Leather seats loudly creaking when sitting back?
Discussion in '3rd Gen Tundras (2022+)' started by RickyBobbysTundra, Feb 9, 2023.
  1. May 2, 2023 at 1:45 PM
    rozemab
    rozemab New Member
    My 2023 Platinum just started this week. Third week of ownership with only 800 miles on the clock.
    I'm a big man, 300. 5 ft 14 inches.
    certainly not acceptable!
  2. May 2, 2023 at 7:57 PM
    LimitedFL
    LimitedFL New Member
    Kal
    2023 Limited
    You're 6'2 lol
  3. May 3, 2023 at 7:16 PM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    The 22 Limited had the same problem but no issues with the 23 Plat.
  4. Aug 1, 2023 at 12:46 PM
    RickyBobbysTundra
    RickyBobbysTundra [OP] New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Dealership also got me sorted after months of going back and forth between them and Toyota Corporate.
    I believe the answer was a fixed released by Toyota. Before the dealership tried replacing some of the plastic covering of the seat ventilation. That actually made things worse. Then they tried something and that didn't work. Then Toyota came out with a bulletin and that fixed it. No issue since then.
    Tundrastruck91 likes this.
  5. Aug 1, 2023 at 1:05 PM
    CRFL82
    CRFL82 New Member
    SWFL
    2023 Lunar Rock SR5/TRD Sport
    Did your invoice / paperwork from the dealer have any reference to a bulletin put out by Toyota? I'm going through this battle right now and it has been an absolute joke.
  6. Aug 1, 2023 at 1:05 PM
    Breathing Borla
    Northern Illinois
    there isnt a TSB yet
  7. Aug 1, 2023 at 1:56 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Ugh...I gotta stop reading these threads. You guys are depressing me. I'm 6'4 and around 260#.
    So far, my seats don't make any noises, but I've only put 132 miles on my 2023 1794.
    My wife and I are going on a 17 hour roadtrip in a week. That should be a good test to see if Toyota has fixed this problem, or not.
  8. Aug 1, 2023 at 2:07 PM
    rdavenp3
    rdavenp3 New Member
    6’ 2” 225 lbs. My seat back starting making noise at about 2k miles. Will have it fixed when I bring it in for 10k service.
  9. Aug 1, 2023 at 2:25 PM
    CRFL82
    CRFL82 New Member
    SWFL
    Fortunately it isn't a super horrible problem, mainly an annoyance. Service manager at my local dealer tried to say that's how they all were, but when I got him to take a look at the new ones they had on the lot (awaiting pickup), none had the issue. I haven't fought it too hard but I did make the issue known fairly quickly. If/when Toyota issues guidance on the issue I'm hoping they will be able to fix it without the need to "try" a bunch of stuff.
  10. Aug 2, 2023 at 6:10 AM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    I posted this in another thread about the seats creaking. Seats have been quiet for several months.
    batman900 likes this.
  11. Aug 2, 2023 at 6:43 AM
    nodak67
    nodak67 New Member
    JR
    my 23 plat (dec-8-2022 build) only the driver seat squeaks when pressing the center. had them check, couldnt dupe but not surprising as no tsb is out. will re-address once the tsb comes out.
  12. Aug 17, 2023 at 8:26 PM
    WoodyOne
    WoodyOne New Member
    Spring, TX
    Mine have gone quiet also. I wonder if the 150 degree internal temperatures in the Texas heatwave have melted something.
  13. Aug 18, 2023 at 2:11 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    My 1794 drivers seat would creak but after I sprayed some DuPont Silicone spray on the rods and white plastic clips the creaking is no longer noticeable. It’s been two months .
  14. Aug 18, 2023 at 2:20 PM
    LR Pro 2022
    LR Pro 2022 New Member
    2022 LR Pro
    Mine did the same at first but haven’t noticed it in a while.
  15. Oct 25, 2023 at 5:48 PM
    Billm
    Billm New Member
    I had this issue by day 3 with my 2023 1794. Dealer ordered a upper seat assembly, waited 3 weeks for the part. After repair the sound was gone…..1 month later it’s back. I have chased more sounds and rattles in two months from this truck than anything else I have ever owned. Headliner, seatbelt, plastic cup holders, armrest, glovebox. I have to admit I am extremely disappointed in this truck. If I wouldn’t lose my butt at this point, I think I would get rid of it. Life is too short to live with aggravation. Toyota, you can do better than this. Rant over. I am new to the group, so sorry for being a negative Nancy .. I am going to take it to the dealer again.
    Soupbean77 likes this.
  16. Oct 25, 2023 at 6:17 PM
    Breathing Borla
    Northern Illinois
    this, but I used WD40 dry lube
    shot down the headrest post hole as well.
    silent and hasn’t come back ,
    it’s the metal rod, plastic near the top of the seat beneath the head rest mounts , I unzipped the seat and hit this area and put a shot or two down the mount holes with the headrest removed
    Dry lube doesn’t go away as fast as regular lube IMO
    pwpblue likes this.
