General Supercharger Thread
  1. May 4, 2024 at 5:11 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    But it won't be all out... I may put in a small trigger buzzer and red led high on dash like @helidave suggested for the afr hitting anything over 12afr at 11psi up.
    More wiring which I have trouble with. haha
  2. May 4, 2024 at 5:33 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Know you got other stuff going on. @armyoffoo did you install the engine oil/air cooler. Looked at a Greddy setup and a few Rcf ones on fleabay. Thinking of fitting a 15 row cooler on my driver side. I got a cheapo digital oil temp gage to plumb in for now.
  3. May 4, 2024 at 6:57 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I've got all the parts and fittings I need, just haven't done it yet. I'm due for an oil change, but might not get to it this weekend. My plan was to try and put the heat exchanger behind the bumper cover, so it would get air through that opening vs the radiator/intercooler opening. I figured it would be easier to do oil changes if it was lower, and should still get plenty of air.
    Mdl[QUOTED] likes this.
  4. May 4, 2024 at 7:11 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    my comparison was not to disparage amsoil buyers, it was to demonstrate that kirklands performs damn well compared to the “best” oil
    and, yes I am easy on oil. But that 0w-20 run had all my dyno runs on it + 5k. And it did awesome. Looked exactly like amsoil after 5k
    In short.
    All synth oil is about same at 5k
    S/c’d motors do fine with kirklands
    5w-30 protects better that 20w
    That’s my last oil speech in this thread
    I will continue to cast stones in other threads
    had to buy shell gas the other day. Super unleaded nitro plus mega stuff. Made no difference
  5. May 4, 2024 at 7:15 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Omg not gas nau!!!!!
    Lol
    Wynnded, blenton, pursuit2550 and 3 others like this.
  6. May 4, 2024 at 7:41 AM
    bflooks
    bflooks New Member
    Metrowest MA
    You all aren't alone on the HPT connectivity issues. I've only had it happen to me one time, with some magical combination of cuss words, temper tantrum and reboot/plugging/unplugging cables.
    I believe @TurboKits.com can shed more light on his issues as well, since he first informed me about it. I am probably remembering wrong, but I think I recall hearing that HPT is aware of the issue.
  7. May 4, 2024 at 10:03 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    In both of my cases it wasn't HPT it was my fault. I haven't had any big issues with HPT.
    Wynnded, Mdl, ARES35 and 1 other person like this.
  8. May 4, 2024 at 10:04 AM
    e30cabrio
    That is frustrating, sorry.
    Mdl and Fastlane47[QUOTED] like this.
  9. May 4, 2024 at 10:07 AM
    Fastlane47
    Maryland
    2018 Platinum
    Live and learn. We are modifying our Trucks, nothing is guaranteed and nothing works the same as it did before, so we have to expect some issues. Lol, that's why I'm keeping my new monster to bolt on mods only.
    Mdl, Wynnded, ARES35 and 3 others like this.
  10. May 4, 2024 at 10:18 AM
    e30cabrio
    Modding 'aint for the feint of heart!
    lol
    Mdl, nobodyintexas and Fastlane47 like this.
  11. May 4, 2024 at 11:56 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I've been considering the same thing since my tundra is my wife's only vehicle while we're in TX. Her car is back home in OR.
  12. May 4, 2024 at 1:24 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Theoretically
    can I duplicate my ecu and set it on a shelf?
    Mdl, Abell207 and Wynnded like this.
  13. May 4, 2024 at 2:15 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    I was wondering the same thing. I don’t see why we can’t.
    Mdl likes this.
  14. May 4, 2024 at 3:40 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    get the same part number ecu and use techstream to flash your VIN to it.
  15. May 4, 2024 at 5:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Did you say you had the Lexus rcf filter housing and it clears the sway bar. I believe @Jowett said we needed a larger end cap for the 3urfe filter. Looking back at posts on pg 398. If it bolts up I don't mind a horizontal filter if I can install a oil to air cooler without the Baxter adapter. Want to keep parts at a minimum. Found some cheap rcf housing local junkyard. Thanks!
  16. May 4, 2024 at 5:37 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    1UR FE GX 460 filter housing, but it needs machine work to the oil passages for proper flow and to accept the oil coolers. The 2UR GSE filter cap allows the V8 filter to be used with the GX housing. I’ll post some pics tomorrow.
    Mdl likes this.
  17. May 4, 2024 at 5:49 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks! Trying to get some ideas just to add an oil/air cooler. Saw a gx 460 housing that had external ports, for oil cooler?
    Appreciate it!
