Wheel fitment
Discussion in '1st Gen Tundras (2000-2006)' started by Robpad29, May 21, 2024.
  1. May 21, 2024 at 2:58 PM
    Robpad29
    Robpad29 [OP] New Member
    Robert
    Miami, Fl
    2006 silver access cab
    Stock
    Will wheels and tires from a 2023 tundra fit a 2006 tundra. 265/60R20s on the ‘23, mine have 245/70R16s
  2. May 21, 2024 at 3:09 PM
    No
    FishNinja likes this.
  3. May 21, 2024 at 4:50 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    +1
  4. May 21, 2024 at 5:14 PM
    Robpad29
    Robert
    Miami, Fl
    Stock
    Will 17 inch 4Runner wheels fit with 265/70r17s?
    Tlar25 and FrenchToasty like this.
  5. May 21, 2024 at 5:30 PM
    Yes
  6. May 21, 2024 at 5:37 PM
    Robpad29
    Robert
    Miami, Fl
    Stock
    upload_2024-5-21_20-37-7.jpgupload_2024-5-21_20-37-7.jpgCan’t decide between these two
  7. May 21, 2024 at 5:47 PM
    This question gets asked too damn often. Just know of backspacing issues and you'll be fine. And you can use new Tundra wheels, you need to spend extra coin to adapt.
    All those repeat questions and many more, about wheels, and what you need to worry about, are in the "wheels tires suspension" section of THIS THREAD: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Go read it. Now, and save yourself some headaches.
    Depending on the backspacing/offset of the wheels you choose, you may need to install spacers. Know what you need before you buy. IIRC, the 2nd snowflake" wheels you chose have backspace problems.
    There's an entire thread dedicated to other-model OEM wheels here: https://www.tundras.com/threads/lets-see-1st-gen-with-toyota-rims.40487/
    OldGuy03 and FrenchToasty like this.
  8. May 21, 2024 at 7:41 PM
    FishNinja
    Lee
    06DC2wd
    Both have weak offsets. And the stars look like hot garbage. The te37 wannabe's look great. But it ain't my truck.
  9. May 21, 2024 at 9:21 PM
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    They work with an adapter, but yeah see above threads.
  10. May 22, 2024 at 4:11 AM
    I have yet to see a 1st gen with the snowflake design that actually looks "good", I think "hot garbage" is apropos. The other "asterisk" wheel option, I've seen plenty that look pretty solid, almost natural. But the OEM 5-spoke splits that came with these trucks still look better with meatier rubber IMHO.
    abcinv and FishNinja[QUOTED] like this.
  11. May 22, 2024 at 5:31 AM
    FishNinja
    Lee
    06DC2wd
    But a weak offset as well; they probably look the best on our trucks from the OE options and come in rad color options. But cost more the cooler they look
    Tlar25 and shifty`[QUOTED] like this.
  12. May 22, 2024 at 5:32 AM
    Yeah, the -5.0" backspace is not great, but still better than the Taco snowflake option above, IIRC.
  13. May 22, 2024 at 2:31 PM
    Robpad29
    Robert
    Miami, Fl
    Stock
    upload_2024-5-22_17-30-5.jpgThis is what’s on my truck now, but thinking to go to 17’s to add bigger brakes
  14. May 22, 2024 at 3:21 PM
    bfunke
    bfunke Tundra Curmudgeon
    Bottom one all day long.
  15. May 22, 2024 at 3:53 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    These are my favorites -
    Then these -
    shifty` likes this.
  16. May 22, 2024 at 4:11 PM
    FishNinja
    Lee
    06DC2wd
    maybe if there wasn't a rubber band wrapped around that wheel; it'd look better
    bmf4069 and abcinv[QUOTED] like this.
  17. May 22, 2024 at 5:19 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    These were my favorite 1st Gen offerings from the Darrel Waltrip Edition.
    I'm just not 100% on going to an 18" wheel & having to go down in rubber profile to maintain the same overall stock diameter . . . cause I'm old . . . LOL
    Killer looking wheel though, IMO . . .
    Riverdale21 likes this.
  18. May 22, 2024 at 5:24 PM
    I saw some of these locally on a parts truck (FBMktpl) and I think the seller was asking $100/ea with tires.
    HBTundra[QUOTED] likes this.
  19. May 22, 2024 at 5:48 PM
    And here's a set with a little bit of curb rash for $300, tires look good.
    HBTundra and Riverdale21 like this.
  20. May 22, 2024 at 5:58 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Got those with 285/60R18 tires and they look perfect.
    HBTundra[QUOTED] and shifty` like this.
  21. May 22, 2024 at 6:03 PM
    Riverdale21
    OTP ATL
    Bit of light sanding and some diamond silver metallic touch up paint and you would never know those were rashed. Those are a steal. You can put together some replica center caps for cheap too. I got some black Chinese knock offs to match the OE DW Tundra for about $60.
    It's crazy because Toyota only sold 2,200 sets of those wheels. If people knew how rare they were they would command a higher price.
  22. May 22, 2024 at 6:08 PM
    These 16" Enkeis are always popping up also. This guy has a full sets, $150.
  23. May 22, 2024 at 6:25 PM
    These Enkeis are pretty cool too. From a 1GT. Must be running spacers with that much poke. Very classic 80s/90s Ivan Stewart-era offroad race look.
    Tlar25 likes this.
  24. May 22, 2024 at 6:30 PM
    Set of 5-spoke splits with tires, $150: @FishNinja
  25. May 22, 2024 at 8:32 PM
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Never seen these ones before but they're sweet. Much better than the Darrel waltrip option.
    shifty`[QUOTED] likes this.
  26. May 23, 2024 at 6:23 AM
    FishNinja
    Lee
    06DC2wd
    that dude is under selling himself lol
    should be ATLEAST $200 w/o tires. Cause they actually look good. ESPECIALLY for those looking for the OEM+ style
