  1. Dec 3, 2023 at 9:24 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Was looking for an intake tube like the one pictured. Thanks. I've used AEM DryFlow before. No issues. Since watching Project Farm's filters video, I stick with Wix filters.
  2. Dec 4, 2023 at 4:12 AM
    Whelp, my idle is still fucked. Sitting in a drive-thru it shakes and tries to lunge forward. I had to put it in park it got so bad. In park it lopes, then jumps up to about 900, the drops down to around 609 and lopes, then repeats. Pretty sure all the vacuum lines are connected so the only thing I can think now is o2 sensors. I should probably replace my CE light too...
  3. Dec 4, 2023 at 4:28 AM
    10X
    10X New Member
    2002 Tundra AC SR5 V8 4X4
    2002 Silver Sky Met SR5 Access Cab 4WD...4.7L Four Cam EFI V8...4-Speed Automatic ECT Trans...TRD SUPERCHARGER...Tuned Unichip/Harness...TRD Boost Gauge...Doug Thorley Ceramic Coated Headers...Custom AeroTurbine Exhaust...MISHIMOTO Radiator...HPS silicone hoses...True Flow Alloy Intake...aFe Pro Dry S Air Filter...Mobil1 5-30W...NGK BKR7EIX Plugs...Ivan Stewart 16X8 Rims, Grill, Bumper and Mirror Covers...Michelin P265/70R16 LTX2...Donahoe Racing Coil-Over Shock Assemblies...Total Chaos Upper Control Arms...Bilstein 5100 Rear Shocks...Hellwig Rear Sway Bar...4-Wheel Anti-Lock Brake System...Heavy Duty Starter/Heater...Limited Slip Differential...Power Windows/Door Locks/Mirrors...Custom Rear Roll Pan With Dual Exhaust Cuts...Sir Michaels Class III Hidden Hitch...Bully Flip-Down License Plate Frame...Back Seat Mod...A.R.E. LSII Tonneau Cover...Eclipse AVN5435...Focal 165 V3 3-Way System.
    The intake tube was part of the TRUFLOW intake system/filter, the only thing I kept was the tube and attached to the airbox....Well, that and the decal on the firewall. The company stopped making them almost twenty years ago.
  4. Dec 4, 2023 at 4:41 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You checked for codes already?
  5. Dec 4, 2023 at 4:42 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    smooths out above idle?
  6. Dec 4, 2023 at 5:08 AM
    Yes, smooths out at 900 or so. Drives just fine too.
  7. Dec 4, 2023 at 5:09 AM
    Hell no, why would I come at y'all prepared?
  8. Dec 4, 2023 at 6:05 AM
    That kit is discontinued, has been for years. Unless I missed something…
  9. Dec 4, 2023 at 7:56 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Really? Feels like I can drive over a man-hole cover now, instead of actively avoiding them.
    Negatory, good buddy, but I wish I did! *Ahem*Santa*
    Already ordered the HD springs from General, should be here Wednesday...which means I'll be shoot cussin' up a storm trying to get those shackle bolts out this weekend.
    oscardog86 and bmf4069 like this.
  10. Dec 4, 2023 at 8:57 AM
    I don't know how bad your stuff was before. My stock suspension was still fine. These Aluma Boss are definitely stiffer.
    One thing I did notice, I can't notice the absence of my swaybar. Dunno if you had any plans to kill yours, but I get zero front-end sway after coilover install.
  11. Dec 4, 2023 at 9:05 AM
    metalpete
    ID
    Ahh, I gotcha. They probably are a little stiffer than stock. I had a set of OME/5100 on the front, so that might explain our difference lol.
    Interesting about the sway bar, hadn't considered deleting it. I didn't have one side of the SB as tight as the other and felt a bit of sway, so I feel like I would notice the lack of one... but maybe not! Never know until you do, ya know?
    Where are you sitting at, measurement-wise? I think I'm at 23-3/4" now. Gave the collar a 1/4" crank just to see how easy/hard it was.
    oscardog86 likes this.
  12. Dec 4, 2023 at 9:13 AM
    My final measurements here: https://www.tundras.com/threads/how-big-is-yours-measure-up.46186/page-5#post-3333656
    Reply after that is the ground-to-fender measures if interesting.
    metalpete[QUOTED] likes this.
  13. Dec 4, 2023 at 9:45 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I would hit them with some penetrating oil for the few days leading up to the work, always makes things easier for me. PB blaster is my favorite flavor that is available locally.
    oscardog86 and metalpete[QUOTED] like this.
  14. Dec 4, 2023 at 9:45 AM
    metalpete
    ID
    Oh yeah, I've been hitting them for 2 days now lol.
    oscardog86 and JakeJake[QUOTED] like this.
  15. Dec 4, 2023 at 11:36 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    350 horsepower, that's awesome! How much boost are you running?
    455h0le_dachshund likes this.
