Sniv's 300k Supercharged Tundra
Discussion in '2nd Gen Builds (2007-2013)' started by snivilous, Jun 14, 2019.
  1. Dec 22, 2021 at 5:30 PM
    #91
    snivilous
    SW UT
    300k+ Supercharged 2008
    That's good to know! I look forward to your review before getting myself one though :D
    TX210Tundra[QUOTED] likes this.
  2. Feb 14, 2022 at 1:34 PM
    #92
    snivilous
    SW UT
    Just passed 268,500 miles yesterday! Finally bought a TRD sway bar for the rear before going to KOH to help me control this big bitch.
    Camper plus the trailer and can am, and lots of water and fuel!
    Had the shocks stiffened up about halfway, 40psi in the airbags, and like I said rear sway bar. This was the "heavy towing" setup, and seemed to work great! Truck handled great and had plenty of power as usual. Drove about 700 miles round trip.
    Camper was awesome, and carrying an extra 30gal of water for what felt like unlimited length showers was great. A tarp over the shower tent kept it really warm like a sauna which was nice. Most comfortable setup I've been to KOH with. Heater, bed, kitchen, outdoor shower, and the table/couch area was setup to hold my race gear.
    And a handful of racing photos. Lots of issues with my buddies racecar but he got it fixed. I preran about 100 miles of course in my Can Am. We made it 119 miles (out of ~160) during the UTV race and ended up blowing three CVs and two tires and eventually timed out. Raul Gomez won the 4400 class for the first time, maybe next year I can try and race 4400 :D but I doubt it.
    FrenchToasty, Blang805, TG705 and 6 others like this.
  3. Apr 3, 2022 at 5:39 PM
    #93
    snivilous
    SW UT
    271250 mile update.
    At 270638 I installed a Radium Catch Can since Ive been having lean out codes when I come to a stop and the PCV hose has been looking gross so suspected that was leaking and may as well upgrade it. Installed it last week and so far no more CELs!
    Also my passenger side Morimoto headlight got condensation in it after a car wash. Need to contact them, though at least it only lasted for a day and has dried out but obviously a seal is broken somewhere. Seems somewhat inevitable with aftermarket headlights, was hoping being direct from Morimoto would be better about the quality...
    Changed the oil on Wednesday at 270693 and then loaded up the camper and drove to Moab for a race I was codriving in.
    A flop, a broken frame, a roll, a destroyed front end, and four blown tires between qualifying and the main race! Got the car recovered and I packed up at 9pm and home by 1:30am!
  4. Sep 4, 2022 at 10:11 AM
    #94
    snivilous
    SW UT
    277,059 mile update.
    Changed the engine oil/filter, flushed the ATF, changed the tcase oil, flushed the brake fluid, changed the cabin air filter, swapped the engine air filter for an AFE dry, new IKH22 spark plugs, and changed the fan clutch.
    Still need to flush the steering but ran out of ATF.
    Also bought a dragy and got 5.58s 0-60 at 5500ft which doesn't seem too shabby.
    Due to the elevation I'm at I'm effectively 5-6psi short of what a stock Magnuson at sea level would be putting out, so I designed a modular coupler since the ones on the market seem to suck, and will probably get some machined in the near future.
    The end :D
  5. Oct 16, 2022 at 6:52 PM
    #95
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    snivilous[OP] likes this.
  6. Oct 16, 2022 at 8:10 PM
    #96
    snivilous
    SW UT
    Mater[QUOTED] likes this.
  7. Oct 20, 2022 at 7:43 PM
    #97
    snivilous
    SW UT
    279,160 mile update. Lots of towing things around Utah in September and October.
    Did a dragy run down the hill at lower elevation and got 5.13s 0-60 which I wish was better. This was at 6.7psi which is ~20.1psi manifold pressure, or ~5.4psi at sea level.
    Now for the exciting stuff, my pulleys showed up weeks ahead of schedule!
    Everything looks and fits absolutely amazing! 7075-T6 pulleys and 17-4PH stainless hub. Tore everything apart yesterday and got it back together today.
