General Supercharger Thread
  1. Nov 9, 2023 at 11:17 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Looking at old acceleration videos I have punching it from a cruise, even on the 80mm pulley it comes in pretty fast if you quickly crack open the throttle.
    1500rpm - 4psi
    2k - 6psi
    2800 - 7psi
    4000 - 8psi
    4500 - 9psi
    I’m sure it hits both harder and faster now on the 77.5.
    ARES35, Mdl and armyoffoo like this.
  2. Nov 9, 2023 at 11:20 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    ARES35, Saltyhero13, Mdl and 3 others like this.
  3. Nov 9, 2023 at 11:25 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Wow...I need to get some logs so I can see what mine's doing on the 85mm
    ARES35, Mdl and Silver17[QUOTED] like this.
  4. Nov 9, 2023 at 11:58 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    ARES35 and Mdl like this.
  5. Nov 9, 2023 at 12:19 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah...it's pretty janky, but the more I think about it...the more I think it would work. You could get a real BOV and come up with a solution where it was sealed until it pressurizes...it shouldn't cause a vacuum leak, and you'd get the zu-too-too and pssh pssh noises as a bonus!
    https://www.youtube.com/watch?v=4PwqaYY42I8
    hoof hearted, ARES35 and Saltyhero13 like this.
  6. Nov 9, 2023 at 1:15 PM
    Silver17
    Eastern PA
    I do like your thinking here honestly. I just wonder if a small 1/4” pressure relief will adequately bleed off the excess pressure/volume to keep it from going over 10psi, it might since most of the volume will still be going into the cylinders? It’s just a lot smaller than the bypass valve diameter. I’m also curious about the ability of those relief valves to open and close and seal well after hundreds to thousands of cycles. Keep some extras in the glove box I guess lol.
  7. Nov 9, 2023 at 2:05 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Normal driving will hit 5lbs. Big pedal gives me 9.5lbs around 3k rpms
    ARES35 likes this.
  8. Nov 9, 2023 at 6:37 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
  9. Nov 9, 2023 at 7:32 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
  10. Nov 9, 2023 at 9:37 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Looks like a good mod for the Harrop
  11. Nov 9, 2023 at 10:32 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    We don’t need no stinkin throttle body!
  12. Nov 10, 2023 at 12:35 AM
    blenton
    blenton New Member
    mZiggy[QUOTED] likes this.
  13. Nov 10, 2023 at 2:42 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I definitely see boost very very quickly. Cruising and light blip of slight acceleration 6psi
    Mdl likes this.
  14. Nov 10, 2023 at 6:15 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  15. Nov 10, 2023 at 6:40 AM
    mZiggy
    mZiggy Honey badger
    Marc
    These are intended as a one-and-done as you say, so that someone can take it and run it confidently like they would the Magnuson calibration for example.
    appreciate you sir
  16. Nov 10, 2023 at 7:00 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    HulkSmurf14 and armyoffoo like this.
  17. Nov 10, 2023 at 7:06 AM
    e30cabrio
    Nope, belts and pulley ribs are universal.
    seems to me if it’s one rib bigger should be ok but what do I know?
    lol
  18. Nov 10, 2023 at 7:09 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Well it is a "General Supercharger Thread"...so I guess we can let it slide :D
    The 6-rib belt "should" work on the 7-rib pulley if the ribs line up...but you'll probably go through belts faster if there are any alignment issues. Might want to run it by a Bimmer forum.
    M3Tundra-JK and Wynnded like this.
  19. Nov 10, 2023 at 7:12 AM
    e30cabrio
    Thanks, I did. In a thread specifically about this set up, the previous last post was in 2011 & it's been a few days, nada.
    lol
    https://www.bimmerforums.com/forum/...Rotrex-S-C-on-s52-Z3M&p=30916339#post30916339
    Also, as far as the fitment, it is just a need to mess with the hoses to fit the hood slope, I found several YouTube videos where the issue is resolved.
    I need to find a meth kit now too.
    Mdl and M3Tundra-JK like this.
  20. Nov 10, 2023 at 7:14 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    One rib bigger is fine. On my supercharged LS the supercharger pulley is actually two ribs bigger and the belt spacing ends up using the 6 middle ribs out of the 8 total. As long as the spacing is fine I wouldn't worry.
  21. Nov 10, 2023 at 9:16 AM
    nags
    nags New Member
    Just stopped by the holy land.
  22. Nov 10, 2023 at 9:44 AM
    VWTim
    Corvallis, OR
    Went and ran a few logs:
    Harrop
    85mm pulley
    DW650's
    stock airbox for now (Maggy lid waiting)
    Stock TB
    650' elevation (Hutto, TX)
    55 deg and misting (DA ~700')
    Stock exhaust and manifolds (axle cut)
    AFR's 9.4-9.8 (will lean/smooth out a tiny bit)
    MAF 4.98V @ 6,000RPM
    Inj DC @70% @5,600 75% @6,000 (has me worried about the 80 and 77.5mm pulleys in the garage)
    Knock feedback good
    KCL is 18's (19 at low load/RPM)
    Going to smooth the AFR's a little bit then will work on a Dragy run when it stops raining. (who'd crossed into Nuevo Laredo, MX recently?)
    I'm also building a test rig to log after TB inlet vacuum and outlet boost via the Prolink. We went down the rabbit hole of compressor inlet restrictions a while back and I'd like to log what happens with the following: SABM, Maggy Airbox top, then get into larger TB's (I snagged one of @snivilous Harrop to LS adapters a few months back)
    ARES35, ZPhilip, Mdl and 5 others like this.
  23. Nov 10, 2023 at 10:01 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Guessing you'd hit the max MAF voltage before the max injector DC.
  24. Nov 10, 2023 at 10:12 AM
    VWTim
    Corvallis, OR
    Not too worried there, the Maggy box should get me back onto the tables.
    Wynnded[QUOTED] likes this.
  25. Nov 10, 2023 at 11:10 AM
    e30cabrio
  26. Nov 10, 2023 at 11:13 AM
    nags
    nags New Member
  27. Nov 10, 2023 at 11:21 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Mdl, e30cabrio[QUOTED] and reywcms like this.
  28. Nov 10, 2023 at 12:42 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  29. Nov 10, 2023 at 12:58 PM
    e30cabrio
    Mdl[QUOTED] and HulkSmurf14 like this.
  30. Nov 10, 2023 at 1:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The 50/50 mix can help you with timing and run it a little leaner for more power with the larger nozzle pintles.
    I haven't noticed it affecting my afr's at the 70/30 mix and I have no way of measuring IAT to see if additional cooling is happening. Just trusting the literature and experiences of others.
