General Supercharger Thread
  1. Jul 2, 2024 at 12:10 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Great...ha! guess that's what I get for going by Prospeed site! So I'm running a stock, SC, plug at 14psi.
    reywcms, e30cabrio and HulkSmurf14 like this.
  2. Jul 2, 2024 at 12:33 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Are there "better" coils available? This was a moderate update on my Audis to upgrade to R8 coils...though, mostly marketing...
    Mdl likes this.
  3. Jul 2, 2024 at 12:48 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    heh, taco world tackled this topic last month too.
    https://www.tacomaworld.com/threads...ricks-and-mods.518932/page-2532#post-29884838
    "When I pulled my ruthenium's they looked amazing in terms of wear. I replaced them with the spec'd iridiums because NGK doesn't make rutheniums designed for this setup in proper heat range. While the ones myself and others have used seem to "work" I suspect they are harsher on the coil packs with no evidence to back that up, but I did call NGK and inquire about using them and they seemed a bit mortified that I was using those in the truck lol."
    They've had a fair amount of RIPP coils cause issues over there. Not sure if there is a consensus on a good upgraded coil pack to run
    "I did run the with the RIPP packs but mine didn't die due to poor contact issues or corrosion anywhere. They just died due to bad internals (as in the coils themselves). They are resting peacefully in a landfill now."
    reywcms likes this.
  4. Jul 2, 2024 at 12:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    All the aftermarket units never work as well as oem and create more issues. But an oem replacement like that could work? Never knew that was option I'd be curious if it works. We always used to just tighten the tune up and plug gaps. But again Hp tuners etc on our rigs is not as open as the other platforms.
  5. Jul 2, 2024 at 2:24 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Which coils are we talking about?
  6. Jul 2, 2024 at 3:23 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
  7. Jul 2, 2024 at 3:25 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    M3Tundra-JK and Wynnded like this.
  8. Jul 2, 2024 at 3:30 PM
    e30cabrio
  9. Jul 2, 2024 at 3:31 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  10. Jul 2, 2024 at 3:48 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Never verified compatibility.
    My brain immediately read it the same way.
  11. Jul 2, 2024 at 5:00 PM
    e30cabrio
    I'm the guinea pig, ordered 8 used coils from eBay.
  12. Jul 2, 2024 at 5:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Ill say this group we definitely aren’t worried to try new things
  13. Jul 2, 2024 at 5:05 PM
    e30cabrio
    They were from 2 different Lexus NX Turbos.
    I figure, if they work and one or more have an issue I'll get new ones once proof of concept has been established.
    :D
  14. Jul 2, 2024 at 5:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Cool! And a decent price for used ones.
    e30cabrio[QUOTED] likes this.
  15. Jul 2, 2024 at 5:45 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    They should work, I’ll dig further. If they work, are there gains other than durability? Durability is enough for me, but more energy for those pushing big boost surely is welcome.
    OEM Lexus part number 90919-02269 retail $112 discount around $80 Japan sourced $46
    Denso aftermarket 673-1206 retail $70 discount $49 when purchased 4+ quantity
  16. Jul 2, 2024 at 5:48 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Know where to get the 14mm ones?
  17. Jul 2, 2024 at 5:56 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    I have not found either of the discussed NGK sparks plugs in a heat range colder than 7. Perhaps Denso has something?
    Coils look like a go to me…
    NX200t 8ARFTS
    Tundra 3URFE
  18. Jul 2, 2024 at 6:32 PM
    e30cabrio
    I'll post as soon as they are in!
    Mdl likes this.
  19. Jul 2, 2024 at 6:56 PM
    koditten
    Kirk
    Midland of the Mitten
    Question:
    Is there any reason not to install a recommended fuel pump before the supercharger install?
    Will the factory injectors care that a high flow unit is feeding them?
    My truck is presently on my hoist while being rebuilt. If I can knock out that chore ahead of time, it would help with the supercharger install.
    I would like to drive the truck for a few months to make sure the bugs are worked out before tackling the super charger install.
