295/70/18 or 285/60/20 on a 3" lift?
Discussion in 'Wheels & Tires' started by renlo, Jun 29, 2017.
  1. Aug 16, 2017 at 5:35 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Not completely full, but I workout and it's awesome for protein mini-man
    Law323 likes this.
  2. Aug 16, 2017 at 5:35 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Wow
  3. Aug 16, 2017 at 5:36 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Can't see the gif??
  4. Aug 16, 2017 at 5:36 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Naw brotha it didn't load.
  5. Aug 16, 2017 at 5:38 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Aww just a pic of Stimpy eating popcorn LOL
  6. Aug 16, 2017 at 5:39 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Wrongside, AnonVet and Law323 like this.
  7. Aug 16, 2017 at 5:42 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Law323[QUOTED] likes this.
  8. Aug 16, 2017 at 5:43 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  9. Aug 16, 2017 at 5:45 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I'll be here all night until I find a way to post a damn gif. There's a funny ass antifa one that would go greatly with our friend Michael
    Law323 likes this.
  10. Aug 16, 2017 at 5:46 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Maybe the ole Samsung is taking a shit on me. Can't see @joonbug's either
    joonbug likes this.
  11. Aug 16, 2017 at 5:48 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Just more popcorn :D
    Law323 and AnonVet[QUOTED] like this.
  12. Aug 16, 2017 at 5:53 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Hahaha it is quite entertaining. My wife laughed and said "he must be antifa or something". That's what inspired the gif lol
    joonbug[QUOTED] and Law323 like this.
  13. Aug 16, 2017 at 5:56 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    That's not what ur wife was saying last night
  14. Aug 16, 2017 at 6:10 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I just go online, search for _____ gif, look on images and find one I like. Save image in photos and press upload file, click on the gif in my photos and then "post"
  15. Aug 16, 2017 at 6:25 PM
    renlo
    renlo [OP] New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    Well I went out and measured and there right a 33". I wonder if the weight of the truck is causing the tire to compress, thus measuring shorter than advertised. I didnt measure the tire and wheel off of the tire, but I remember when I took the wheels off to remove my spacers, there wasnt as much of a "mushroom" look on the bottom.
    Either way, I like the look and even happier it doesnt rub. Maybe when these tires wear out, ill jump up to the 4.5 bds kit with some 35s.
    JackWagon likes this.
  16. Aug 16, 2017 at 6:30 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    The weight will compress the tire a bit. I have 275/70's and they measured right above 33"
    I honestly think you'll be fine with a 3/1 and 35's. Just gotta do the CMC. It's not that big of a deal whatsoever. I'm actually surprised the 295/70's rubbed as badly as you say
  17. Aug 16, 2017 at 6:44 PM
    renlo
    Rene
    As was I. I would say the tire dug in about an inch to the front fender liner and rubbed the mudflap. I did end up pushing the fender liner further in more and re drilled the rear mudflap to flatten in out which created more clearance. I wanted to keep the flaps to help out with keeping water from kicking up. Next time Ill try a bigger size.
  18. Aug 16, 2017 at 6:51 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Was this after alignment? That can make a big difference.
  19. Aug 16, 2017 at 6:54 PM
    renlo
    Rene
    No, i had it aligned before the new wheel/tire setup because I had bought some 33's for the platinum wheels. I kept the same alignment afterwards.
    I did get a new alignment last week though because i had them tighten the lca's due to a clunk i had. The caster was set at 2.75. This is with spc arms.
  20. Aug 16, 2017 at 6:56 PM
    #50
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Got you.
    I'm at a loss, countless guys on this forum are running true 35's on a 3/1 with some adjustments. Haven't heard a problem from their end.
  21. Aug 16, 2017 at 6:58 PM
    #51
    renlo
    Rene
    I know, but they took off their front mudflaps which i want to keep. That right there gives about an inch of clearance.
  22. Aug 16, 2017 at 7:03 PM
    #52
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    True. Have you thought about trimming it down some??
  23. Aug 16, 2017 at 7:13 PM
    #53
    renlo
    Rene
    Yea, i will eventually when I get bigger tires.
    Law323 likes this.
  24. Aug 16, 2017 at 7:30 PM
    #54
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I won't knock that man, thatd be a solid setup man.
    renlo[QUOTED][OP] likes this.
  25. Aug 16, 2017 at 7:33 PM
    #55
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    My 2.5 sus lift will fit 295's but there is zero room for more.
    equin, Law323[QUOTED] and renlo[OP] like this.
  26. Aug 16, 2017 at 7:54 PM
    #56
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That sounds right to me. Seems like 295 is the max (without extensive modification) with a 2.5 and 35's are the max on a 3"
  27. Aug 16, 2017 at 8:18 PM
    #57
    renlo
    Rene
    The 295's i tested were cooper at3. Arent coopers usually bigger than the average brand?
  28. Aug 16, 2017 at 8:35 PM
    #58
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Not sure but if guys can fit a true 35 on a 3/1, a 295/70 Cooper that ran big still wouldn't pass up the 35 mark.
  29. Aug 17, 2017 at 6:38 AM
    #59
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    Based off of what you guys are saying... The 285/70 should be perfect on a stock suspensioned PRO. Thats good news. The hard pill to swallow is the price per tire.
  30. Aug 17, 2017 at 8:49 AM
    #60
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    So what's going on in here? hahaha
