New (to me) 2005 Tundra, Getting ready to tackle some maintenance!
Discussion in '1st Gen Tundras (2000-2006)' started by squanto, Sep 16, 2024.
  1. Sep 16, 2024 at 7:55 PM
    squanto
    squanto [OP] New Member
    2005 Tundra Double Cab XSP 4WD V8
    Hi everyone! I’m very pleased to have recently become the owner of a 2005 Tundra Double Cab with 260k on the odometer. The truck runs great and has fairly minimal rust, but the dealer and CarFax report only had a very limited service history available. I tried checking the records that were available on Toyota’s website, though the documented history was pretty limited there as well.
    I’ve driven the truck about 200 miles since buying it and it runs and shifts great. I’m getting ready to start replacing a few parts for some peace of mind since I don’t have a lot of history available to me.
    I’ve read through quite a few of the guides and posts here on routine (and preventative) maintenance, and I *think* I’ve got a decent grasp on what to address first.
    There’s no timing belt information or sticker, so my plan is to replace the:
    -timing belt and water pump (with an AISIN TKT-021 kit)
    -serpentine belt
    -belt tensioner
    -idler pulley
    -thermostat and thermostat gasket
    -radiator
    -upper and lower radiator hoses
    I’m also planning on doing a drain and fill of the engine oil, transmission fluid, coolant, rear differential oil, transfer case oil, lubing the driveshaft, and replacing the oil and air filters.
    I’ve seen quite a bit on the lower ball joint failures, so I’m planning on taking care of those as well.
    Is there anything else that I should be addressing while I have it apart to do the timing belt and water pump? Is there any other ‘critical’ maintenance that I’m missing for a well-running Tundra with an otherwise fairly unknown service history?
    Thanks in advance!
    Bmktw2 likes this.
  2. Sep 16, 2024 at 8:46 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Any visible oil leaks ?
    squanto[OP] and bmf4069 like this.
  3. Sep 17, 2024 at 4:38 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Not sure if you added the Amazon link or if the forum did but buy this on Rockauto not Amazon, don't want to get fake parts.
    I'd honestly say order almost everything on your list from Rockauto for the same reason. There's a 5 percent discount code posted in a few places on the forum or you can always Google search for one.
    squanto[QUOTED][OP] and bmf4069 like this.
  4. Sep 17, 2024 at 4:53 AM
    Welcome from NY.
    squanto[OP] likes this.
  5. Sep 17, 2024 at 5:25 AM
    bmf4069 Captain wtf
    A lot of places don't report on maintenance done, so I wouldn't worry too much about that. PO could've just used smaller places for maintenance. With that 2005, I'd read up on the SAIP as well. Got pics of the truck?
    This is another area that's notorious on our trucks. Valve cover gaskets and oil coolers.
    2nd, big big 2nd. NEVER buy shit off Scamazon. Like Nick said there's usually an active discount code on here at all times.
    BroHon and squanto[QUOTED][OP] like this.
  6. Sep 17, 2024 at 8:09 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Do the oil cooler figure 8 gasket and the one behind the oil filter.
    it’s easy if all the oil and coolant are out of the truck already. Parts are under 6$ for it.
  7. Sep 17, 2024 at 4:09 PM
    bfunke
    bfunke Tundra Curmudgeon
    Pics please of engine and suspension. LBJ and TB should be top of your list.
  8. Sep 17, 2024 at 4:46 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Good luck these guys In this forum are an amazing resource
    I will just add that so you don't get overwhelmed early on definitely do the timing belt and lower ball joints first.
    if you have any leaks in the power steering, oil, transmission, differential - basically everything other than brake fluid, I would strongly suggest
    AT-205 Re-seal. I was not a believer, but it immediately fixed a significant power steering leak that I had Even if you plan on coming back later and replacing gaskets, etc., it will get you by until you catch your breath and get other more important things done
    Welcome to the forum. I started refreshing my 06 DC with 300,000 plus miles a year and a half ago and again this forum, the people and the resources, is amazing. A warning though - repairing and upgrading your truck with the assistance of this forum can become addictive
  9. Sep 17, 2024 at 4:57 PM
    Spark plugs. Make sure the front brake caliper pins are greased or you’ll be drilling them out come brake pad replacement time. Adjust your rear brakes and make sure the parking brake works and there’s no slack in the cable. Also replace your brake fluid.
  10. Sep 17, 2024 at 4:59 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You certainly found the right place to find out about your Tundra. These guys know these trucks inside and out.
    squanto[OP] and Weagle like this.
  11. Sep 17, 2024 at 5:11 PM
    shifty` Goons of Hazzard
    I just noticed my rack bellow is showing a leak in the rack. Inner tie rod, I suspect. Started sometime between getting my 275s on, and recently installing the 285s. Added a few oz of 205 in there, and I need to wipe down the bellow to see if it nips it in the bud as I hope.
    squanto[OP] and Weagle[QUOTED] like this.
