General Supercharger Thread
  1. May 1, 2024 at 6:15 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    You can add it to the policy beforehand otherwise it’s usually just replacing the known vehicle at oem configuration/mileage. The risk with adding to the policy is they may drop/increase the coverage for superchargers/mods.
    Mdl and pursuit2550[QUOTED] like this.
  2. May 1, 2024 at 6:17 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I tried to get additional coverage for aftermarket items on mine through Erie. I was told that it’s not available and that I should keep receipts for the upgrades, not that I’d count on a full reimbursement for all the parts however but it might help recoup some cost.
  3. May 1, 2024 at 6:21 PM
    pursuit2550
    pursuit2550 New Member
    I always say to myself that if it a crash that is a total loss, its coming home with me. The following day I am tearing into it to remove and replace everything and anything that I can.
    VWTim, e30cabrio and Silver17[QUOTED] like this.
  4. May 1, 2024 at 6:23 PM
    pursuit2550
    You have a 21 with a dying trans already?
  5. May 1, 2024 at 6:34 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Yeah I first noticed when going in reverse on an incline/under load it feels like a rumble strip/shaking. Then 2/3 gear shift started to be delayed/rough. Now get some slipping/rumble strip in 3rd gear. I think it’s a combo of having mid 600 crank hp, plus whatever whacky OV tune magnuson was using plus 35” tires plus no cooler so it’s 230f frequently. New tune plus IPT built trans plus cooler I think is the (spendy) ticket .
    pursuit2550[QUOTED] and Abell207 like this.
  6. May 1, 2024 at 7:01 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Got the @TurboKits.com goodies for this weekend. :cookiemonster:
    My first go at a FPR, so I'll have a couple basic questions I imagine...
    Just pretend that's my kitchen counter.
    ZPhilip, ARES35, M3Tundra-JK and 10 others like this.
  7. May 1, 2024 at 7:05 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    The Tundra owners manual has the no-go mounting points. I think this one is near if not on a no-go zone.
    e30cabrio, Abell207[QUOTED] and Mdl like this.
  8. May 1, 2024 at 8:07 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Kool! Mock up the fpr and see if it clears the side of the 2650. I think it will but a 45 or 90deg fitting will work.
    Good luck.
  9. May 1, 2024 at 8:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My maf and narrow band O2's were flat lined but after the 4.5 inch intake and 95mm TB it's jagged. Would turbulence cause it? It's runs sweet otherwise. No air leaks etc...
    ARES35, e30cabrio and snivilous[OP] like this.
  10. May 1, 2024 at 8:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Think it may be time for turbokits MAF...
  11. May 1, 2024 at 8:18 PM
    Dashunde
    Dashunde New Member
    2018 Tundra Crewmax limited TRD
    Hi all, I got redirected to this 508 page thread..
    I’m in southern Idaho, 3500ft and up, plenty windy, and I tow an RV.
    My paid off bone stock 2018 CM Limited TRD has 44k and is like new. I have zero desire to buy a new $75,000+ turbo truck of any kind so I’m thinking about adding a supercharger to bring back sea level power (and then some).
    What are the pro’s and con’s?
    Any reason not to install one?
    Who has a good history of selling/installing them? (In/around Boise, Salt Lake, etc.. I’d overnight
    e30cabrio and koditten like this.
  12. May 1, 2024 at 8:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That looks like a first gear pull, how do you even have traction?
    e30cabrio likes this.
  13. May 1, 2024 at 8:39 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The 2007 aLSD let's me pull through the nannies. My Auburn is toast and has been 6mos after getting it.
    Went to the airport to test 6000rpm pulls.
    My exhaust mod has me down to 12psi.
    https://vimeo.com/941811316
  14. May 1, 2024 at 8:56 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Most people are shocked that I walked away. I'd say someone was looking out after me along with the safety of a Tundra.
    I'm assuming I won't get anything and get screwed but I will provide receipts and see what happens. A lot of my audio was stolen less than an hour after we left the accident to get me checked at the ER.
    e30cabrio and Wynnded[QUOTED] like this.
  15. May 1, 2024 at 8:57 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Silver17[QUOTED], Abell207 and Mdl like this.
  16. May 1, 2024 at 9:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Fricking thieves! Most of the time I surance will let you swap out aftermarket parts.
    Swap out the harrop and anything else you may have. If you have stock pieces...
  17. May 1, 2024 at 9:09 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    That's interesting it wasn't before and now is. I think your theory has merit, and names logical sense that if the sensor isn't seeing consistent airflow then it would bounce around.
