First Gen Lower Ball Joint(LBJ) Failures
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, May 1, 2024.
  1. May 1, 2024 at 9:52 AM
    FirstGenVol [OP] Recovering mangler
    I figured it's time to start documenting all these in a single place. A good reminder for all our new members that join.
    • DO NOT BUY AFTERMARKET LOWER BALL JOINTS
    • They should be replaced with OEM parts every 100k minimum. If they see a lot of hard use, consider doing it sooner. If you wait for a sale from Toyota you can save 20-25%.
    • The bolts should be replaced too.
    • See this thread for part numbers
    These are from the last 24 hours.
    Lupe, Jsim, BroHon and 5 others like this.
  2. May 1, 2024 at 9:53 AM
    @shifty` I couldn't find the thread where a member had his fail on the interstate and he totalled his truck. Maybe your search skills can.
  3. May 1, 2024 at 9:58 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  4. May 1, 2024 at 10:09 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Ka-chow!
    metalpete, Tundra2 and JasonC. like this.
  5. May 1, 2024 at 10:27 AM
    I'd be curious to see how @Dave8699 made out with his "terrain tough" Mevotech LBJs. https://www.mevotech.com/brands/ttx/
  6. May 1, 2024 at 10:37 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
  7. May 1, 2024 at 10:43 AM
  8. May 1, 2024 at 10:44 AM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    Would be good to post all the proper torque numbers for each year as well. That's a big area of confusion.
    Tundra2 and Jack McCarthy like this.
  9. May 1, 2024 at 11:32 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Hour and a half in and this isn't stickied.....for shame
    Tundra2 likes this.
  10. May 1, 2024 at 11:34 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Tundra2 likes this.
  11. May 1, 2024 at 11:37 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    @shifty` has them linked in the Bible
  12. May 1, 2024 at 11:54 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  13. May 1, 2024 at 12:25 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I went 304k on my original :anonymous:
    (DON'T TRY THIS AT HOME)
    Weagle, G_unit3000, BroHon and 3 others like this.
  14. May 1, 2024 at 12:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    With a spacer lift?
  15. May 1, 2024 at 12:34 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    At that time, yes :anonymous:
    (AGAIN, DON'T TRY THIS AT HOME)
    Jack McCarthy likes this.
  16. May 1, 2024 at 12:41 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm speechless.
  17. May 1, 2024 at 2:09 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Literally.
    G_unit3000 and Tundra2 like this.
  18. May 1, 2024 at 2:13 PM
    Riverdale21
    OTP ATL
  19. May 1, 2024 at 3:52 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Black bolts on mine. With protector. Like 440 in.lbs.
  20. May 3, 2024 at 4:20 AM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    5k on drivers side. Sheared off just after getting off the freeway pulling away from a red light.
    10k on passenger side again sheared off. This time at 70mph just after coming over the grapevine. Ripped upper ball joint apart and frame landed on the wheel and skid to a stop on the side of the freeway. Ground almost an inch of the lower control arm off and about 20% of the wheel. Only thing holding the wheel on was the tie rod and if it hadn't become a ski it probably would have ended badly.
    New brake line, spindle, lca, wheel and tire. Also did Toyota upper and lower ball joints, and all 4 tie rods.
  21. May 3, 2024 at 4:46 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I don't want to "like" this, but thank you for sharing to testify to the fact that no aftermarket LBJ is a safe option.
  22. May 3, 2024 at 4:51 AM
  23. May 3, 2024 at 5:06 AM
    Wow, man. Sorry to hear. I think you're the first here who experienced a separation at high speed. Glad you're okay.
  24. May 3, 2024 at 5:10 AM
    No there is the other guy I keep mentioning. Can't find that thread. His truck was totaled. But you're right that they typically fail going slow. Not sure why that is.
  25. May 3, 2024 at 5:17 AM
    35k miles and going strong.
    I’m not worried, you’re worried!
    :lalala:
  26. May 3, 2024 at 5:31 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The lateral forces (front to back) from the truck moving forward might be enough to keep the ball locked into the rear of the "cup" the ball stud sits in.
    As the truck decelerates, those forces lessen, and the ball stud can come free from the cup.
    I'm no engineer though, but I stayed at a Holiday inn with one, one time. This is purely speculation.
    I'm thinking that when you drive over a washboard, or a lot of our fucked up roads, the wheel gets to bouncing up and down at speed. That half second of air time from the wheel coming out of a pot hole might enough of a rest on the suspension, that the same thing would happen at high speeds.
    The ball stud would center itself in the cup while the wheel is in the air after the pot hole, or washboard, and then esplodeys into pain and suffering
  27. May 3, 2024 at 6:17 AM
    My house is not a Holiday Inn, thank you very much. :rofl:
  28. May 3, 2024 at 10:48 AM
    I hear what you're saying. They rarely get above 3 stars anyway.
  29. May 3, 2024 at 11:51 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
  30. May 3, 2024 at 12:10 PM
    Nope. This guy had a gray or silver truck. He didn't own the truck very long and posted as a warning to those to just replace the ball joints if you aren't sure when they were last done. For some reason, the thread is lost to time.