  12. Sep 17, 2024 at 8:57 PM
    squanto
    Hey guys, thank you for the advice and the welcome!
    Looks like there’s some oil leakage around the valve cover gaskets on each side. I haven’t driven it enough to get pulse for how bad it’s leaking yet, but I’m gonna replace those and the oil cooler and oil filter gaskets like jerryallday suggested.
    The lower ball joints look alright as far as my untrained eye can tell. They look a little less oxidized than some of the nearby suspension components so I’m inclined to believe they were replaced at some point in the somewhat recent past, though I’m planning on replacing them with OEM LBJs and bolts just to play it safe.
    I do have a torn rack and pinion bellow on the passenger side. Aside from a bit of a power steering whine, the power steering hasn’t proved to be problematic thus far, though I’ll certainly be keeping an eye on it. AT-205 might be the the way I tackle that while waiting for parts to come in if it seems like it worsens.
    I’m planning on ordering all the replacement parts from RockAuto other than the LBJs and bolts since I didn’t see OEMs listed there, thanks for the heads up about the RockAuto discount code!
    The brakes were one of the handful of things that were replaced just before I bought the truck. The parking brake seems to be good, I’m in the habit of engaging the parking brake any time I park and it seemed like it had appropriate tension/grip. I’ll check out the cable to make sure there’s no slack. I’ll also make a note to grease the caliper pins while I’m doing the LBJs.
    I apologize for the poor lighting in the pictures. The rain started coming down just as I was getting out there late this evening. I’ll try getting some better pictures of the suspension, and truck as a whole tomorrow. Let me know if there's any specific areas that you'd like to see.
  13. Sep 17, 2024 at 9:43 PM
    squanto
    Also, does anyone have the part number for the gasket behind the oil filter? I think it's Toyota part number 9672124025, but I'd like to double check
  14. Sep 17, 2024 at 9:43 PM
    Definitely need a brake fluid change (dirty master cylinder fluid). Valve cover leak and steering rack boot as you already know.
    Not sure I know what that green wire going over the knuckle is all about.
  15. Sep 18, 2024 at 2:32 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The green "wire" is actually two zip ties. It looks as if they were intended to hold that brake line bracket on the knuckle that always breaks, but it's not holding it because you can see it flopping on the side.
  16. Sep 18, 2024 at 3:53 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Get a stainless hose clamp on that brake line (where the green zip-ties are). I found a way to run it through the slot in the original bracket so there was no rub on any of the line.
    I'll 2nd the AT205 stop leak, works like a champ. I found that some of my valve cover bolts were loose though (common problem I think?). Don't smokum to Alabama though (over tighten).
    I would get that rack boot zip tied up temporarily until you get new ones.
    One LBJ looks new, but for sure neither one is OEM. Oem do not come with grease zerks. At least mine didn't and I haven't seen any that have.
    Definitely flush your brake fluid until it's clear at every wheel. It took me an entire quart/big bottle.
    You stumbled into the right saloon for info/help on your truck, these boys know them inside and out.:thumbsup:
  17. Sep 18, 2024 at 4:05 AM
    bmf4069 Captain wtf
    X2 on getting that brake line secured. Mine ruptured the brake line and I lost all pressure because of that.
  18. Sep 18, 2024 at 5:22 AM
    Passenger LBJ has been replaced, very recently in fact, hopefully not catastrophically, and it was replaced with new hardware which is nice to see; driver is potentially original. I'd change driver, at least, with OEM only. 100k-125k is your LBJ lifespan **IF AND ONLY IF** you used OEM parts. Aftermarket parts, you're looking at 1/2 - 1/3 the lifespan due to inferior part quality.
    Get that bellows replaced.
    You clearly have valve cover gasket leak, check to see if the bolts are at-least hand tight, i.e. take a deep well socket and try to turn each bolt using only the socket. The valve cover isn't supposed to have much more pressure than that, and the fasteners will snap on you. All the valve cover info you need to overhaul is here, reply #18: https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
    You can use a good degreaser like Griot's Engine Cleaner to clean up the oil residue everywhere either now or after VC gasket replace, use a decent bottle brush/wheel brush, being careful not to snag any electronics, take a blower to things after, or let it sit for 1-2 hours to dry after, before you reattach battery cable. Always remove your negative battery cable before spraying any liquids in the engine bay. Remember to drop the skid plate, and use a good degreaser on that, Simple Green is great, it's just not necessarily alloy-safe, so I don't use it on anything except steel.
    You may have cam seal leaks, which is why I'm telling you to clean and wipe up the oil.
