2006 Toyota tundra third brake light plastic screw reciever
Discussion in '1st Gen Tundras (2000-2006)' started by wcsalaun, Feb 18, 2024.
  1. Feb 18, 2024 at 8:45 PM
    wcsalaun
    wcsalaun [OP] New Member
    Truck: 2006 DC Tundra 4WD
    I striped the plastic clip that the screw threads into for the third brake light
    Anyone know the part number to order new ones?
  2. Feb 18, 2024 at 9:43 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Try 90189-04035
  3. Feb 18, 2024 at 9:47 PM
    ATBAV8
    Tempe, AZ
    You should also read through this thread. The search function on this forum is your friend.
  4. Feb 18, 2024 at 10:15 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Stuff a zip tie end in it, and then rescrew
  5. Feb 18, 2024 at 11:57 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Lowe's has some similar items that may fit the bill.
  6. Feb 19, 2024 at 5:46 AM
    Which thread? I think you forgot the link :D
    I think I’m more concerned about the lack of seal - do the double cabs not have the same foam seal around the perimeter as the access/regular cabs?
  7. Feb 19, 2024 at 6:41 AM
    ATBAV8
    Tempe, AZ
  8. Feb 19, 2024 at 6:43 AM
    ATBAV8
    Tempe, AZ
    When I looked up the part number, the exploded diagram did not show a foam seal. I specifically looked at 2006 DC.
    shifty`[QUOTED] likes this.
  9. Feb 19, 2024 at 6:46 AM
    ATBAV8
    Tempe, AZ
    That was going to be my other suggestion, or a piece of narrow gauge wire. The local ACE HARDWARE might be a good option too. They have a plethora of weird fasteners/hardware.
  10. Feb 19, 2024 at 8:29 AM
    wcsalaun
    Thank you all! Yes hopefully will come with a seal too, because Im having a hard time fixing a third break light leak. If it doesn't have a seal I will just silicone it.
