  1. Aug 2, 2023 at 4:07 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Yes, hard to see in the mid day sun but they are on.
  2. Aug 2, 2023 at 4:50 PM
    Cummins3500
    Logan
    Finished up one side of the rear door power outlets today. The usb outlets are wired to the seat heater circuit via an add a circuit tap. The cigarette lighter plug is tied to the cig circuit via a fuse tap. Each outlet has its own dedicated ground from the engine bay to cab. The only adjust I’ll have to make is the seat heater circuit appears to be constant power at the fuse panel (my fault for not checking) so I’ll probably swap it to power outlet circuit and be done with it. Other option would be a relay tied in line. 2 pair 14 gauge wire feeds the outlets btw
    Filthyphil, SateenC1, Mr.bee and 10 others like this.
  3. Aug 2, 2023 at 5:23 PM
    daveeasa
    I'd recommend a clean power source off the battery (fused) and a high current relay, switched off power outlet, then to a fuse block. Either 5 or 8, then feed the old power socket with a usb from one circuit on the fuse block and the rest of your stuff off the others. Good peace of mind. Can use a maxi fuse holder in the kick panel and one good ground to the fuse block if you have room for one with a ground.
    Just makes life so much nicer, all you're using the poutlet stuff for is to switch the relay. Most stuff in the cab I want ignition switched so it's all dead when key isn't in.
    oscardog86, BubbaW and Cummins3500 like this.
  4. Aug 2, 2023 at 6:21 PM
    danb
    danb New Member
    Minnesota
    2018 Tundra DC Looooooong bed
    So my truck makes this annoying ass clunking whenever giving it gas from a dead stop and when slowing down a crawl. I'm guessing its the drive shaft coupler / bearing? Shits rusted to hell. Would I be better off replacing the whole damn shaft?
  5. Aug 2, 2023 at 6:37 PM
    shifty` Oh, I have felt Cobain's sarcoma
    That is one of the basics covered in this thread, which you should read.
    But if you just want to go to the likely solution instead of reading about your truck, here:
    https://www.tundras.com/threads/grease-your-drive-shaft-you-lazy-sods.55067/
    oscardog86 likes this.
  6. Aug 2, 2023 at 6:52 PM
    bfunke
    bfunke Tundra Curmudgeon
    @danb - try greasing the zeros on your driveshaft. Follow Shifty’s advice
    JasonC. likes this.
  7. Aug 3, 2023 at 9:14 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As I await the cabin filters from the 2 developers, thought I'd take a look see at the EVAP coils area for first time in 19 years. Actually not as bad as I would have thought considering outside parked under an oak tree. Was able to vacuum most of it out for now. Full coil clean via partial dash removal when it's time, even if it's not till fall considering this god forsaken heat.
  8. Aug 3, 2023 at 9:32 AM
    Mine looked about the same. I tried cleaning mine out with generic foil cleaner but it didn't work. It just came right back out the drain. The kit Toyota sells comes with a barb that keeps the foam in place.
    BubbaW[QUOTED] likes this.
  9. Aug 3, 2023 at 9:37 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks, I'll be traveling to the big town next wk for prostate MRI and have it added to my Toyo Dealer list :)
  10. Aug 3, 2023 at 9:45 AM
    It's worth mentioning there are standard non-auto liquid you can buy that professional HVAC guys use on the coil/compressor boxes outside your house. If you pop out the resistor, there's no reason you can't do a direct application to the evap coil, let if foam, toothbrush on a stick to the coils, rinse, repeat as needed. There's even no-rinse options out there.
    FirstGenVol likes this.
  11. Aug 3, 2023 at 10:28 AM
    Good point. That's what I bought and tried to force it in through the drain. I'll just soak it down from inside the truck next.
  12. Aug 3, 2023 at 11:54 AM
    danb
    danb New Member
    Minnesota
    Yup everything's been greased, double grease guns and bumper jumping. Read through that guide a few times before I bought my truck.
    Greasing didn't solve the issue. Only clunks when leaving, or coming to, a complete stop. Not a vibration issue.
  13. Aug 3, 2023 at 12:42 PM
    If you sit stationary, foot on brake, shift into D, release the brake and roll forward 12", any clunk?
    If you brake, shift into R, release brake and roll back 12", any clunk?
    Have you grabbed at various places on the shaft and pushed/pulled? It's normal for the carrier bearing to have 1/4"-1/2" of play in either direction, as long as bearing housing isn't loose.