    ARES35 and Wynnded like this.
  18. May 1, 2024 at 9:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And i threw in a newish maf I had for emergencies. Same result.
  19. May 1, 2024 at 9:13 PM
    snivilous
    SW UT
    Southern Utah here. Blower and a pulley and you'll be very happy. There's also the turbocharger kit out now, food for thought about that.
    Only real reason not to install one and the associated con being cost. It can snowball quickly, and there's a steep initial buy in. Supercharger, pulley, injectors, and a tune and it'll be reliable and make a lot of power. Or just get a stock supercharger and enjoy it as is for awhile, though a tune is always recommended regardless of power and mods.
  20. May 1, 2024 at 9:13 PM
    snivilous
    SW UT
    Time for that honeycomb shit, if you care about how jagged it is.
  21. May 1, 2024 at 9:21 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Insurance told me I have a total of 15 minutes available with the truck for up to 15 days lol
    M3Tundra-JK likes this.
  22. May 1, 2024 at 9:22 PM
    blenton
    blenton New Member
    Do it. DO IT. DOOOO IIIIIIITTTT.
    Saltyhero13 and Mdl like this.
  23. May 1, 2024 at 9:30 PM
    AZTundra
    Paul
    Phoenix, AZ
    Can't you have the truck released and towed to your place?
    Wynnded and pursuit2550 like this.
  24. May 1, 2024 at 9:53 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Getting ready to install my PSB-1 in the drivers door vent (got a vent insert) and trying to get the basic game-plan down. From my reading I need to find a 12v ignition on wire and ground somewhere near that area. The blank switches and fuse box above the drivers left knee seem like the ideal spots for these. Then I would imagine you route through the side of the Ac vent somewhere too (seen people install the gauge in the vent just not the wires). The o2 sensor seems pretty straight forward as it’s just screw in like a regular o2 then route the harness on up to the gauge, guessing through one of the firewall holes. Im guessing people just make the best of routing/zip tying. Then the map sensor you mount someplace near a supercharger vacuum line, which there seems to be two setup for this that are capped on either side of the back of a mag 1900, (routing the wiring harness to the gauge as well). I am a bit confused on how to use the purple/yellow wires so that the hptuner mpv3 can read it.
    Mdl likes this.
  25. May 1, 2024 at 9:54 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I probably could have. I'm following the insurance company's directions. I sold off most of my oem stuff, including the stock intake unfortunately. My boss wants to buy the truck and pull the engine.
  26. May 1, 2024 at 10:52 PM
    Dashunde
    Dashunde New Member
    Whats the company? (Need to know before I say much)
    Where is the truck?
    Have they made a settlement offer yet?
    If so, whats the retention (salvage) value?
    Would you be on the hook for storage/transport charges if retained?
    Do you own it outright? (If so, lender gets paid first)
  27. May 1, 2024 at 11:08 PM
    Dashunde
    Dashunde New Member
    Any recommended shops in my area? I’m in Twin Falls.
    I’m probably going to keep it simple, just want better towing without threatening reliability, transmission, or going through tires like they’re free. Maybe an extra pound or two so I get full sea level power, definitely a proper tune.
    Is the Magnuson the original TRD item that could be installed by the dealer, full warranty and all?
    Why are there two listed on Magnuson’s site, $5k and $8k?
    My 2003 Taco had the TRD supercharger… it was fun for what it was.
  28. May 1, 2024 at 11:59 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You'll need the mpv pro link+ to hook up to the vcm scanner. It will convert the afr and boost signal so you can log them.
    Hopefully @blenton can shed some light on the boost formula. You can mount the map sensor on the firewall. Most run the wires through the drivers side wire harness bulkhead plug.
    Wynnded likes this.
  29. May 2, 2024 at 12:07 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Only warranty is from the company you buy the supercharger from. Whipple, Harrop and Magnuson. No warranty from Toyota.
    You can throw a smaller pulley on for some extra psi. Keep it low psi and run it rich for longevity.
    The difference in price is one is just an upgrade from the 1900 to the 2650. No extras, its just a SC upgrade.
    The other is the full 2650 kit.
    Wynnded likes this.
  30. May 2, 2024 at 12:22 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's from the torque converter overheating. Usually a valve body upgrade will help the shudder. As the accumulators get worn it causes the rumble/shudder.
    Try disabling the torque flex lockup. On some it got rid of the shudder. It also generates excess heat. Definitely get a external transmission cooler. Amazon has a few inexpensive coolers that will do the job.
