Popping backfire? 2006 DC
Discussion in '1st Gen Tundras (2000-2006)' started by Twisted99, Oct 9, 2023.
  1. Oct 9, 2023 at 4:42 PM
    Twisted99
    Twisted99 [OP] New Member
    2018 Crewmax Platinum 4x4
    None, yet
    2006 DC with 189k. No cel. Timing belt done at 106k.
    Took off from a light with the rear window down and heard this squeaky/popping noise. It happens only after a stop, as far as I can tell. Sounds like it's coming from between the bed and the cab, and I only hear it with back window open. Other popping sound I hear is driving at any speed, lift, coast and as soon as I hit gas easy or hard, feel a pop under my feet. only hear it slightly.
    I didn't find anything exactly like it when I searched.
    Sound familiar to anyone?
  2. Oct 9, 2023 at 5:06 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Have you checked your transmission crossmember bolts?
    https://www.tundras.com/threads/inspect-your-transmission-crossmember.74691/
    KNABORES, shifty` and FrenchToasty like this.
  3. Oct 9, 2023 at 5:21 PM
    KNABORES and NickB_01TRD[QUOTED] like this.
  4. Oct 19, 2023 at 3:30 PM
    Twisted99
    None, yet
  5. Oct 19, 2023 at 3:45 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    A backfire would likely fire up the money light.
    JasonC. likes this.
  6. Oct 19, 2023 at 6:03 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    The kids I work with pay big money to make their cars backfire
  7. Oct 19, 2023 at 6:08 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  8. Oct 19, 2023 at 6:09 PM
    Twisted99
    None, yet
    Yeah, I know, and no light. I'll check for codes over the weekend.
  9. Nov 12, 2023 at 12:47 PM
    Twisted99
    None, yet
    Ok, so I checked the transmission 2 bolts not real tight, tighten them, banging noise worse. Rear u joint on drive shaft is bad.
    Read a little and checked YouTube, what's the best path for this? Should I replace the entire drive shaft $663 shipped for a Dorman, or repair the old one?
  10. Nov 12, 2023 at 12:49 PM
    Which u-joint are you speaking about, so we better understand? U-joints are typically replaceable. Got a pic, it's worth 1,000 words?
    bfunke likes this.
  11. Nov 12, 2023 at 1:00 PM
    Twisted99
    None, yet
    Rear of rear half of drive shaft. One at the rear diff. Carrier boot / bushing looks bad too
  12. Nov 12, 2023 at 1:51 PM
    bfunke
    bfunke Tundra Curmudgeon
    Replaceable parts. Get Speicher carrier bearing
  13. Nov 12, 2023 at 2:59 PM
    What he said ^^
    And if you don't feel confident doing the work, take to a shop that deals with drivelines specifically, request they use Spicer. They should be able to knock out the work in less than an hour, easy peasy. I wouldn't hit up a chain store. Same with A/C stuff, always hit the shop that specializes in auto A/C.
  14. Nov 12, 2023 at 6:18 PM
    Twisted99
    None, yet
    Just checked everything again. Looks like the other 2 u joints are good, I can't tell about the carrier
  15. Nov 12, 2023 at 6:21 PM
    Twisted99
    None, yet
    Changed out just the rear U joint. ALL thumping and "chirping" is gone. I'll keep an eye on the carrier, but everything feels solid.
    THANKS EVERYONE!
    bmf4069, JasonC. and FrenchToasty like this.
  16. Nov 12, 2023 at 6:27 PM
    You live in Phoenix?
  17. Nov 12, 2023 at 6:45 PM
    YW. Just a heads-up, and others here can vouch I'm the last guy who hassles anyone about carrier bearings, but ... you really should change that carrier bearing sooner than later. If you've never done one, make sure you mark the driveshaft orientations so you can line it all back up proper.
    It's not like it's gonna fail tomorrow, but that seal is proper effed up, and if it's not causing a ruckus now, it probably will be in the next 10-15k miles or 1-2 years.
  18. Nov 12, 2023 at 6:56 PM
    Twisted99
    None, yet
    about 40 miles east of Phoenix
  19. Nov 12, 2023 at 6:57 PM
    The greater basin, close enough.
    des2mtn likes this.
  20. Nov 12, 2023 at 7:00 PM
    Twisted99
    None, yet
    I'll do it way sooner than 10k or a year. When I can plan it. Need truck to get to work, so I was just trying to get up and running. Yeah I know about marking them. when I went to mark it tonight, it already had white marks, so apparently previous owner had it done before
    FrenchToasty and shifty`[QUOTED] like this.
  21. Nov 12, 2023 at 7:35 PM
    I’ll take a wild stab and say they used shitty off-brand parts. :rofl:
    If true, it never fails to amaze me how willing people are to spend 25-50% less to do the job 3x within the same timeframe OEM would’ve lasted them.
    bfunke and FrenchToasty like this.
  22. Nov 23, 2023 at 5:29 AM
    Twisted99
    None, yet
    Weeeellll, I did the same thing. Duralast. Not much of a choice, needed it to get to work. If it lasts 10k, it was worth the $28,to not have to get a ride to and from work.
  23. Nov 23, 2023 at 6:18 AM
    Not knocking, just saying. If the PO marked it, they probably changed it and here you are changing it again. $28 isn’t much of a loss to cut, toss in OEM (Spicer) and be done. Hell you may even be able to take the old part back if you have box and receipt.
    Fortunately, the carrier bearing doesn’t have a photo graveyard the same way non-OEM balljoints do, showing truck after truck after truck destroyed, because the owner opted to use non-OEM parts. There probably quite a few bad things that could happen from that center support bearing failing, but none that will potentially total the truck, and potentially you along with it.
    There are definitely places in cool with non-OEM and even encourage it. Based on real-world experience, bearings are one that I’ll always tell you to use Dana/Spicer, they’re good enough Toyota chose them to be the OEM. We have a dedicated 1st gen thread for good OEM alternatives (and parts to avoid) to boot.
  24. Nov 24, 2023 at 4:20 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I love the sound of an unrestricted straight six at idle. That smooth low rumble reminds me of vintage mahogany Chris Craft boats with the flat head six.
    Mr.bee[QUOTED] likes this.
  25. Nov 24, 2023 at 4:41 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Thats still got a cat & a glasspack for a tractor.
    tvpierce likes this.
  26. Nov 24, 2023 at 6:36 AM
    Twisted99
    None, yet
    Yeah, I'm good with the joint being nonOEM. i did the ball joints last year and went with OE without even considering AM. So ill pick and choose.
    I had the front ujoint on my first car come apart and the drive shaft drop minutes after getting off a highway.
    shifty`[QUOTED] likes this.