  14. Aug 3, 2023 at 12:53 PM
    danb
    danb New Member
    Minnesota
    Theres probably half an inch of play side to side. No clunking in the driveway trying what mentioned. Rubber in support bearing looks fine. Whole driveshaft is rusty as hell, considering picking this replacement shaft up from O Reillys since its in stock here. https://www.oreillyauto.com/detail/...-truck-2006-toyota-tundra?q=drive+shaft&pos=1
    I will take some wall thickness measurements on my driveshaft today to see how much is left. Think OEM driveshafts have a wall thickness of 0.083 inches.
  15. Aug 3, 2023 at 12:55 PM
    Yeah, I'm probably just a spoiled southerner, but I'd be replacing that carrier bearing yesterday already.
  16. Aug 3, 2023 at 1:17 PM
    danb
    danb New Member
    Minnesota
    Midwest rust sucks ass. Wall thicknesses are pretty low, about 25% loss in the couple spots I checked. Guess I'm going to slap the o reillys one in today.
    bmf4069, oscardog86 and Jack McCarthy like this.
  17. Aug 3, 2023 at 1:22 PM
    That’s a cool instrument. I could’ve used something like that when I made the bad decision of not getting a full cat-back exhaust and only getting the muffler and resonator section instead.
    Later found the front pipes were paper thin and were the reason for most of my exhaust leaks.
  18. Aug 3, 2023 at 1:38 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Yea that device looks pretty useful! Then I went and looked at the price of them and decided its not for me, lol
  19. Aug 3, 2023 at 1:38 PM
    danb
    danb New Member
    Minnesota
    Damn, that sucks. If you google "non destructive testing" near you, most places should have a version of this technology and maybe take some readings for you for free. Takes less than 5 minutes for someone who knows what they're doing
  20. Aug 3, 2023 at 1:39 PM
    danb
    danb New Member
    Minnesota
    yeah they dont give them away. probably why work gave me this 10 year old unit thats beat to shit. still works though!
  21. Aug 3, 2023 at 1:45 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Damn, that's nasty. I'm curious to see what the inside of the yoke looks like (in-between the carrier, after you un-stake the nut). Not counting the rust removal, but the carrier replacement isn't too bad at all.
  22. Aug 3, 2023 at 1:51 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That's about what mine looked like. Inside was perfectly fine.
    metalpete[QUOTED] likes this.
  23. Aug 3, 2023 at 1:55 PM
    metalpete
    ID
    That's good to hear. Never thought I'd be glad to live in ID, until I see pictures like that.
  24. Aug 3, 2023 at 3:24 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Don't forget to chock off your wheels.
  25. Aug 3, 2023 at 4:24 PM
    Azblue
    The Dirty T ( ^_^)_且
  26. Aug 3, 2023 at 6:16 PM
    danb
    danb New Member
    Minnesota
    Yup, wasn't until the shaft popped off the diff that I realized I had forgotten to chuck in the chocks... if there had been a piece of coal between my buttcheeks I wouldve popped out a diamond.
    New drive shaft on. Truck is a lot quieter inside, but still getting the clunk. A new squeak too. The new driveshaft didn't have any zerks on the cardan joint, is that normal? Just one at each end of the shaft that were painted over.
    Funny thing is the kid at o reillys had the exact same truck, same year, same color, everything. He said just to order a driveshaft off ebay and return this one once it came in, save $300
  27. Aug 3, 2023 at 6:25 PM
    Sounds like you need to strap a Gopro under the truck to watch for movement.
    Is it possible the brakes are being late to grab/release?
  28. Aug 3, 2023 at 6:26 PM
    metalpete
    ID
    How about the transmission mount and the cross member it's attached to? What do those look like?
    Mr.bee likes this.
  29. Aug 3, 2023 at 7:56 PM
    danb
    danb New Member
    Minnesota
    thats a good idea, can rig a mount up and drive around with it.
    i gotta take a look again in the morning, but I think you're onto something. did some reading tonight and looks like a service bulletin was released about it: https://www.tsbsearch.com/Toyota/T-SB-0067-09
    this video https://www.youtube.com/watch?v=jskN3pgpW_Q sounds like the dude has the same problem and fixed it.
  30. Aug 4, 2023 at 5:53 AM
    That's for 2WD only, and is also covered in the info dump thread I've linked to several times already.
    While it could be driveline, my thought is brakes are doing some late grab, late release type crap, but the camera could rule that out. Maybe LSPV not configured right. ABS doing something stupid. Dunno.
