Bilstein 5100 with Torch add-a-leaf?
Discussion in '1st Gen Tundras (2000-2006)' started by JIL_24/7, Jul 17, 2023.
  1. Jul 19, 2023 at 11:25 AM
    Just in case we didn't harp on OEM ball joints enough, they even make stickers.
  2. Jul 19, 2023 at 12:09 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Haha totally know what ripped off sticker that is
  3. Jul 19, 2023 at 12:14 PM
    Good observation on your part. I was removing some stickers earlier that I didn't really care for.
    FrenchToasty and des2mtn[QUOTED] like this.
  4. Jul 19, 2023 at 1:08 PM
    Yup.
    :fistbump:
  5. Jul 19, 2023 at 3:22 PM
    JIL_24/7
    JIL_24/7 [OP] New Member
    2005 DC Tundra SR5 TRD 4x4
    Got the ball joints, bolts and the cam sleeve today. $240 Canadian for everything. Pretty happy with that.
    New Issue!!!! I’m looking at my replacement CV axles and there is a small gap on each side where they enter the diff case. They are in all the way. Looking at my OEM CV’s today I noticed a small metal ring on the diff side. I removed them and they look to be just about the width of the gap I now have. Here’s the thing, though, the OEM widens right where the ring fits, but I am nearly certain the replacements did not. Do I need to do something about this? All the videos I found online said nothing about it
  6. Jul 19, 2023 at 4:09 PM
    Mine have a gap
    JIL_24/7[OP] likes this.
  7. Jul 19, 2023 at 4:11 PM
    JIL_24/7
    Yeah. The ones I see on video do too, but it is interesting that that ring is removable and that the gap is about the same size. Perhaps it's a dust cap of some sort built into the OEM CV's?
  8. Jul 19, 2023 at 4:18 PM
    There has to be a gap because the axle is spinning but the differential housing is not. When I initially replaced my axles I was confused by this too.
    JIL_24/7[QUOTED][OP] likes this.
  9. Jul 19, 2023 at 4:21 PM
    des2mtn
    Shady Grove
    Tonto cover
    Yes, they have a metal dust shield on the differential side that is removable
  10. Jul 19, 2023 at 4:31 PM
    JIL_24/7
    Awesome. Thanks everyone.
    Just to get back to my thought from earlier as I have to make a choice on what to send back. If I am going to lift the rear 1.5-2" to keep a bit of rake should I go with the 5100's that say the only do 1" of lift or do I go with the Rough Country N3's which are for 2-5" rear lift. I know the 5100's are better shocks and I got them for a song, but not worth it if they are going to be overextended. Thanks. Once I get a bit more cash I will replace the OEM leaf springs, but for know I will be adding the Torch. Even if I don't get the lift now because my leaf springs are older I will eventually, so I want a shock that will work. Thanks.
  11. Jul 19, 2023 at 4:55 PM
    I'll make this simple for you: Never, ever, ever buy Rough Country products. For the most part, it's cheap garbage. Add Rancho and Monroe to that list also, they too have their issues.
    txagg likes this.
  12. Jul 20, 2023 at 7:10 AM
    The front can be set to different levels up to 2.25” or so on certain models of Tundra. The rear gives no lift, but will accommodate up to an inch of lift.
    Elevatorguy likes this.
  13. Jul 20, 2023 at 9:37 AM
    Welcome to the forum. If you use the bottom notch on stock springs, that's correct: No lift. And like KNABORES said, no lift from the rear shocks, shocks don't provide lift; any lift you may've observed was either placebo, or due to your old stuff being worn the hell out.
    Really, the 5100 is intended to be used one of three ways:
    1. Stock springs at bottom notch: No lift.
    2. Stock springs at some other Bilstein-approved notch: You get about 1/2"-3/4" lift per notch on average for many cab types/drivetrain types, but you can't go above the 3rd notch except for certain cab type/drivetrain configurations and may lose comfort at each notch up (NOTCH CHART HERE)
    3. Lifted springs at bottom notch: Whatever lift your spring provides, there's an assload more info on which spring to pick in the "Suspension, wheel and tires ..." section OVER HERE.
    Thread linked in #3 should cover all the shit newbies typically don't know or forget, and what some folks who aren't new may not be aware of.
  14. Jul 20, 2023 at 11:31 AM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    I'm using the greaseable Moog lbj, I grease them every 6 months. They've lasted 24k miles so far after the frame swap. And see shitty ass WI winters as my daily driver, fishing, hunt truck.
