Loud bang, now truck wont move in any gear
Discussion in '1st Gen Tundras (2000-2006)' started by DiscoNfrno, Jul 2, 2024.
  1. Jul 2, 2024 at 4:42 AM
    DiscoNfrno
    DiscoNfrno [OP] New Member
    2023 Tundra Hybrid Limited 4x4 Off Road
    Emblem, and Door handle Blackouts
    2002 Tundra 2wd 240k miles
    Sold it to my son last year. He's been pulling a small trailer with a mower on it. No trailer this morning, but entering the interstate ramp, he felt/heard a loud bang, and the truck coasted to the side of the road. Goes into all gears, but won't move.
    Getting towed now. Any ideas? He just gave me $3,000 last night to pay it off!
  2. Jul 2, 2024 at 4:58 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Start with the obvious: u-joints, center support bearing, drive shaft, front yoke, rear diff flange.
    After that check rear diff fluid for chunks or sparkles.
    455h0le_dachshund and Bprose like this.
  3. Jul 2, 2024 at 5:00 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Disco Dave, that sucks. So truck still runs? Goes into gear? Maybe broken driveline? U joints?
    455h0le_dachshund likes this.
  4. Jul 2, 2024 at 5:18 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Agree with the above, check the driveline first, then maybe investigate the rear differential. If the driveline is still spinning but the wheels aren't, then your problem is in the rear axle.
  5. Jul 2, 2024 at 5:59 AM
    DiscoNfrno
    Shop just said the Overdrive planetary setup is gone. $3250 can start on it in 2 weeks.
    I don't even know what that is. That seems like the cost of a transmission replacement.
  6. Jul 2, 2024 at 6:10 AM
    DiscoNfrno
    I should have just sold this truck to someone besides my son. Now over a year later it seems like my problem.
    Any parenting suggestions to go along with transmission advice?
    He's 27 btw
    Fieldnstreamer and DarkMint like this.
  7. Jul 2, 2024 at 6:44 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    What they're saying is the transmission grenaded itself. The OD gear. So he may have been hauling with OD on the whole time.
    I mean I do, but my 800lbs load only goes 3min anway and it goes 1.5 blocks.
    I may have another shop look at it.
    this is an ideal parenting moment on how to deal with automotive failures and what to look for in shops and how to deal with it finically. These failures effect more than just the truck
    Filthyphil and jerryallday like this.
  8. Jul 2, 2024 at 6:53 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Parenting moment: you're 27 years old, figure it out/deal with it yourself. Shit happens!
  9. Jul 2, 2024 at 7:02 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Is it the A340 transmission - if so starting in '01 they began having OD bearing issue that don't show up until 200-400K. And yes it is destroyed - not even the TC will come out now. Ask me how I know.
    Jack McCarthy likes this.
  10. Jul 2, 2024 at 7:07 AM
    Retired...finally
    Sounds like your son has a good credit rating with The First National Bank of Dad. Loan him the 3 grand.
    mayan and jerryallday like this.
  11. Jul 2, 2024 at 7:23 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    The thing here is it's a mechanical thing and mechanical things break. It's not your fault. If your son would have bought the truck from anywhere else, the outcome would have been the same. That being said, it's time to cut the apron strings and let your adult son figure this out. If he is gainfully employed enough to pay the truck loan, he's gainfully employed enough to finance repairs. This is an excellent teaching moment on preparing and having the means to take care things when they break.
  12. Jul 2, 2024 at 7:29 AM
    terrward
    terrward New Member
    2004 DC SR5
    Any junkyards nearby? I’d toss a used trans in there, $300-$500 bucks and a few hours should get him back up and running.
  13. Jul 2, 2024 at 7:37 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    ^^THIS^^ I would be advising this route, and possibly doing the install yourself. Your son and his bros could make a weekend of it. The YouTube should give them all the information they need.
  14. Jul 2, 2024 at 7:48 AM
    This is the way. Just make sure you get it out of a 00-04 2wd truck. The tailshaft is different on the 4wd.
  15. Jul 2, 2024 at 8:30 AM
    DiscoNfrno
    Thank you for the replys
  16. Jul 2, 2024 at 9:40 AM
    bfunke
    bfunke Tundra Curmudgeon
    Planetary gears were a known weakness in early FGTs. If I were you, I would search for a good used transmission from a wrecking yard.
    ToyotaDude likes this.
  17. Jul 2, 2024 at 9:52 AM
    koditten
    Kirk
    Midland of the Mitten
    You are better off sourcing a new, rebuilt transmission. They come with the upgraded planetary gear assemblies.
    The early gen 1 tundras used the Tacoma transmissions. They just weren't strong enough for the heavier truck and v8.
  18. Jul 2, 2024 at 9:59 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I’d definitely search on craigslist, faceplace marketbook, wrecking yards, ect. I’d prefer to buy one on a truck that has been wrecked. The reason being is that you know the transmission was working up until the crash. No guarantees on how well it was working though.
    Depending upon what side of the country you’re on, i have a 2004 2wd transmission in my shop. I don’t know the full history on it, but i removed it from my running driving 2004 2wd tundra that had a HUGE engine knock (i bought the truck as is with a bad engine).
  19. Jul 2, 2024 at 10:21 AM
    I thought the grenading planetary was an '00-'01 thing, but wasn't sure. I guess I need to update THE MEGATHREAD!!!, eh?
    mayan likes this.
  20. Jul 2, 2024 at 3:34 PM
    Johnsonman
    Austin
    Sequoia
    That is what I did - used Yota1 out of Riverbank CA. $2650 with core. They don't have them sitting there - must wait to be built - took 6 mos. yet oh so worth it - smooth as silk shifting.
  21. Jul 2, 2024 at 4:09 PM
    00-02. 03 it was upgraded.
    mayan, koditten and shifty`[QUOTED] like this.
  22. Jul 2, 2024 at 4:20 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I towed a 1300lb popup 700 miles a couple weeks ago, and 6000ish lbs of truck and trailer 50ish miles a couple days ago on my stock trans. Just gotta be easy on it.
  23. Jul 2, 2024 at 8:50 PM
    If you're not a bot say potato.
  24. Jul 3, 2024 at 7:53 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
  25. Jul 3, 2024 at 4:03 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    How can I tell if I'm a bot or not?
  26. Jul 3, 2024 at 4:44 PM
    koditten
    Kirk
    I always wanted to meet a bot.
    I also want to give myself a date rape drug. Hoping I'd get lucky, but how would I know!
  27. Jul 3, 2024 at 7:08 PM
    Riverdale21
    OTP ATL
    A serial masturbator. Just constantly spiking your own drinks. You've taken advantage of yourself before but you were too messed up to remember.
    koditten[QUOTED] likes this.
  28. Jul 3, 2024 at 7:10 PM
    Riverdale21
    OTP ATL
    This poor guy came to this website, took the time to create an account, and asks an honest question. All of that effort to help his son. And he got his honest answers. And now gets to see the deeply unserious side of our motley crew.
    bmf4069 and koditten like this.
  29. Jul 3, 2024 at 7:20 PM
    Johnsonman
    Austin
    Sequoia
    Are we "disturbed" from too much Toyota?
  30. Jul 3, 2024 at 7:22 PM
    That depends, where’ve you been sticking your Toyota lately?