  18. May 4, 2024 at 6:08 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I ended up getting the Baxter remote adapter and a Thermostatic filter housing...I just need to figure out the mounting/hose routing, but I will install during my next oil change. With the 1UR housing, I would have still needed a remote adapter and the remote filter housing, so this way required fewer parts overall.
    https://www.baxterperformanceusa.co...k-cartridge-to-remote-adapter-multi-port.html
    https://www.improvedracing.com/remo...oil-filter-mount-with-thermostat-env-171.html
  19. May 5, 2024 at 12:57 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Looks like an easy deal. I was hoping that the rcf housing I have access to would work . It's $95 plus another $45 for the air cooler. Man, supercharging is just as bad as fly fishing with the gear.:rolleyes: and yes I just compared the obvious. I have family that remind me of the gassers. What an Era!
  20. May 5, 2024 at 7:19 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    If you can obtain all those parts for $140, do so. Lexus USA charges charges well into multiple four figures $$$$ territory for all of it.
    Mdl and e30cabrio like this.
  21. May 5, 2024 at 7:30 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It turned out that the other Toyota housing has a different filter element depth, so the adapter didn't fit, and of course none of the other adapters I had fit it either. That, and I would still need to work out fittings/adapters to get oil pressure and temp logging, so I scrapped that idea. The Baxter remote adapter has ports out the bottom or out the side, so it'll clear the sway bar no problem.
    Mdl[QUOTED] and HulkSmurf14 like this.
  22. May 5, 2024 at 9:54 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    What’s the easiest way to get techstream for this now? I have a OV dongle from the magnuson tune I heard works with techstream, just haven’t seen someone get a temp license then change the vin.
  23. May 5, 2024 at 10:04 AM
    pursuit2550
    pursuit2550 New Member
    There is no easiest way. It's all pirated software or dongles unless you buy the real deal $$$$. I posted a website that talked somewhat about dongles on the ECU recovery thread. Plus there was some talk about TS in there.
    https://www.tundras.com/threads/how-to-recover-replace-ecu-thread.141787/
  24. May 5, 2024 at 10:14 AM
    helidave
    flagstaff
    2015 DC 4x4
    You can get a 2-day techstream subscription for $70, and the VF Tuner tactrix cable should work with it. I don't know if the dongle magnuson gives you will work
    HulkSmurf14 and snivilous[OP] like this.
  25. May 5, 2024 at 10:15 AM
    VWTim
    Corvallis, OR
    Not sure which cable VF uses, but I've used a Tactrix open port 2.0 or something on mine before. Now using a mini-VCI.
    e30cabrio and helidave[QUOTED] like this.
  26. May 5, 2024 at 10:18 AM
    pursuit2550
  27. May 5, 2024 at 10:45 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    @TurboKits.com you need to stock more of the MAFs, just told another guy to order one :D
  28. May 5, 2024 at 11:10 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    They are 2-3 weeks out and on sale...
    e30cabrio and Wynnded like this.
  29. May 5, 2024 at 11:30 AM
    snivilous
    SW UT
    They actually have a lot of good shit on their website. This dude was asking what upgrades to make more power, and I went to send him the link for their bolt in FPR and realized essentially everything I would tell someone to buy (injectors, pump, FPR, MAF) they offer it all.
  30. May 5, 2024 at 11:41 AM
    blenton
    blenton New Member
    Clarify the reason behind needing a new MAF, if you wouldn’t mind. The OE MAF is setup to read X amount of flow and produce a voltage of Y volts. The software interprets Y volts as Z CFM\LbsPerHour (not sure on the units) of air and calculates how much fuel you need to dump in to the motor.
    The SC is flowing more air than the MAF can read before reaching its peak voltage, so most kits come with an larger intake diameter. The air flows more slowly through the larger intake so the MAF doesn’t max out as soon, but on the software side of things, you have to rescale the MAF table to let the computer know that X amount of low producing Y amount of volts now equals Z *n lbs of air. Correct?
    With the new Turbokits MAF, the rescaling you were originally doing the software is basically rescaled in the hardware? Does that mean the new MAF is less ‘sensitivie’ or provides less resolution? Or because (and I’m making an assumption here) the MAF isn’t quite linear, it provides better resolution because you aren’t in the extreme end of the MAF voltage with higher airflow?
    Doesn’t the new MAF accomplish the same thing as increasing the intake size? Or is it just easier (and cheaper compared to the Maggie intake) to install a new MAF instead of increasing the intake size?
    I’m genuinely curious and thought I understood, but I’m sure there’s something I’m missing.