  15. Jul 20, 2023 at 12:24 PM
    des2mtn
    Shady Grove
    Tonto cover
    https://www.tundras.com/threads/fyi-moog-recall.101454/
    Anima likes this.
  16. Jul 20, 2023 at 2:04 PM
    Moog isn't what it used to be, they outsource their parts to smaller warehouses in China mainland now. The end result is what @des2mtn just showed you with the recent massive recall on Moog LBJ. Note it's a Moog part, but wasn't made by Moog - here's a link, make sure you aren't affected: https://static.nhtsa.gov/odi/rcl/2022/RCONL-22E002-1411.pdf
    One of these guys was using Moog LBJs also, you want to take a guess which one it was?: , , link, link, link, link, link, link, link
    But hey. Live your life however you wanna live. If less than $200 is stopping you from swapping in OEM LBJs and fresh bolts for another 10-20 years of failure-free service, then bless you brother. I'm sorry you're stuck using non-OEM when it's been proven, exhaustively, that you should avoid 3rd party for this specific part, which is arguably the Achilles heel of these trucks.
    des2mtn likes this.
  17. Jul 20, 2023 at 2:09 PM
    des2mtn
    Shady Grove
    Tonto cover
    I think they're actually sending out OEM ball joints for those that are affected so if you have Moogs you're really doing yourself an additional disservice by not looking into it.
    This guy with later year ball joints for example...
    FirstGenVol likes this.
  18. Jul 20, 2023 at 2:24 PM
    Ha!! Even Moog realized their parts can't stack up to OEM, and OEM is probably about as cheap if you buy the Toyota OEM LBJ recall package part# vs. buying each OEM LBJ separately.
  19. Jul 20, 2023 at 2:45 PM
    shootemintheface
    I'm using Moog part # K90262 and K90263. They are not part of the recall. Gen 1 Tundras had 3 different part numbers. My truck is from 2001. They were the originals when I took them in for the recall the boots were already torn
  20. Jul 20, 2023 at 4:25 PM
    #50
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Dang Shifty, You have way too much time lol.
  21. Jul 20, 2023 at 6:52 PM
    #51
    Nah, it's all copy-pasta
  22. Jul 20, 2023 at 9:16 PM
    #52
    JIL_24/7
    Can confirm the LBJ recall kit does not come with bolts
    shifty` likes this.
  23. Jul 20, 2023 at 11:21 PM
    #53
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I had moogs on my 01. They were pretty new but I ditched them as soon as I could. Not worth the inconvenience or possible injury from trying to save a few hundred bucks.
    txagg likes this.
  24. Jul 21, 2023 at 5:23 AM
    #54
    You're not even spending more money. I checked for my truck at least. Moog LBJ are around $95/ea. If I buy Toyota's OEM late '04-early '06 LBJ recall kit for my truck (04006-62134), with both LBJ included, it's $185.
    This isn't even about money. It's about people being ignorant of what's needed, and potential solutions available. :bananadead:
    Posted earlier, but there's a recall kit for all ranges, although, with McGeorge for example, they claim they won't guarantee fitment so it may get weird around crossover years:
    Late '04 - '06 kit # 04006-62134
    Early '02 - '03 kit# 04005-21134
    Early '01 - '02 kit# 04005-04134
    Spiker's testing listed the bolts to get for replacement (8 needed) are Toyota Black Bolt w/Washer (90119-10933) or the ARP Bolt (673-1004). I think the Toyota black bolts may be the ones some complain are a hair longer. (EDIT: Actually, if you need bolts for yours, you may want to read all 4 pages of the Spiker LBJ bolt thread)
  25. Jul 21, 2023 at 3:02 PM
    #55
    NickB_01TRD
    KY
    I never really liked the way that thread turned out. Ended up a bit too long. Need to condense one day.
  26. Jul 21, 2023 at 6:42 PM
    #56
    I tend to agree. There's nothing stopping you from editing the 1st reply at the very beginning to say "tl;dr - if you have XYZ year, use p/n 123, if you have ABC year, use p/n 456" etc.
  27. Jul 21, 2023 at 6:47 PM
    #57
    NickB_01TRD
    KY
    Yeah true.
  28. Jul 21, 2023 at 8:31 PM
    #58
    NickB_01TRD
    KY
    Done. Double check if you'd like.
    Thread
    noahrexion, shifty`[QUOTED] and txagg like this.
  29. Jul 22, 2023 at 3:54 PM
    #59
  30. Jul 22, 2023 at 7:03 PM
    #60
    shootemintheface
    They won't let me into the group, mine hasn't failed yet :D