  16. Dec 4, 2023 at 12:54 PM
    10X
    10X New Member
    Okay, found paperwork. Looks to top out a wee bit over six psi...It's been nine years ago with lots of smiles per mile.
    txagg, bmf4069, FirstGenVol and 5 others like this.
  17. Dec 4, 2023 at 2:19 PM
    rock climber
    Just makes me want to test an SC 1st gen that much more! I'll never be able to buy it, but the idea is cool!
  18. Dec 4, 2023 at 2:28 PM
    rock climber
    I need some parts help. I called the dealership and they were confused also. 01 access cab, bench seat, grey interior. The seat belt buckle for both the middle seat and passenger seat don't work at all. I'm trying to find the part number and they are showing that the driver's side and middle seat are combined and the passenger is it's own. But in my truck it's the passenger and middle set that are the same.
    They gave me a few possible part numbers and I did a ton of research on my own.
    73030-0C011-EO
    73040-0C011-E1
    73230-0C050-E0
    I'm pretty sure grey isn't possible to find so I'm ok with other colors, but need the correct buckle. Anybody have better google fu and can find the correct part number?
  19. Dec 4, 2023 at 2:42 PM
    So here's the deal.
    Those last two digits are the color. IIRC, anything with an "E" in it is tan/brown/beige in color (i.e. browns). Anything with "C" in it is blacks/greys. Anything with "J" in it is blues. The number following the letter is just a color variation, where c0 could be black, while c1 may be dark grey, c2 may be medium grey, you get the idea (that's not actual truth on the 0/1/2, just giving you an idea). E0 may be tan, E1 may be fawn, E2 may be brown.
    The first set of 5 digits is always the part category. Like, anything 73xxx probably involves seats. Where 730xx may be for the front seat, and things ending xxx30 in that group may be front bench seat, xx040 may be front 60/40 split seat, and 732xx may be the rear seat, where xxx30 is the entire bench.
    The second set of 5 digits is typically model variations. It's almost always starting 0Cxxx, and the final 3 digits seems to be variations. Like, xx050 may be for a double cab, which has separate seats and xx010 is for the access cab which has a single bench. While helping a member recently with finding parts on a sedan, a cupholder was either unlit or LED-lit, and xx040 was for the unlit variation, 050 was for the LED backlit cupholder.
    If you can shoot me your VIN I can try and use the EPC-DATA website from the top of this thread to look up your specific part.
  20. Dec 4, 2023 at 4:09 PM
    I hit this on Saturday. Sorry for the shitty pics, I was driving into the sun and almost missed it.
    dbittle, Voss, oscardog86 and 10 others like this.
  21. Dec 4, 2023 at 4:15 PM
    Almost a third of a million. Hell yeah
  22. Dec 4, 2023 at 4:16 PM
    Sounds like vacuum leak or idle air control valve
  23. Dec 4, 2023 at 4:16 PM
    rock climber
    That helps so much! How did I miss that thread? Two options depending on build date, I'll check that tonight.
    Seat belt for Tundra UCK40
    Frame number: 5TBBT44151S142264 Color code: 1C7 Trim code:1C7 Manufacture date: 2000.09
    Here are parts you've selected:
    No PNC#
    (SUB)
    OEM part number Required
    per car
    Production period Name Applicability Please order in advance In stock
    01 73230 73230-0C040-B1 01 02.1999 - 08.2001 BELT ASSY, FRONT SEAT INNER, RH VCK40..ACB..5F
    VCK40..4HC..(LIMD,SR5)
    UCK30,40,VCK30..LIMD,SR5
    MD.CHARCOAL,TRIM11 0.00 USD
    02 73230 73230-0C010-B1 01 02.1999 - 08.2002 BELT ASSY, FRONT SEAT INNER, RH UCK30,40,VCK30,40..4HC..(LIMD,SR5)
    W(6:4 SPRIT SEAT),CHARCOAL,TRIM11 0.00 USD
  24. Dec 4, 2023 at 4:19 PM
    IAC you say? Hmmm, I shall research this.
  25. Dec 4, 2023 at 4:20 PM
    oscardog86 and 455h0le_dachshund like this.
  26. Dec 4, 2023 at 4:26 PM
    Shows the IAC function is handled by the “ECTS” which is all the components and sensors related to throttle body position.
  27. Dec 4, 2023 at 4:26 PM
    It's interesting everything is defaulting to tan, even when it's clearly not a tan part number.
    @FirstGenVol went thru this recently. Toyota apparently discontinued all the parts and has all the part numbers of every color pointing back to the tan part.
  28. Dec 4, 2023 at 4:38 PM
    That's the one I saw too. Has anyone actually had a problem with it? I'm wondering if it might be my fuel filter...
    KNABORES[QUOTED] and NUDRAT like this.
  29. Dec 4, 2023 at 4:41 PM
    So RA sells a IACV for the v6, but not one for the v8. Interesting.
  30. Dec 4, 2023 at 4:42 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I know Iron Man has been in the family a long time. Was your father the original owner?
    bmf4069[QUOTED] likes this.
