  1. Jul 27, 2023 at 1:30 PM
    danb
    danb New Member
    Minnesota
    2018 Tundra DC Looooooong bed
    Picked up an 06 Tundra last Saturday. Drove it 810 miles home. Planning on fixing a number of things, but shes runs well and is on a brand new frame and has new lbjs, timing belt, and water pump.
    replaced wipers
    replaced tailgate cables
    rerouted hood release cable since hood wouldnt relatch (the washer pulled through the rubber grommet on firewall)
    replaced air filter
    ordered Fumoto F133 quick drain plug (use these on all my vehicles)
    this weekend I plan on
    changing oil, installing fumoto
    flush coolant
    grease everything
    find a new skidplate
    Now I'm debating replacing the suspension parts the previous owner installed. Alignment is bad and ride is shit. Rough Country 2.5" on front and HD springs on rear. Yotamafia has complete Bilstein kits I'm thinking of picking up once my wallet recovers a bit. Plan on replacing the mud klaw tires with Open Country ATIIIs soon too.
    Debating replacing the radiator as the thread on it here has my bh puckered.
    bmf4069, oscardog86 and DJenerated like this.
  2. Jul 27, 2023 at 1:35 PM
    If you're around Atlanta, gimme a shout on the skidplate.
    If you haven't already caught it, have fun, and welcome to the fray.
  3. Jul 27, 2023 at 1:40 PM
    danb
    danb New Member
    Minnesota
    Hey man, youre the dude that made that huge writeup on the first gens right? Big thanks dude, read through that while I was looking for a truck.
    I'm on the opposite side of the country, but I really appreciate it
  4. Jul 27, 2023 at 1:45 PM
    There may be someone else on here that can help on a used pan. If not, here's the OEM skid plate p/n, why not buy new to go with that new frame?: 5140534010
    You'll also need bolts for it, part number 9008011373, and I think you need 5 of them: 3 front, 2 rear.
    Price fluctuates on the skid plate. When I looked about 8 months ago, they were running around $210 with free shipping. Looks like they're a little more right now. May be able to find used OEM on fleaBay. Junkyards are always a good bet also.
    JasonC. likes this.
  5. Jul 27, 2023 at 2:00 PM
    danb
    danb New Member
    Minnesota
    Thanks again man. I'm up in Minnesota and have access to a sandblaster and powder coater so rusty is fine if anyone else wants to get rid of one.
  6. Jul 27, 2023 at 2:10 PM
    WTF?!? I’m just not having a good day.
    Anyone know what needs to be replaced here? A cam sensor? Is there only one or two, one for each cam?
    The real question is how long can I drive it like that? It quickly went away but the truck was struggling to not die.
  7. Jul 27, 2023 at 2:19 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    check bubbaw's reply.
    https://www.tundras.com/threads/camshaft-position-sensor-a-bank-2.123418/
    & theres 4 cams.
  8. Jul 27, 2023 at 2:19 PM
    Believe for the 2UZ there is only the driver's side cam position sensor. I would check the harness wiring and make sure it hasn't gotten eaten into by the belt.
  9. Jul 27, 2023 at 2:22 PM
    Is it under the timing belt cover? I really didn’t want to try and remove that with the corroded bolts, but if I have no choice I guess I will.
    I guess I’ll be doing some research tonight.
  10. Jul 27, 2023 at 3:03 PM
    Yes, I believe it is.
  11. Jul 27, 2023 at 6:10 PM
    It is, and there was an issue where the belt would eat through it in the earlier models. I want to say there was a TSB for it. Hold up, lemme check my thread and I may edit this.
    Here you go - as I understand, the newest part revision gives an added retention for the sensor or something. https://www.tundras.com/threads/p0340-code-camshaft-position-sensor.95343/
  12. Jul 27, 2023 at 6:50 PM
    Weird. The code that link references is a P0340 and I have a P1340.
    Is there really only one cam sensor for the 2uz-fe? Must be two codes for the same sensor I guess.
  13. Jul 27, 2023 at 7:05 PM
    No, it's possible there are two on the earlier models. I would need to dig to confirm. Hol' up, lemme check the FSM.
  14. Jul 27, 2023 at 7:11 PM
  15. Jul 27, 2023 at 7:13 PM
    Looks like only one.
  16. Jul 27, 2023 at 7:14 PM
    P1340 doesn't exist as a code in the FSM.
    Try a different code reader; something isn't jibing here. Or just clear the codes and wait if something pops again. Maybe your ECM is tweaking a bit.
    txagg and FirstGenVol like this.
  17. Jul 27, 2023 at 7:30 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I’m hoping to do the big shabang lift and tires at christmas time. So I’m thinking I’ll just do the lbjs then. Full pucker til then….
    oscardog86 likes this.
  18. Jul 27, 2023 at 7:32 PM
    Casper421
    In the woods
    06 DC
  19. Jul 27, 2023 at 7:37 PM
  20. Jul 27, 2023 at 7:43 PM
    Casper421
    In the woods
    06 DC
  21. Jul 27, 2023 at 8:27 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Omw to work tonight I noticed my driver headlight is out. I turned on my fogs to compensate and halfway to work the driver side fogs go out. WTAF!?
  22. Jul 27, 2023 at 8:28 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Pulled the bed liner out of the old girl tonight. Truck lived in Virginia and Germany a few years, so was really worried about what I would find. Turned out to be in great shape!
    NUDRAT, JasonC., FirstGenVol and 7 others like this.
  23. Jul 28, 2023 at 5:30 AM
    Watcha gonna do with that liner?
  24. Jul 28, 2023 at 5:35 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Flip it upside down, stick it on the bed & have a cap?
    NUDRAT, bmf4069, txagg and 1 other person like this.
  25. Jul 28, 2023 at 7:00 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I'm throwing that hooker back in the bed, so will keep it. I wanted to see if I had any rust under there. Plan on pulling the bed and cleaning up the frame some when I swap the: Leafs, rear shocks, add airbags, and setup trailer wiring and brake setup.
    NUDRAT, bmf4069, shifty` and 2 others like this.
  26. Jul 28, 2023 at 7:05 AM
    I really want to do that too and I'm tempted to replace the fuel pump when the bed is off. My truck has had a few instances when it didn't want to start and I've wondered if the fuel pump is the issue.
    txagg[QUOTED] likes this.
  27. Jul 28, 2023 at 7:08 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Forgot about the pump, good call! I'll do that as well
  28. Jul 28, 2023 at 7:09 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    That's never fun, had mine replaced a few months ago.
    At least a couple good whacks with your fist or mallet will getcha going agan....for a few more weeks lol.
    txagg likes this.
  29. Jul 28, 2023 at 7:15 AM
    Sometimes I hate my life….left side timing belt cover nut and bolt to remove :annoyed:
    Middle nut on timing cover
    Top left bolt to remove
    I’d hate to think the stud would snap in the process of removing the nut from the center of the timing cover. It’d probably do some damage if I didn’t get the cover off to find it before I drove the truck again.
  30. Jul 28, 2023 at 7:19 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Washed it out with some hot water and dawn last night. Looks pretty good. @Jack McCarthy will be pissed IMG_1741.jpgIMG_1742.jpg
    bmf4069, oscardog86, shifty` and 2 others like this.
