  1. Aug 28, 2023 at 11:42 AM
    Jasons2006Tundra
    Jasons2006Tundra New Member
    2006 Tundra DC SR5 4wd 4.7 TRD
    Can you point me to info on how to properly clean the condenser?
  2. Aug 28, 2023 at 11:46 AM
  3. Aug 28, 2023 at 11:53 AM
  4. Aug 28, 2023 at 11:55 AM
    The condenser is in front of the radiator behind the grill. Spray cleaners that are safe on aluminum are fine to use here to get the gunk loosened up, then just hose it down with water. Don't try to scrub it, you'll likely bend the fins which kills airflow. Even just rinsing with water can improve the performance.
  5. Aug 28, 2023 at 11:57 AM
    Ah, yup, totally missed that.
    Then again, one of the two may've meant evap, not condenser, but ... Meh.
  6. Aug 28, 2023 at 12:02 PM
    They touched on it in previous comments. I sprayed mine down with some EVAP foam I had. Then I used a gentle setting on my hose to rinse it all off. Repeated this twice. Pretty simple. Just don't turn your hose on blast or you'll bend the fins.
    des2mtn and FrenchToasty like this.
  7. Aug 28, 2023 at 12:08 PM
    I've not had luck with the EVAP yet. That kit from Toyota is the ticket but I'm too cheap right now. They want like $43 for it.
  8. Aug 28, 2023 at 12:32 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I bought an expansion valve, schrader valves, and an o-ring kit to replace along side my condenser. I'm going to blow air and vacuum the evaporator while I'm in there and probably do the Toyota foam. Also need to re-read the cabin filter thread and order that stuff.
    txagg likes this.
  9. Aug 28, 2023 at 12:46 PM
    Is the expansion valve at the evap? How hard will that be?
  10. Aug 28, 2023 at 12:50 PM
    des2mtn
    SW
    Tonto cover
    Yup, it looks like the valve itself comes easy, but I'm not sure if I'll have to fully remove this or if I can just take off the lower half.
  11. Aug 28, 2023 at 12:52 PM
    I'm just praying mine never stops working because it seems like a lot to figure out and fix.
    What is this part?
  12. Aug 28, 2023 at 12:57 PM
    des2mtn
    SW
    Tonto cover
    The tube canister thingy is your receiver/ dryer and that's a sight glass on top. Ridgelines have these built into the condenser. That black cap is where the schrader valve for checking your high pressure refigerant charge is.
  13. Aug 28, 2023 at 1:00 PM
    Jasons2006Tundra
    Thanks for the info everyone, I guess I'll clean both the evap and condenser.
    FrenchToasty and des2mtn like this.
  14. Aug 28, 2023 at 2:11 PM
    Got inspired and did the FGT when my sone got home
    bunch of pine needles and trash in there
    used this foaming coil cleaner I had to fully foam it through the opening inside.
    Resistor was a little corroded, cleaned the contacts with some alcohol to remove the buildup.
    ktundra, sportbike37, NUDRAT and 5 others like this.
  15. Aug 28, 2023 at 5:42 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    So following up on this since I am a little pissy about the situation, but Inno finally got back to me on the return on their rack system and they're charging me $100 to ship it back to them claiming their returns are usually free but being that the rack system should "fit your truck" they are not giving me that free return. I'm not sure what else to do as I recorded a whole video and emailed it to them showing how the mounts do not fit correctly on my truck. AND after calling Inno directly and speaking with someone who actually builds the rack systems they told me(in a challenging accent) that the set I ordered from them WOULD NOT fit my truck as the mounting system is incorrect. But hey, a company's customer service team knows more about the product than the people who actually design it right? That $100 could have gotten me 3/4 of a tank :mad:
  16. Aug 28, 2023 at 5:57 PM
    Welp. I guess this is why nobody on this forum should be buying Inno products in the future.
    This is the kind of thing I'd blast the company with on Twitter. It's the only way you're going to get past the riff-raff.
    And if you bought this with a credit card, you may just want to dispute the charge. I know AmEx covers me in situations like this.
    ktundra, NUDRAT, oscardog86 and 2 others like this.
  17. Aug 28, 2023 at 6:50 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I like it - it's your truck, you do your thing. Looks good
    But more importantly, those wheels... I'm not a big aftermarket wheel guy, but those look SHARP.
  18. Aug 29, 2023 at 3:58 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Maybe not impossible but highly improbable.
    Back 2 screws and clip could be a bitch !
    From a 2005 Tundra.....
    des2mtn[QUOTED] likes this.
  19. Aug 29, 2023 at 11:06 AM
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    Thank you. Those wheels are Icon's. I got them on 1stGenOffroad about a year ago. I like them, but I kinda wish I had gone with the bronze ones instead of the gunmetal
    SateenC1 likes this.
  20. Aug 29, 2023 at 2:02 PM
    bfunke
    bfunke Tundra Curmudgeon
    DO NOT CHARGE INTO HIGH SIDE. Recharging is done into the low pressure side and pressures are monitored on both sides. Connecting a can of coolant to the high pressure side can cause it to rupture sending shrapnel everywhere.
  21. Aug 29, 2023 at 2:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    ^ this.
    des2mtn likes this.
  22. Aug 29, 2023 at 2:04 PM
    des2mtn
    SW
    Tonto cover
    Yeah good catch, meant checking while you charge the system etc.
    assassin10000 likes this.
  23. Aug 29, 2023 at 7:46 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Well if you need to unload them, I’ll be here!
  24. Aug 30, 2023 at 2:27 PM
    Now both codes after switching 6 and 8 ignition coils. :confused:
    Ill swap out both with extras i have to see what happens. Maybe the ECU will eat more coils.
    BubbaW[QUOTED] likes this.
  25. Aug 30, 2023 at 2:43 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  26. Aug 30, 2023 at 2:46 PM
  27. Aug 30, 2023 at 9:18 PM
    Archive
    Archive New Member Vendor
    Eric
    '22 Tundra CM 6.5' TRDOR
    Archive Garage Suspension
    Desert Season, Hunting Season is here, Crazy 15% Sale, including our 1st gen leaf springs and Ultimate Off Road Package!
    www.archivegarage.com
    Kimosabe, oscardog86, shifty` and 5 others like this.
  28. Aug 31, 2023 at 6:49 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Thanks for the heads up! Been wanting to get the MD leaf springs and U bolt flip kit and now seemed like the perfect time. Just made my purchase!
    NUDRAT, 805Tundra, JasonC. and 4 others like this.
  29. Aug 31, 2023 at 7:23 AM
    Archive
    Eric
    Thank you!
    oscardog86[QUOTED] likes this.
  30. Aug 31, 2023 at 10:58 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    15AUG35 is an online-only code at Advance, 15% off any order over $35.
    artsr2002 and oscardog86 like this.
