Blown engine
Discussion in '3rd Gen Tundras (2022+)' started by northerntundra1, Oct 29, 2022.
  1. Feb 6, 2024 at 9:09 AM
    #601
    Breathing Borla
    Northern Illinois
    seems to be another confirmation of the poor block cleaning cause.
    there hasn't been a single hybrid failure?
    ryanwgregg likes this.
  2. Feb 6, 2024 at 9:10 AM
    #602
    AZBoatHauler
    So.Arizona
    Plenty of hybrid engine failures have occurred. @ryanwgregg has the stats.
  3. Feb 6, 2024 at 9:10 AM
    #603
    AZBoatHauler
    So.Arizona
    Please post the details in the thread for tracking. Sorry this happened.
    https://www.tundras.com/threads/3-4-i-force-engine-failures.121107/
    Mattedfred likes this.
  4. Feb 6, 2024 at 9:39 AM
    #604
    Breathing Borla
    Northern Illinois
    ya I thought so, it makes sense, the blocks are the same and would have been made and not cleaned at the same time
    Mattedfred and ryanwgregg like this.
  5. Feb 6, 2024 at 10:34 AM
    #605
    AZBoatHauler
    So.Arizona
    Shocked to hear 5 failures so far at the Lake Havasu Toyota dealer. That town only has 60k people.
  6. Feb 6, 2024 at 11:36 AM
    #606
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Last year it was easier to do the math when we had a good idea based on short block and gasket kit orders and industry watchers posted 200K trucks had been produced at that time. For my own sanity I pushed the failure number to 1000 (way over actual at that time) and used 200K built. That gives you 0.5%. Who knows what it is now but failures have tapered off and units built just goes up. The percentage is still very low but to all the affected owners it still totally stinks.
  7. Feb 14, 2024 at 5:51 PM
    #607
    Kanadakid
    Kanadakid New Member
    Donald
    2023 Tundra 1794
    Nothing yet
    Think this is inaccurate.....look at the shear number of recalls for the Ford 150s. Chevrolets drop transmissions all the time so much that a master mechanic at our local Chevrolet dealer said he would never buy one and recommends the CURRENT Tundra. Ram can't give their trucks away they are plagued with so many problems. I don't know who your local dealer is but they can easily switch to RAM or chevy dealership.
  8. Feb 15, 2024 at 6:36 AM
    #608
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    People are used to previous generations quality, where the worst thing that seems to happen is running out of gas.
    JPritch, Terndrerrr and AZBoatHauler like this.
  9. Feb 15, 2024 at 7:14 AM
    #609
    AZBoatHauler
    So.Arizona
    You had a water pump fail? How long was the truck down for that?
    hagrid likes this.
  10. Feb 15, 2024 at 7:21 AM
    #610
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    The above is the best advice. (edit)
    If you live in Florida or Arizona, someplace hot, with a turbo motor that the oil gets heated up by them, general rule of thumb without the analysis is to change it more frequently.
  11. Feb 15, 2024 at 7:59 AM
    #611
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Yeah, that made me chuckle. My Gen2 has been a good truck but had it’s fair share of issues that come to mind:
    • Brakes gone at 5k
    • Electronic Shift controller
    • ABS Sensor mounts decoupled
    • Electronic Shift Controller (Yes, again)
    • Rear axle assembly/seal/bearing
    • I don’t recall what it was, related to distributor but on left rear frame, see pic. This one left me stranded far from pavement and nice long walk.
    She is generally still solid however. I think gen3 will fare just fine over time. Especially against the big 3.
    cmiles97 likes this.
  12. Feb 15, 2024 at 8:01 AM
    #612
    AZBoatHauler
    So.Arizona
    Fuel pump control module?
  13. Feb 15, 2024 at 8:03 AM
    #613
    MaineTundy
    I think you’re right. ‘module’ was one of the words. When first diagnosed I thought, “shouldn’t that be under the hood?”
  14. Feb 15, 2024 at 11:24 AM
    #614
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    This is a PWM amplifier basically. It's purpose is to be close to the fuel pump and amplify a weak EPA-friendly signal from ECU to a strong 12v PWM required by the pump. Could be a generator, if the communication is more advanced, like LIN, I2C or SMBus.
    Gen3 has a similar one, too. Don't know where it is located.
    But you gave me a good hint what I need to carry in my offroad zip kit. Non-Toyota branded once are like $50.
  15. Feb 15, 2024 at 11:29 AM
    #615
    AZBoatHauler
    So.Arizona
    I know someone working on a bypass module.
