General Supercharger Thread
  1. Mar 6, 2024 at 9:21 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Ran the sdhq units on the old mans tundra worked well. But with the new suspension will be removing. No negative feedback since he's had them. They worked great both on pavement and on the dirt
    ARES35, Mdl and carn_dogg[QUOTED] like this.
  2. Mar 6, 2024 at 10:14 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Core thing is right
    I just bought them. Then sent back for core credit. Smooth transaction
    and I got stickers.
    ARES35 and Mdl[QUOTED] like this.
  3. Mar 6, 2024 at 10:34 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  4. Mar 6, 2024 at 10:55 AM
    ARES35
    ARES35 New member for life
    Mile high
    I don't run traction bars but have the road active suspension on AAls. I use it for towing camper. When I gun it back barely moves..... Dedicated traction bars are probably far superior though.
    carn_dogg[QUOTED] likes this.
  5. Mar 6, 2024 at 10:58 AM
    ARES35
    Mile high
    This. RTD needs to go if you want to dial your rig in for how you drive.
  6. Mar 6, 2024 at 11:14 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I hope to be off the rtd tune in a week or so once I have new injectors. Mpvi3 in my hand as we speak so I can get a readable/editable file over for a tune
    ARES35[QUOTED] likes this.
  7. Mar 6, 2024 at 11:16 AM
    ARES35
    Mile high
    I just looked at a log @Grenades4Bacon sent..... If he's on the RTD device is so out of wack it's insane. Can see STFT -20 still trying to take fuel from the LTFT that are already negative! He for sure needs a MAF tune from what I can see with my limited knowledge.
  8. Mar 6, 2024 at 11:40 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Ironically a datalog he sent me earlier showed the fuel trims actually very dialed hahaha
  9. Mar 6, 2024 at 11:41 AM
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
  10. Mar 6, 2024 at 12:06 PM
    ARES35
    Mile high
    :rofl:Well shit looks like out of the 5000 datalogged line items I scrolled to a -20 area, not sure where that was at. Just clicking around I found this spot but if this is 1single massive data log overall his LTFTs are close to zero with -7 being the worse haha. @Grenades4Bacon was the excel one single datalog or multiples?
    Grenades4Bacon likes this.
  11. Mar 6, 2024 at 12:09 PM
    Grenades4Bacon
    Grenades4Bacon New Member
    2019 Tundra
    Yup, it was one long drive.
  12. Mar 6, 2024 at 12:09 PM
    ARES35
    Mile high
    Holy shit that is a lotta data:rofl:. Well at the end of the log your LTFT are within -+2 so I degress..... Lol. Do you have a log in open loop WOT?
  13. Mar 6, 2024 at 12:12 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Mdl and koditten like this.
  14. Mar 6, 2024 at 12:14 PM
    koditten
    Kirk
    Midland of the Mitten
    Mdl and Black@Blue19[QUOTED] like this.
  15. Mar 6, 2024 at 12:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  16. Mar 6, 2024 at 12:45 PM
    carn_dogg
    Pat
    Eastern Shore MD
    ah yes, our taxpayers dollars at work.
  17. Mar 6, 2024 at 1:23 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    my modifications were lost in a tragic boating accident.
  18. Mar 6, 2024 at 3:40 PM
    Black@Blue19
    Ken
    SE Texas
    ^^^^ now that’s fricken hilarious!!!!!:goingcrazy::)
    koditten likes this.
  19. Mar 6, 2024 at 4:31 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's usually reserved for our other worries and now our vehicles!
  20. Mar 6, 2024 at 4:46 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    We're gonna need a bigger boat
  21. Mar 6, 2024 at 4:57 PM
    ARES35
    Mile high
    Same with all my guns:(
  22. Mar 6, 2024 at 5:18 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ARES35 and Mdl like this.
  23. Mar 6, 2024 at 5:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's what I was referring too without stepping into the political foray.
  24. Mar 6, 2024 at 5:31 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wynnded[QUOTED] likes this.
  25. Mar 6, 2024 at 5:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    With the IC that I've been using most recently, mine reads ~2MPG higher than what's manually calculated. Other ICs that I've used for long durations as the tune has evolved particularly with different injectors, have shown to be consistently....uh, consistent in how far the cluster calculation is off. I want to say, and I could be remembering this part wrong, but I seem to remember that the closer the IC was to stock/original, the more accurate that cluster calculation seemed to be.
  26. Mar 6, 2024 at 5:43 PM
    blenton
    blenton New Member
    Had an interesting issue with a my bypass valve actuator. I pulled vacuum on it with a handheld vacuum pump and it held 10-15"HG perfectly. Let it sit for 5 minutes and zero loss of vacuum. Went to disconnect the line and the gauge blipped, so I started fiddling with things. In short order, I found that gently pushing on the actuator cap or jiggling it would cause the vacuum to disappear. I could give the cap an almost imperceptible twist with less than finger tight tension and the actuator lost vacuum immediately and wouldn't even build vacuum. Do a little twist and jiggle and it hold, then blip, then hold, then drop pressure, then not hold vacuum, and on and on. Bizarre but it looks like I have a bad actuator.
    I emailed Whipple about it last night and they sent a new one out today - should be here tomorrow. Good on them.
    ARES35, Wynnded, Mdl and 1 other person like this.
  27. Mar 6, 2024 at 5:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    For those with larger tires or want to adjust shift point in HPT Grant from TRP gave me a excel spreadsheet to adjust shift points. You can enter your gear ratio and tire size and plug in each gear ratio to get your new shift point. Does upshift and downshifts. Hope it helps! I have it in excel and another that works in open source or the like for those that don't have microsoft crap. The site wont let me upload the open source document so if you need that I can email it.
    reywcms, ARES35 and Wynnded like this.
  28. Mar 6, 2024 at 6:00 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Seems most the inaccuracies come when the truck doesn’t correctly determine “distance driven” due to tire change ect.
    Yes ECM sends CAN message relating to fuel injector #1, Cluster uses this data, distance driven (from ABS ecu/wheel speed sensors) and fuel level (direct line resistance from tank) to calculate Avg, Instant Fuel Economy and Range (DTE)
  29. Mar 6, 2024 at 6:21 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That seems to make sense as many people change tire size and it throws everything off. I'm using the stock tire size, but we've all changed the Injector Constantin our tunes for larger injectors, and that's gotta be throwing off the cluster calculation with the pulse duration of larger injectors being shorter giving the false result of a higher MPG. Thanks for the attachment detailing how each of the other values are calculated. Dig stuff like that.
    ARES35 likes this.
  30. Mar 6, 2024 at 6:21 PM
    ARES35
    Mile high
    I avoid political forays like the plague. Sometimes boating accidents just happen. :spy:
    Mdl[QUOTED] and koditten like this.
