  1. Mar 18, 2024 at 6:25 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Speaking of welding cool little stuff...
    I welded up a phone mount using the useless cup holder area in my dash.
    Also installed some exterior lights for the camper.
    And of course made some Corned Beef and cabbage!
    PXL_20240317_014503489.jpg PXL_20240317_014518878.jpg PXL_20240318_015234336.jpg PXL_20240318_023253231.jpg
    Voss, 805Tundra, bmf4069 and 9 others like this.
  2. Mar 18, 2024 at 7:08 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    If you get the settings right and everything is prepped AND you use a good wire. The welds will be plenty strong.
    https://youtu.be/lEytWQQPHOU?si=zZ1FqknTllndssRZ
    805Tundra and oscardog86[QUOTED] like this.
  3. Mar 18, 2024 at 7:48 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Think it's best to detach the brake cable from the bellcrank and adjust the brake shoes first then the bellcrank to 1mm and pb cable in that order.
    https://www.tundras.com/threads/rear-brake-adjustment-theory-and-practice.99575/page-2
    How much do you have left at the lowest depth?
    oscardog86 and FrenchToasty like this.
  4. Mar 18, 2024 at 12:06 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I been wanting to figure out something useful to do with that cupholder slot
    oscardog86[QUOTED] and FishNinja like this.
  5. Mar 18, 2024 at 12:23 PM
    FishNinja
    Lee
    06DC2wd
    switch panel?
    edit: a slide out switch panel would be dope
  6. Mar 18, 2024 at 12:33 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    If I ever decide on any permanent coms, that might be where they go. But for now I'll stick with handhelds. I've got a switch panel where my sunglass holder/garage door opener flap was
    oscardog86 likes this.
  7. Mar 18, 2024 at 2:04 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I 100% agree. I welded in high school with a friend. No real training or anything. I bought a HF welder 10 years ago and use it about once a year to bail myself out of something. Totally worth it and lots of fun. Easier than it looks to make non-structural stuff.
  8. Mar 18, 2024 at 4:39 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Lowest depth on the shoes?
    I saw something about detaching the cable also but it wasn't on here it was on YT. I assume you mean adjusting shoes with the star after detaching, then remove any slack then reattach?
    There's about a 1/16th" space between screw and plate now.
    The way they were set the screw was on the backing plate, been that way since I got it never messed with it til the other day. I have new innards for the drums except the shoes because I realized I had a plugged bleeder a while back so I didn't go through with the refresh being as the shoes had some life left but they were worn a little unevenly...
  9. Mar 18, 2024 at 5:59 PM
    KidOnTheHill
    KidOnTheHill New Member
    2004 Tundra Access Cab V8
    100%... who has time to pick apart someone who has no affect on your life, thought we were talking about 1st Gen Tundras.....
  10. Mar 18, 2024 at 6:32 PM
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    Probably not everyone's cup of tea, but I finally got my bed decals on.
    Voss, NUDRAT, VR6T and 16 others like this.
  11. Mar 18, 2024 at 6:39 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I <3 that color/wheel combo. Bonus points.
    Voss, bmf4069, BroHon and 2 others like this.
  12. Mar 18, 2024 at 6:40 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    sounds like something that someone who puts beans in chili would say.
  13. Mar 18, 2024 at 7:21 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Looks great :thumbsup:
  14. Mar 18, 2024 at 7:23 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    It always comes back to beans with chili. :rofl:
    Show me on the doll where the beans touched you.
    BroHon likes this.
  15. Mar 18, 2024 at 7:30 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  16. Mar 18, 2024 at 9:50 PM
    pullupthendown
    pullupthendown New Member
    2006 Tundra Double Cab SR5
    Picked it up from the paint shop and started working on broken flair clips
    Voss, NUDRAT, 805Tundra and 7 others like this.
  17. Mar 18, 2024 at 11:23 PM
    Looks much better without the fender flares.
  18. Mar 19, 2024 at 3:04 AM
    Is that Timberland Mica? I like it.
  19. Mar 19, 2024 at 4:44 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Not the best pic but the PO of mine must have been deaf... cab topper rub rub rub :facepalm:
  20. Mar 19, 2024 at 6:41 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Rub a dub dub
  21. Mar 19, 2024 at 7:00 AM
    ToyotaDude
    ToyotaDude Member
    Was just asking how worn your shoes are. I think it's 1mm on the bellcrank IIRC and whole procedure is in the thread along with the FSM pages for reference on the bellcrank. Very helpful. Find its easiest to remove the drum to adjust the shoes and also can clean-out all the dust. Have even regreased the adjuster and backing plate if shoes have life but some would opt to replace shoes instead given basically the same labor.
  22. Mar 19, 2024 at 7:11 AM
    BEANS DONT BELONG IN CHILI!
  23. Mar 19, 2024 at 8:39 AM
    Chili isn't chili without beans. You're one of those weirdos that puts corn and carrots in your chili, aren't you?
  24. Mar 19, 2024 at 9:28 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Never added carrots, but corn chips are a staple.
    BroHon, artsr2002 and bmf4069 like this.
  25. Mar 19, 2024 at 9:33 AM
    FishNinja
    Lee
    06DC2wd
    that's called a frito pie. You call it by its proper name
  26. Mar 19, 2024 at 9:33 AM
    FishNinja
    Lee
    06DC2wd
    beans belong in chilli
  27. Mar 19, 2024 at 9:35 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    you can add beans to chili, but you dont cook chili with beans.
    455h0le_dachshund and bmf4069 like this.
  28. Mar 19, 2024 at 9:38 AM
    BBQ sauce. Cold or hot? I hate it when restaurants apply it cold. Like WTF? Cook it into the meat.
    (We need an angry old man shaking his fist in the air emoticon)
  29. Mar 19, 2024 at 9:38 AM
    Chili with beans is good. Chili without beans is good. Pizza with pineapple is good. Pizza without pineapple is good. Food is good. I like to eat. Don't care about rules.
  30. Mar 19, 2024 at 9:43 AM
    FishNinja
    Lee
    06DC2wd
    frito pie sounds fucking amazing right now. I don't think I've had one in 5 years.
    NUDRAT, The Black Mamba and bmf4069 like this.