    :spy:
  16. Feb 15, 2024 at 11:32 AM
    #616
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Bypass what? Older vehicles had fuel pumps cranking at 100% all the time. The excess pressure was relieved by a valve. Newer ones control the duty cycle of the pump with PWM signal (pulse-width modulated), so it delivers the exact fuel volume at needed pressure. 12 Volts PWM is a lot to ask for from a low voltage ECU, thus there's an amplifier in between.
  17. Feb 15, 2024 at 12:23 PM
    #617
    MaineTundy
    You’re kidding right? As a Gen2.5 owner I’m surprised you carry anything but extra gas.
  18. Feb 15, 2024 at 12:35 PM
    #618
    AZBoatHauler
    So.Arizona
    I wouldn’t call it an amplifier as my understanding is it provides the 12v from a separate wire/source.
    You can jump wires and completely bypass the module that dials down the fuel pump. A plug-n-play bypass module is what I’m referring to.
    https://www.tundras.com/threads/fuel-pump-control-module-ground-side-circuit-voltage-drop.63638/
  19. Feb 15, 2024 at 1:25 PM
    #619
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not even gas. What for? With 38 gal tank I never use more than 2/3 in the woods.
  20. Mar 6, 2024 at 12:37 PM
    #620
    JohnsSR5Pickup
    JohnsSR5Pickup New Member
    2022 SR5
    Side steps, trd air filters
    So mine blew up last month 2022 SR5 EITH Exactly 30k miles. Dealer is in the middle of replacing short Block. I think Toyota should at least extend my warrantee, anybody else agree ??
  21. Mar 6, 2024 at 12:59 PM
    #621
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Sorry to hear that. As much as we all agree an extended warranty would be great, ain't going happen.
  22. Mar 6, 2024 at 1:10 PM
    #622
    Mr Badwrench
    Mr Badwrench New Member
    Every generation had their issues. Well... except for the first gen which was perfect in every way.
    Kidding KIDDING!
  23. Mar 7, 2024 at 7:13 AM
    #623
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Was it suggested you post to the Tundra site by a different social media site? Reddit, FB, etc..
  24. Mar 7, 2024 at 7:15 AM
    #624
    BoulderGT3
    Glen
    For me, I'd rather take the very low chance of a Tundra engine failure vs the electronic gremlins my F150 had that couldn't be identified let alone repaired.
  25. Mar 7, 2024 at 7:41 AM
    #625
    JohnsSR5Pickup
    2022 SR5
    Yeah, I know...But at least they could give me a deal on buying one. I was told in my area a 100k mile powertrain warrantee is about $1500, and I know it's much cheaper elsewhere. Maybe they give me a break, otherwise I'm done with toyota...and on to the next.
    HSrider! likes this.
  26. Mar 8, 2024 at 12:37 PM
    #626
    JohnsSR5Pickup
    2022 SR5
    So I got my truck back today. Mechanic at dealership said #2 main bearing in crankshaft. I asked and he also said it's a defect from toyota and that he believes the manufacturer has since upgraded the bearings. I still have little confidence in its longevity , Although it is nice and quiet and seemingly fine now. I may opt for a 100k ext. Warrantee which inmy case with what I have left on the original one will get me 3 1/2 yrs. To pay off enough to send it packing. We will see. I will post if I get the toyota ext. Warr.
  27. Mar 30, 2024 at 12:10 PM
    #627
    Jamesausman
    Jamesausman New Member
    Phoenix
    2023 Limited OR
    Does the issue seem to be mostly with those built in early 2022?
  28. Mar 30, 2024 at 12:16 PM
    #628
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Supposedly it was remedied in March of 2023 and Toyota has a watch list of vins that could be affected. As of right now the number is .5% of all the tundras built. There is a whole thread about documented engine failures on the pinned threads
  29. Apr 3, 2024 at 7:05 PM
    #629
    farmerj
    farmerj New Member
    john
    2022 tundra off road
    none
    i have a 22 trd off road crew max , and i regret buying it, 45000 kms and turbo crapped out, after a week in shop i got it back and now it burns oil really bad
    taking back to dealer tomorrow...if they cant fix it right this time, im getting rid of it.....and would like to kick the head of engineering in the balls...who designs a truck with all that room under the hood and only have to take the cab off to get to the turbos??
  30. Apr 3, 2024 at 7:21 PM
    #630
    Breathing Borla
    Northern Illinois
    You don’t have to take off the cab
