  1. Sep 14, 2024 at 5:30 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    If they are street legal in your state - much better.
  2. Sep 14, 2024 at 5:41 PM
    French Avocado
    Utah / Wyo
    Thanks. How long did it take?
    Did you do one bolt at a time?
    Did you only loosen, cut the washer and insert?
    Did you place the washer against the frame?
    Did you put a washer on the joint point bolt?
    Tundrastruck91 likes this.
  3. Sep 14, 2024 at 5:48 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Started to install my DD 42" LED lightbar from Hotshot Offroad. Just need to plumb the wiring, aim it, and tighten everything down.
  4. Sep 14, 2024 at 5:50 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    It’s awesome definitely recommend
    pvn.beluga likes this.
  5. Sep 14, 2024 at 5:56 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It’s a whole hell of a lot faster to air up with a tank than a compressor.
    reywcms[QUOTED] and bflooks like this.
  6. Sep 14, 2024 at 6:00 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    I have an eBay knock off of the TRD skid but it's basically the same thing. I removed it entirely and placed the rubber washers so they sandwich between the skid n frame..
    I removed both my skids just to do an oil change and add the Fumoto Valve. Figured this was a good time to add the washers. It's pretty simple. Easier if you got someone helping you put it back on. Alone it took me I'd say maybe an hour for just the skid but I did a few other things in between. Removing and putting it back on.
  7. Sep 14, 2024 at 7:00 PM
    TacomaTRD4x402
    Southern California
    Anybody here running the Jomax TSS bracket? If so, how's that working for you? Do you ever get any error codes at all?
  8. Sep 14, 2024 at 7:24 PM
    smokint
    smokint New Member
  9. Sep 14, 2024 at 7:43 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Wow same thing happened to me too.
    smokint[QUOTED] likes this.
  10. Sep 14, 2024 at 7:46 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Wild same here. Gotta add some tomorrow. Anything equivalent to oem that I can grab from autozone?
    smokint and pvn.beluga[QUOTED] like this.
  11. Sep 14, 2024 at 8:10 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I heard Zerex Asian is just as good. But I ended up buying a OE 50/50 jug for $29.
    Lassie and CaptRussia253[QUOTED] like this.
  12. Sep 14, 2024 at 8:52 PM
    CaptRussia253
    Ruslan
    I’ll grab some Monday from the dealership.
  13. Sep 15, 2024 at 6:17 AM
    Cthulhu
  14. Sep 15, 2024 at 6:34 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    What tubes do you bypass on the throttle body mod?
  15. Sep 15, 2024 at 7:29 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Read about the throttlebody coolant bypass modification and learn what you are asking and celebrate with us!
    BR73 and bulldog93 like this.
  16. Sep 15, 2024 at 8:11 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Old post I know. But which Dobinsons are on the 4Runner that ride like shit? Local 4x4 shop to me uses their stuff like it’s the best in the universe.
  17. Sep 15, 2024 at 8:37 AM
    CaptRussia253
    Ruslan
    I went with the heavy duty coils to add bumpers and winch in the future. Without the extra weight they ride stiff. Once I add the swing out tire carrier, sliders, skid plates(installed), and front bumper with a winch, the ride will improve. I also just removed the sway bars and the ride has improved considerably.
    Dobinsons is high quality suspension. You just have to choose the correct springs for your weight/application.
    HulkSmurf14 likes this.
  18. Sep 15, 2024 at 8:43 AM
    ghott86
    ghott86 New Member
    VA
    ‘21 Super White SR5 CM 4x4
    1700 mile road trip last week from VA thru WV to KY and back towing ~3500lbs. Went pretty smooth with the airbag helpers set 18psi and had the trans t-stat pinned open. SG3 helped in monitoring trans temps. Got pretty good at using the go-pedal to get the trans to drop to 4th and let the torque converter lock up to keep trans temps lower going up the long steep grades in southern WV and eastern KY.
  19. Sep 15, 2024 at 9:57 AM
    TimmyTundra21
    TimmyTundra21 New Member
    2021 Magnetic Gray TSS
    TRD Rear Sway Bar, Spotter Mirror with BSM, TRD Pro Headlights/Fog Lights
    IMG_0075.jpg Finally got my TRD Pro Headlight/FogLight assemblies installed on my 21 SR5
  20. Sep 15, 2024 at 11:36 AM
    Cthulhu
  21. Sep 15, 2024 at 11:48 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    2x6x8 board, cut down to 66 1/4 length, 20 degrees cut in middle on each end, rounded smooth at each end using a sander. :thumbsup:
  22. Sep 15, 2024 at 4:20 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
  23. Sep 15, 2024 at 4:28 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    TundraTXTSS likes this.
  24. Sep 15, 2024 at 4:48 PM
    FireFinder44
    Albany, OR
    Finished the 42" DD Stage Series light bar with the "Perfect Mounts" from Hotshot Offroad, well mostly finished. Still have some wire harness management to do, and while I was fishing the wire harness behind the grille, I took the opportunity to put some loom over the front camera wires and clean that up as well. I don't have a rivnut tool and my son's die for his is too small to finish the Rago Fabrication compressor mount, so I will go visit a friend after work tomorrow and finish routing the wiring harness.
    I didn't realize that the switches are keyed to certain spots on the dash, I was going to move the rear window switch over to the right side of the steering wheel, and put the light bar switch under the headlight leveling switch. Annoying. I definitely think I will do a SwitchPro at some point if I have more stuff to control. I may also redo the switch wiring for the light bar if I don't go to a SwitchPro, as I would rather have it behind ignition circuit so it only works when the engine is running and the illumination tied to the dash lights. It was a hassle because for some reason I cannot get the harness to unclip from the Cali Raised LED switch I got, and didn't want to break it.
  25. Sep 15, 2024 at 5:48 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    traded her in today. kind of a sad day. I really thought I was going to have this truck several years, I spent two weeks of nights and weekends taking off all the mods I had. IMG_20240915_162023610_HDR.jpg
  26. Sep 15, 2024 at 5:54 PM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    but, I get to start a new project now, a 2018 1794 in the best color, MGM, with only 21000 miles.
  27. Sep 15, 2024 at 6:16 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    After many years I finally did the "all auto" switch mod. I don't know why I waited so long to do this!!! One of those things that absolutely should have been standard on these trucks, especially the higher trims.
    Took 3 weeks to get, 5 minutes to install, and is the best $ spent on a simple but rewarding mod.
  28. Sep 15, 2024 at 7:27 PM
    TimmyTundra21
  29. Sep 15, 2024 at 7:29 PM
    DrRansom
    DrRansom New Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    Bed: lined (Rhino)
    Undercarriage: Coated (Wool Wax)
    Next: Tonneau cover
  30. Sep 15, 2024 at 8:57 PM
    ReyDaddy
    ReyDaddy New Member
    DFW
    2021 Super White Tundra Platinum 4x4
    Can I get the discount code u used for that mod? Thanks ;)