    The supercharger shaft is 0.663", which is the same diameter I measured from the stock pulley. Luckily the place I bought the pulleys from had a +-.001" tolerance so I downsized my original 0.663" bore to 0.662" with the intention I could bore it out if needed. The hub came at the exact size I specified, which was actually great because the if it was a match fit there'd be hardly any pressing going on! I also feel really dumb since for some reason I didn't analyze the press fit, which in retrospect seems really easy since I know the strain failure of the 17-4 stainless so can size the press on that. With that said the 0.001" diametric press fit is around a 5600lbf press based on some shower math, which should handle ~900ft-lbf of torque before spinning. Not sure if that's a lot or not... But I think for production hubs I'll increase the press fit quite a bit to be safe and actually do some analysis instead of my current winging it method. I also was contemplating drilling and keying the pulley since I did that on my LSA supercharger since spinning that pulley can be an issue, but I'd rather run the Magnuson with the product the way it'd arrive to people so will risk it spinning on the shaft, and if that ever happens I will fix it then.
    The hub pressed on great, I used the 20 ton HF press just like I did with the URD and that makes it easy. The hub was pressed flush with the shaft and seemed to contact the bearing inner race which seems correct.
    The pulley barely clears the snout which is how the previous pulleys have been. There is plenty of clearance everywhere with both pulleys which is a good sign!
    I also replaced the coupler since it was starting to get loud. This is a $10 "OEM" coupler and lasted about 2.5 years. I bought the "upgraded" $20 coupler from ZZP (also where the black coupler came from) so hopefully that one lasts longer.
    I also adjusted the bypass valve though it seemed adjusted correctly already.
    I lifted the entire blower housing a couple inches to pull the snout, this seemed easier than removing the crossover.
    And fully installed! This is with 12x A286 4-40 fasteners. I also replaced the belt with the same Continental 112.4" belt #4081124. The pulley is designed so you can lay the belt onto the pulley THEN slide the pulley on so you don't have to pry the belt over the pulley. We didn't have to do that since the issue is no one makes a smaller belt (within reason) belt, so the 112.4" belts work with the 2.35" pulleys and ideally we'd have a ~0.5" shorter belt with the 2.0" pulley. With that said, we did a test drive and haven't yet (at least obviously) experienced belt slip.
    We did a short drive to dinner and the truck is making way more boost! I did a quick full throttle pull and saw 7.7psi over the previous ~4.5psi we were seeing! The truck now appears to have a manifold pressure equivalent to the URD pulley at 2500ft elevation which is insane to me. The URD pulley at sea level I think I'd seen 10psi before, so I think the 2.0 is going to make absolutely insane power at lower elevation!
    More testing to come, up here and at low elevation. Need to see if the belt will slip or fall off and how to fix that. Additionally got new Falken Wildpeaks yesterday, got right around 52k miles on them which seems pretty good! Also replaced the PCV while I had the blower off. So new tires, new pulley and hub, new coupler, new PCV.
  8. Oct 20, 2022 at 8:27 PM
    #98
    Yzed608
    Yzed608 New Member
    Wisconsin
    Your truck makes me feel good about mine lasting a really long time, and I'm NA and never tow! Kind of makes me want to put a supercharger on it though... Really cool seeing some custom designed stuff there, I'm assuming you have some sort of engineering background?
  9. Oct 20, 2022 at 8:59 PM
    #99
    snivilous
    SW UT
    Yes sir, i specialize in aerospace structures and mechanisms, and maybe in the future supercharger parts :D
    I am excited for next year when the Tundra will probably pass 300k. And if I can do a sub 5 second 0-60, I'd like to think that'll be the end of my pursuit for speed for this truck and I think it'll be reliable at that power. That is the "benefit" of living at higher elevation is big power upgrades really aren't as stressful on the engine (to a point). If I lived at sea level I'd probably leave the supercharger stock to keep everything reliable, up here I can modify it just to match the sea level guys and still be reliable.
    rockmup, Yzed608[QUOTED] and reywcms like this.
  10. Dec 19, 2022 at 8:42 AM
    #100
    snivilous
    SW UT
    281,700 mile update. This is mainly to log tuning notes. I installed Prospeed "750cc" injectors (really 715cc) on November 26th. Those details can be found here: https://www.tundras.com/threads/general-supercharger-thread.85513/page-146#post-2993868 Not a fan of the Prospeed injectors.