    In case others are unclear. I bought the truck at a salvage vehicle auction. I've been doing this with my daily drivers for years.
    I have an '08 that I bought a dozen years ago and it still runs flawless.
    It, too is a salvage titled vehicle.
    e30cabrio and Mdl like this.
  20. Jul 2, 2024 at 7:22 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    It'll drive fine on stock injectors with a big fuel pump. No downsides.
  21. Jul 2, 2024 at 7:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Like @snivilous stated it will be fine running the larger pump.
    My 07 tundra is a theft recovery that insurance already settled so I got a good deal back in 2010.
    Wynnded and koditten[QUOTED] like this.
  22. Jul 2, 2024 at 7:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks and @e30cabrio will be looking at results! It seems from the previous post from @Jowett it could help deter misfires too.
    e30cabrio, reywcms and Wynnded like this.
  23. Jul 3, 2024 at 2:24 PM
    pursuit2550
    pursuit2550 New Member
    So I am doing an oil change before a lo g trip this weekend. I go to check my Radium catch can, nothing. Not even a hint of oil. WTF. My cheaper J&L would have oil in it already. I probably have 5k on the CC and not a drop.
    So I go and recheck everything. I can suck but can blow back through the pcv valve, valve is good. Check my connections as per Radiums instructions, perfect. Hose to SC is fine, blows and socks. I can't believe this right now.
    So I start to take the CC apart. I must say, it's a shit design the way it is. The top port, pcv valve, is connected to the side port. There is a SS mesh I there which is what turn the oil vapor to liquid oil. Well, if vapor is coming in from the top, gets converted as it goes through the SS mesh, it just get sucked once it turns to liquid at the bottom port that goes into the SC. I have attached a Pic and you can see how this makes no sense to me.
    My J&L are not connected what So ever and the liquid oil drops with no chan e of getting in the port going to the SC.
    Someone please explain this to me because I can't believe after 5k I have no20240703_172236.jpg oil.
    reywcms and snivilous[OP] like this.
  24. Jul 3, 2024 at 2:32 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Yep. Terrible design. I posted my findings here a while back in the General SC thread. I've removed the plate, plug, and ball and threw in a Scotchbrite SS scrubber and now the catch can finally catches.
    Saltyhero13, blenton, Mdl and 5 others like this.
  25. Jul 3, 2024 at 2:43 PM
    pursuit2550
    That's what I am going to do. I called them and the tech was clueless. Here are the Pic I just took. First is how it comes. The oil have to get pass that ball, shit design. 2nd is everything off. How it should be and 3rd Pic is the JL can. The way it should have been designed. Vapors come in through the mess and converts to liquid. Suction port is no where near to suck it up. 20240703_173828.jpg 20240703_173847.jpg 20240703_173904.jpg 20240703_173828.jpg 20240703_173847.jpg 20240703_173904.jpg
    Mdl and PolishedTRD[QUOTED] like this.
  26. Jul 3, 2024 at 2:52 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    I haven’t looked at mine but I’ve only had it on for a few miles so will see. I bought might a few weeks ago.
  27. Jul 3, 2024 at 2:57 PM
    snivilous
    SW UT
    Yea the radium is kind of a pile, but looks nice. The mounting bracket is even a POS. The $30 Amazon one I have on my buggy collects way more shit, looks just as good, and cost 10% as much. Definitely paying for the name.
    sbxx312, Fastlane47, bflooks and 7 others like this.
  28. Jul 3, 2024 at 3:10 PM
    pursuit2550
    Now your hurting my feelings. Lol.
    I bought it because of all the hype on here. Compared to my J&L, it's built better and sturdier. But the design is garbage. We'll I took all the garbage out and we will see how it does.
    M3Tundra-JK and Mdl like this.
  29. Jul 3, 2024 at 3:21 PM
    Ctaylor76
    Chaz
    Houston
    I’ll have to look at mine in a couple days, that’s really unfortunate to hear lol
    Mdl likes this.
  30. Jul 3, 2024 at 3:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Was just going to say my $21 Amazon special catch can works great!
    Fastlane47 and pursuit2550 like this.