    You'll want to do other regular maintenance, like
    • get a shop towel, and wipe down all the grease on the lower half of the car, wipe it into the parts really well, consider it anti-rust coating
    • go to parts store, get some MAF cleaner and some Throttle Body cleaner, if you need instructions (or a couple of warnings about Throttle Body cleaning), let us know (do it while batt cable is off above)
    • replacing vent valves, like the PCV valve on driver's side valve cover and the vent valve on the rear diff
    • checking rubber hoses, consider looking at the ends to check for cracks, and cutting the last 1/8" off before re-clamping; I'd replace both PCV hoses
    • complete brake flush, power steering flush
    • replace rear diff, front diff fluids, consider doing transfer case (note: Lucas 80w90 is your one true "safe bet" for compatible diff fluid)
    • overhaul tailgate handle and latches, it's quite easy: https://www.tundras.com/threads/how...gate-clip-repair-overhaul-beef-up-lube.94180/
    • if parking outdoors, be aware of the infamous cowl fastener leak
    • get that bellows replaced; buy OEM part, I can get you the #, you'll also need a new oetiker clamp to replace bellow, work isn't that bad
  19. Sep 19, 2024 at 10:34 AM
    squanto
    Awesome, thanks again guys! I've got the first round of parts ordered, and I've secured the brake line. I'll feel a lot better once the timing belt, LBJs, and radiator have been replaced.
    On the topic of differential and transfer case fluids, is there any particular reason Lucas 80w90 is the 'safe bet' for a compatible diff fluid? Do you recommend Lucas 80w90 for both, the front and the rear diff?
    I see in the owners manual that 75w90 is recommended for the transfer case and front differential, though for the rear diff it's listed as: "Standard differential: Synthetic oil SAE 75W-140" and "Limited−slip differential: Above −18C (0F): AE 90 Below −18C (0F): SAE 80W or 80W−90"
    I'm not certain if my truck is equipped with a LSD or not, but it certainly gets below 0F in southern PA during winter.
  20. Sep 19, 2024 at 10:52 AM
    Some people on this forum (incl. me, "Mr. Overly Skeptical") learned the hard way about the rear diff, specifically.
    If you have an LSD rear diff (you should have a sticker saying so next to fill plug unless your diff is rusted to shit), you WILL get chatter from many of the sythetic rear diff fluids on the market, and dumb-down the function of limited slip by adding additive. I thought I was being sly going with my old trusty Mobil1 synthetic rear that advertises having LSD additive in its package. Guess what? The LSD rears in these things have really sensitive clutchpacks or something, because I had to add nearly an entire bottle of diff slip additive in mine to get rid of about 80-90% of the chatter and at that point, I wasn't comfortable. Thankfully Mobil1 refunded me in full b/c their product didn't perform.
    But at the end of the day, I'm the f'n idiot, because @FirstGenVol and others warned me, even ECGS (East Coast Gear Supply) who are well-respected industry experts on the topic, also put Lucas 80w90 at the very top of their best-of-best list and recommend it too. That should've been my, "You're not the expert here, those guys are the specialists!"
    I don't see any reason you can't.
    But that said, IIRC I left the Mobil1 75w90 (or maybe 75w140, since that's what Toyota is using now?) in my transfer case and front diff.
    Oh, and warning: DO NOT overtighten the transfer case fill/drain plugs!!! You will crack the housing or strip the threads.
    To that point, depending on how new you are, always open the fill plug first, so you are guaranteed a way to re-fill the diff after. Granted, you could pump in via the breather on top (which I recommend replacing, it's like $8-10) but nobody wants to do that.
    If you have tow package, I believe you'll have LSD. But more than that, you should find it on your truck into at the Toyota Owner's website.
    That's assuming yours isn't rusted, and hasn't lost its sticker. Here's my 2006 4WD w/tow pkg and sticker is still intact. "ONLY LSD OIL"
  21. Sep 19, 2024 at 11:09 AM
    I could’ve sworn I’ve seen others on another Tundra website saying Valvoline 80w-90 with the LSD additive was all they needed but that was over 15 years ago.
    Anyway, I have a standard diff and just use the Valvoline without additive.
  22. Sep 28, 2024 at 6:54 PM
    squanto
    Well, bad news guys.. The parts finally arrived, and I was planning on putting everything in this weekend.
    I was planning on doing fluid changes on the differentials, the transfer case, and greasing the driveshaft first since it didn’t require the level of disassembly that the timing belt and water pump would. While I was rolling around under the truck on a creeper I started inspecting a few rusty areas a little bit more closely.
    Most of the frame is in good condition, but looking at it from underneath, it looks like there’s a previous attempt at a frame repair pinned in place on one of the passenger-side side rails.
    More concerning is the section of the frame just in front of the driver’s side cab mount. After spraying the truck down with some water I noticed the large smear of dried bondo. After smacking it with a ratchet a few times I saw that what is left of that section of the frame appears to have expanding foam sprayed into it that the bondo outer layer is adhered to.
