McCarthy like this.
  15. Oct 6, 2024 at 4:14 PM
    Toyota lets you turn on and off their side airbags as well? Way to make your passenger behave!
    That makes a lot of sense.
  16. Oct 6, 2024 at 4:20 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I found the same thing to be true in my area as well. I ended up disassembling my lock cylinders and spent about an hour moving the tumblers around (and a bit of filing as well).
    shifty` likes this.
  17. Oct 6, 2024 at 4:34 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Can i unplug my airbag fuse? Passenger side is turned off, but how do i turn off the driver side?
  18. Oct 6, 2024 at 7:17 PM
    Neo
    Neo New Member
    Alabama
    I don't know. I've never had to do this before. I didn't make it to the locksmith Friday, but I'll be sure to post on my experience once I do.
  19. Oct 6, 2024 at 7:42 PM
    Neo
    Neo New Member
    Alabama
    One of my previous sedans was prone to warped front rotors and it didn't help that none of the local shops could even spell "torque spec" when it came to installing wheels. One time after a rotation and balance, I broke a Craftsman socket trying to loosen the lug bolts so that I could re-torque to spec. Best guess is that they had put at least 130 lb-ft on what should have been an 85 lb-ft lug. I had a conversation with the owner at that NTB and they paid for new front rotors. After that, I always drove to my dad's house, put the car on jack stands, removed all 4 wheels, tossed them in back of his truck, and took them in for whatever service they needed. It was a pain in the rear, but they never messed me up like that again.
    ToyotaDude[QUOTED] likes this.
  20. Oct 6, 2024 at 7:42 PM
    PlanoJames
    PlanoJames New Member
    james
    06 Spectra Blue Mica,DC,SR5,4.7L
    ARE Tonneu cover,Nerf bars,Bilsteen 5100s, Power Stop Truck & Tow Front Brake Kit,Weathertech Frt floor liners
    I just installed this cabin air filter mod on my 2006 Tundra DC and it works great. It come with filter medium already but I wanted something a little better so I replaced it with a MERV 8 rated RV vent filter I found on Amazon. I had to trim it as the original is about 4.5 inches and the RV filter is 5.25 inches. I got it from ocd4wd on Instagram. Here's the video on how to install it on YouTube.
    https://www.youtube.com/watch?v=K3wif9u-Vuk
  21. Oct 6, 2024 at 7:50 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Have you checked the foam seals in your ducting? Mine looked like they'd collapesed, even the side i didnt touch. Trimmed down some hvac foam seal tape & added a bent pipe cleaner to fill the gap before & after the ball chiller.
  22. Oct 6, 2024 at 8:03 PM
    Push button start on a first gen Tundra? I don’t recall that.
  23. Oct 6, 2024 at 8:05 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    moms '04 sequoia had bump start, bet an ehrmazhern button could be glued in.
    but could us key holders get it to work as button holders?
  24. Oct 6, 2024 at 8:19 PM
    If it works for a Sequoia, theoretically with the same parts, you should have all you need to put it into a Tundra (unless you need to change the ECU).
  25. Oct 6, 2024 at 9:51 PM
    I think they had to add that button because people were having issues with side airbags randomly going off when people were off-road at extreme off-camber angles.
    455h0le_dachshund likes this.
  26. Oct 7, 2024 at 6:02 AM
    I believe @MrDirtjumper is the one with that setup, using a prox key.
    G_unit3000 likes this.
  27. Oct 7, 2024 at 6:04 AM
    You didn't notice any performance hit? I saw someone (here maybe, on FB maybe?) who took an air meter and found 25-30% less air speed coming out of the vents when measured with an CFM or air velocity meter or whatever. I feel like the airflow from the OEM fan is anemic enough.
  28. Oct 7, 2024 at 6:25 AM
    oscardog86
    oscardog86 New Member
    Southern California
    My AC had the blank button wired up like that. Mine didnt come with the fogs from factory, but I threw a fog switch in there and wired up some aftermarket lights and now I have fogs. Everything is wired up factory, just no fogs included.
  29. Oct 7, 2024 at 8:03 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Both mine have bumpstart, but Dad's 07 Taco doesn't.
  30. Oct 7, 2024 at 8:30 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I am using the blank to put the switch for my ditch lights. I installed the switch and left the wire harness to the side for now.
    That’s what I thought but was hoping maybe it’s for heated mirrors. I’ll check out a EWD and see if I can come up with some answers.