  17. Oct 27, 2023 at 8:48 AM
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    Everything I’ve read in both of these threads show it to be an issue with the driver’s seat only. To me, that points to lumbar specific issue since that’s the only difference. I tried LouALouA’s fix, and I think it might be a little bit quieter(?) but hard to tell. It’s definitely not gone. I think he’s onto the right area, but I’m not sure I’m getting enough of the lube in there. It’s hard to get your hand up that high by just unzipping it, and I’m not risking taking it apart. Hoping someone here posts a TSB number soon.
  18. Oct 27, 2023 at 9:16 AM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    The top of the seat area is the hardest to get at. See picture in my original post. So I built a rig. I used the end of a pen, where the actual writing bit comes out. Attached that to fish tank tubing. Packed pen part with silicone based grease. Tyraped it to a popsicle stick. Tyraped the other end of popsicle stick to endoscope so I could see when pen part was directly at point which I wanted to lube. Then I blew through tubing to force grease at desired point. No seat disassembly was required. Seat has been completely quiet for six months and 5000 miles. upload_2023-10-27_12-15-53.jpg
  19. Oct 27, 2023 at 10:14 AM
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    That is so cool! I wish you were my neighbor…we would get along great!
    Hella Krusty likes this.
  20. Oct 28, 2023 at 4:20 AM
    #50
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    2023 limited, January build date. I took delivery of the truck late on a Friday night and first noticed the drivers seat back popping and creaking when I got in it the next day. A couple months ago the wife and I were going somewhere and I said “check this out”, leaned back, and let her hear the loud creaking.
    She said, I can do that too… she leaned back in the passenger seat and it was creaking too but not as bad as drivers side. I know there’s a bunch of stuff stuffed into those seats… heat, ventilation motors for seat adjustment. But this is unacceptable for a $60,000 vehicle.
  21. Oct 28, 2023 at 4:59 AM
    #51
    Tundra_Jim
    Tundra_Jim New Member
    2024 Tundra Platinum
    Upper part of both my driver and passenger seats in my 24 platinum have made this noise in I picked it up.
  22. Oct 28, 2023 at 5:12 AM
    #52
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Same here. To me it's poor quality.
  23. Feb 6, 2024 at 3:01 PM
    #53
    Chomponthis
    Chomponthis New Member
    Billings, MT
    2023 Tundra Limited Cremax 4x4, TRD OR
    Has anyone found out if there is a TSB on this issue yet? My local dealer replaced my driver seat and the new seat makes the exact same noise.
  24. Feb 13, 2024 at 11:59 AM
    #54
    TTRD
    TTRD New Member
    Took my 24 TRD Pro in today for some issues including seat having the same noise. They claimed it was jus the leather and not a problem. They had another TRD Pro on the lot. That seat did not make any noise. They told me to call on Monday with the service manager is back in. They seem to be very dismissive of the issue. I'm in for the long haul and will find a solution.
  25. Feb 13, 2024 at 12:45 PM
    #55
    Hella Krusty
    Hella Krusty New Member
  26. Feb 13, 2024 at 2:53 PM
    #56
    iforceAZ
    iforceAZ New Member
    Mine did this for a month or two. Then it went away.
  27. Feb 28, 2024 at 5:11 PM
    #57
    paulphilly
    paulphilly New Member
    Paul
    Upstate NY
    '24 TRD Pro
    Dealer replaced my whole frame, noise still there. Regional rep came in and applied tons of dialectric grease, noise still there. Regional rep applied Velcro tape around metal rods and connectors while seat torn apart again, noise still there. Filed a claim with Toyota and letter stated they find no fault and are within the limits of the warranty. My wife refuses to ride in the truck now because the passenger side does it. Drivers side is so annoying that I get frustrated driving it. The regional rep said no permanent fix as of now and the band-aid fix is what the engineers at Toyota recommend. I’m shocked that after two years now the ‘22,’23, and ‘24 models are still having the issue. What has happened to Toyota quality? Oh, I had to have my rear tail lamp replaced 3 times due to particles and bugs being trapped inside housing, along with multiple rattles in the interior. I’m embarrassed to have occupants inside my $75k truck. And, it’s obvious Toyota corporate doesn’t care.
  28. Feb 28, 2024 at 5:48 PM
    #58
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    Mine creaks, too (6’3”). Service manager sat in 3 new ones on the lot and they all did it….chalked up as normal characteristic, at this point. There are a few things I’m on the list for, if any solutions are put out by Toyota for said issues. The gas gauge issue, seat creak, whistle above 55mph from outside mirror and rattling window.
  29. Feb 28, 2024 at 5:58 PM
    #59
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My Limited doesn't have creaky seats or whistles,
    I did have the gas gauge act up once. I know that fix isn't out yet. That will probably be out and ready right after the Gen 4's are launched :)
  30. Sep 13, 2024 at 1:43 PM
    #60
    weekend.hobolander
    weekend.hobolander New Member
    Darrin
    2024 Platinum
    Just picked up my 2024 Platinum and have the same problem with less than 100 miles on it. Made an appointment at my local dealership to have it checked out.
