How come a 2WD Tundra has the 4x4 knob?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by JayKay, Dec 29, 2023.
  1. Dec 29, 2023 at 10:25 AM
    JayKay
    JayKay [OP] New Member
    I just bought a used 2014 Tundra Platinum Crewmax 2WD and on the silver part of the dash left side of the radio, there's a hole for the 4x4 knob next to the AC/heater knob that the previous owner(s) removed. I've seen other Tundras that are 2WD and that part of the dash is flat with no hole and I've also seen Tundras with no 4x4 logo on the tailgate but they do have the 4x4 knob on the dash. Does this mean my Tundra is a 4x4 if I buy that knob when the VIN says its a 2WD? Or any idea what goes in that location of the 4x4 knob?
  2. Dec 29, 2023 at 11:06 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Im sure toyota saves time by only having 1 set if wiring.
    my 2wd has a little coin holding cup that goes in that spot
    snivilous, ryanwgregg and 1lowlife like this.
  3. Dec 29, 2023 at 11:11 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Easiest way to know for sure if you are 4x4 is to crawl under the truck.
    Mater, snivilous, T-Rex266 and 3 others like this.
  4. Dec 29, 2023 at 11:46 AM
    JayKay
    Thank you for that info. I just got off the phone with Toyota and they can't seem to find that coin holding cup for that spot. All they can find is the 4x4 knob. Is it possible for you send me a picture of it so I can show the dealer? Thank you in advance.
  5. Dec 29, 2023 at 11:47 AM
    JayKay
    But how do I know if it's a 4x4 if I go under the truck? What do I look for?
  6. Dec 29, 2023 at 12:01 PM
    APalmTree
    Brandon
    SW Washington
    See if you have a CV axle going into the center of the front hubs. 2wd will just be a flat area behind the center of the wheel.
    T-Rex266 and Shanet421 like this.
  7. Dec 29, 2023 at 12:02 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  8. Dec 29, 2023 at 12:07 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Chances are someone replaced that part and ordered the wrong one..
    I'd say those chances are 100%..:thumbsup:
    Gen 2.5 (2014 to 2021) don't have any kind of OEM 'change holder' in that location.
    BillyB, KNABORES and Shanet421 like this.
  9. Dec 29, 2023 at 12:10 PM
    You’ve got the wrong dash trim piece, or you’re in a 4wd….. there is no coin holder or opening on the 2wd models post 2014 refresh.
    1lowlife likes this.
  10. Dec 29, 2023 at 12:12 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    You could try putting up a 'want to buy' post in the marketplace and see if anyone has a 2WD silver one for sale.
    Some guys replace that part with the black one, it's something I'd like to do in the future.
    They might have the old one sitting in a box in the garage or attic.
    But be warned replacing that part literally requires this....:eek2:
    I've done it..:cool:
    Black Wolf and KNABORES like this.
  11. Dec 29, 2023 at 12:14 PM
    Yup. Been there. Just to dechrome 2 vent rings.
    1lowlife[QUOTED] likes this.
  12. Dec 29, 2023 at 12:15 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    AJT....:eek2::cool:
    ld8c5d7f_a92ff465ef0cb869c5c88cd8236e15a0ef541656.jpgijh4tcdl_2b2568dc4eb1fe785a26d5ff477b1d1f111c83cc.jpg3t3li4jp_f3b720d70370847d82ad9572b161516a71f4f9c7.jpg
  13. Dec 29, 2023 at 12:19 PM
    Shanet421
    San Diego,CA
    I wonder if the 2nd gen coin purse/slot would fit that hole?
    Edit:
    Not likely without modification
  14. Dec 29, 2023 at 12:20 PM
    Pry marks, Someone’s been in there before….
    FrenchToasty, 1lowlife and Hbjeff like this.
  15. Dec 29, 2023 at 12:21 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Either you have a 4wd truck or previous owner damaged the original and tried to replace. But I don’t think a 2wd would still have the plug for the switch.
  16. Dec 29, 2023 at 12:43 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    WTF did they use?
    A crowbar..:eek2:
    That's the kind of person that cuts OEM wiring for audio installs..:mad:
    I do..:cool:
  17. Dec 29, 2023 at 12:44 PM
    Most Toyotas share the main harness across trims. Many options are made easier to add in because of this.
  18. Dec 29, 2023 at 12:48 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  19. Dec 29, 2023 at 1:05 PM
    Shanet421[QUOTED] likes this.
  20. Dec 29, 2023 at 1:05 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Not all 4x4 models have an emblem on the tail gate. Some of us have stickers. Some of us remove those stickers. Some remove the emblems. Case solved.
  21. Dec 29, 2023 at 1:13 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Get up under the truck and take us some pictures. Well tell you if she’s 4x4 or not :typing:
  22. Dec 29, 2023 at 1:14 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
  23. Dec 29, 2023 at 3:55 PM
    JayKay
    My Tundra doesn't have that axle going to the front hub so it's definitely a 2WD. I learned something new today, thank you so much!
  24. Dec 29, 2023 at 4:09 PM
    JayKay
    Thank you everyone for chiming in! I guess one of the previous owners swapped out that silver dash panel from all those pry marks that I didn't even noticed. Happy New Year everyone!!!
  25. Dec 29, 2023 at 4:25 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    That hole in the dash would wear me out looking at it every day.
    If you want I can send you a Buc'Ee's sticker to cover it up...
    Hell, I'll even send you one of my ToyoMafia stickers to cover it..:thumbsup:
    Black Wolf, BillyB and biebs96 like this.
  26. Jan 8, 2024 at 4:35 PM
    JayKay
    Well, I came to a perfect solution to cover up this hole. Even tho my Raiders suck, it actually looks good and fits perfectly with no glue or anything.
    BillyB, Jeff_1974 and snivilous like this.
  27. Jan 8, 2024 at 5:16 PM
    2mchfun
    Lucky you!!! Now just add an aftermarket washer fluid bottle and pump under the hood. Route the hose through the hole. Add a little downspout. Fill the washer fluid bottle with your favorite "beverage additive". After you hit the drive thru take a gulp, remove the lid, hold the cup under the spout and hit the like button momentarily. :drevil:
    JayKay[OP] likes this.