    Needless to say, I am incredibly disappointed, and am kicking myself for not having seen that disguised section of filler on the frame before I bought it.
    It was an ‘as-is’ sale from the dealer, so I fear that I’m SOL on this one. I happened to see another thread on here for a very similar situation where they argued with the dealer and the dealer took the truck back, using the basis of the truck having a recent inspection. Perhaps that would be applicable in this instance. The truck was sold with an inspection that is valid until 04/25. That level of frame damage and corrosion couldn’t have just happened in the past 9 months, right? Surely the inspection shop had to have seen that.
    I’m also searching and reading around about the feasibility of having the frame patched or repaired, but my concern is that this route would be out of the budget anyway..
    Fortunately, all the parts and fluids are still sealed and in their packaging, so depending on how this mess ultimately pans out, returning them will likely still be an option.
    If you guys have any thoughts or experience on this, please feel free to share. Looks like I paid the stupid tax on this one.
    Jack McCarthy likes this.
  23. Sep 28, 2024 at 7:04 PM
    I’d look into it legal-wise. As-is is typically under the assumption that the selling party wasn’t trying to hide something. Here they obviously did, so you may have legal recourse.
    Bmktw2 likes this.
  24. Sep 29, 2024 at 8:18 AM
    This. Clearly you got fucked, and burned, this is EXACTLY why THIS THREAD stresses so seriously and repeatedly (to the point of dead horse beating) that you inspect the frame. You're one of half dozen or more we see per year who get boned by shady dealers/sellers.
    Clearly that was a cover-up job. Typical advice I see is to contact your state Consumer Protection Division. Dealerships can't sell you a vehicle like this with clear problems, then get away with it because they force you to sign an as-is. Knowingly selling a defective vehicle is a crime in many states.
    You should be pissed. I'd be pissed. It's up to you whether you want to go straight back to the dealer and point out the frame hackery, and let them know you're going to the CPD, but I'd probably contact the CPD and ask them what to do in this case, "Are there any protections for me, as a consumer, if a dealership sells me a used vehicle and they covered up extensive frame rot, the the point the frame could snap over any bump?"
    Redoak likes this.
  25. Sep 29, 2024 at 1:52 PM
    bfunke
    Did you buy from dealer or private party. Probably also criminal act as well as civil. Call the police, BBB and state Consumer protection. If a business a little public attention might be indicated. Keep us posted. Might be worth talking to an attorney.
  26. Sep 29, 2024 at 3:42 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
  27. Sep 29, 2024 at 4:24 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Bondo on the frame? Jeez
  28. Dec 28, 2024 at 9:12 AM
    squanto
    Hey guys!
    Hope y’all have been well, just checking in with an update on this.
    I ended up returning the truck and getting most of my money back. After fighting back and forth with the dealer (who has been nothing short of a real piece of work…) he agreed to take the truck back for $3,250, which is a bit less than the $4k that I originally payed, but I’m just glad to be done with the dealer, the truck, and the situation.
    The dealer allegedly took the truck to a frame repair shop and had the rotted section of the frame welded, without me authorizing the work. I took some pictures of the ‘repair’ to show you guys. I’m not a welder, but to my untrained eye, the top of the patch plate just looks crappily tack welded in place. With as shady as the rest of this guy’s operation has been, I wouldn’t be surprised if the ‘repair shop’ is just his cousin with a $100 harbor freight welder.
    I already had a radiator, timing belt kit, LBJs, and LBJ bolts that were out of the return window, but fortunately the parts appear to be compatible with 04-06 DC Tundras and 04-07 Sequoias. While searching for another truck, I was also having a pretty hard time finding a DC camper shell. I’ve seen a few (more or less) locally on marketplace in the territory of $1.5k-2k. This led me to also consider first gen Sequoias since I would likely be using the bed cap for locked ‘trunk’ storage anyway.
    I ultimately found a single owner 04 Sequoia V8 4WD with 289,000 miles and a very clean frame (I learned my lesson… I scooted around on the creeper and heavily tapped every few inches of frame with a wrench, much to the confusion of the seller) nearby that I was very pleased with, and purchased. I don’t have any recent (within the past 150,000mi) service history on the timing belt, radiator, or LBJs, but I fortunately have those parts.
    Thank you guys again for your help and your maintenance suggestions. I’m planning on applying these to the Sequoia!
  29. Dec 28, 2024 at 9:22 AM
    Good to hear you found a replacement and got most of your money back.
    You should have gotten more back even if you took it to small claims and had to pay the costs to get a summary judgement and capias for the owner’s arrest to get them to pay. At least you avoided having to spend your time going through that process.
    Cheers! :cheers:
    squanto[QUOTED][OP] likes this.