    Prior to the injectors I had really bad knock at ~2500ft elevation (I live at 5500ft). The TRD Green 535cc injectors were 100% maxed out even at higher elevation, and no doubt contributing to the knock at lower elevation which is why I got the 715s. Since the bad knocking, I had had the truck at lower elevation a number of times but just avoided WOT. Two days ago we went down the hill and didn't have a lot of plans so grabbed the laptop to see if I could dial the truck in down there. The knock retard on my first run looked like this:
    This was still using the timing map that Viktor had given me (last year?) and was fine before I increased the boost. During this run the max boost I saw was 10.7psia, which means the supercharger itself was making upwards of 12psi and after compensating for the altitude pressure loss was providing 10.7psi beyond what a sea level engine would make. Obviously there is a lot of knock happening at 5200rpm, but otherwise it doesn't look too bad, and was nowhere near as bad as the small injectors. I had already dialed in the large injectors a bit, and was targeting an AFR of 10.5. I then modified the timing base map and high octane map, not drastically but there were a couple areas that could get smoothed out and I dropped the timing 1 or 2 degrees around the 5200rpm range. I also was seeing the AFR fluctuate a bit leaner than I wanted, which is normal, the AFR isn't locked in and is very dynamic, but I wanted 10.5 to be the worst case level of lean at WOT so I richened the truck out a bit more to 10.2. This is the limit of the 715cc injectors, I am at 95% duty cycle but this is only at lower elevation, at home I'm around 80% which is perfect. After those tweaking the data log looked like this:
    Much better! I'm not sure what a bad level of knocking is, but -3.0 is nominal operation and anything lower is bad. In my mind these numbers are all relatively low, so the truck is retarding for knock a little but nothing drastic. My next issue was hitting the rev limiter through most gear shifts. I had this issue in my 2-3 shift before and fixed that, but was now happening through most of the other shifts. The truck seems to have the rpms increase so fast it can't anticipate and shift fast enough, so the tuning solution is to decrease the shift rpm so it doesn't hit the limiter. I dropped all shift points at WOT by 5%, and that was perfect and the truck didn't hit the limiter anymore and shifted around 6000rpm!
    I did one timed 0-60 run once that was all looking good, and this was the quick data log and dragy run:
    The data log was really fast, so not sure how much can be gleaned from it, but the truck seemed very happy with the changes. It also did the fastest 0-60 by far, at 4.58 or 4.37 (depending which number you compare). I only did the one run since I had spent the last hour doing WOT runs and wanted to let it rest, but I am extremely happy with how it's performing. I can now drive down the hill and not worry about knocking and can use all the power on tap safely; I may have lost a little power at higher elevation but I suspect it's minimal since I didn't change the timing by much (and mostly over 5000rpm).
    Peeeheeuuu, ZPhilip and reywcms like this.
  11. Jan 16, 2023 at 4:18 PM
    #101
    snivilous
    SW UT
    284,068 - Was a bit late on this oil change, over 7000 miles on it! New oil and filter.
    I pulled the supercharger pulley off for the first time, nearly 5000 miles since installing it! Looks totally fine, quite a bit of oily residue around it but I suspect it's just from the anti seize between the pulley and hub interface getting thrown out. Wiped down everything looks pristine. Little bit of black marking on the front and rear where the belt extremities contact.
    Also checked the catch can for perhaps the first time ever? I feel like I opened it once before though... Maybe a 1/2" of essentially muddy water and nothing else. I'll take that as a good thing, and the can is just getting condensation from the winter and there's nothing else to pick up.
    k0diak8o8 and Peeeheeuuu like this.
  12. Jan 16, 2023 at 4:43 PM
    #102
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Wish I had a fat ass garage.
    Mater and snivilous[QUOTED][OP] like this.
  13. Jan 16, 2023 at 4:48 PM
    #103
    snivilous
    SW UT
    Shop is getting some fat upgrades this year! Last week it just got insulation, and next up will be a 40ft radiant tube heater. I'd also like to epoxy the floors in the spring, and will be putting plywood walls up to the first cross beam. Over the weekend I had some friends come over to wrench on their truck and help move everything after the insulation, and the new layout is absolutely awesome! Had five vehicles in here with room to work and room for more! Super excited with how it's turning out after not doing anything in December. If you're ever in southern Utah come swing by :D
    Peeeheeuuu, Mater, e30cabrio and 4 others like this.
  14. Jan 16, 2023 at 4:57 PM
    #104
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    That is awesome!
    snivilous[QUOTED][OP] likes this.
  15. Mar 4, 2023 at 6:17 AM
    #105
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I want a similar shop, just nowhere near that big, awesome!
  16. Mar 4, 2023 at 8:08 AM
    #106
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    So like this?
    Amazing how much this guy packs into a tiny room. Not sure how he keeps it so clean and swarf-free..
    https://youtu.be/In6VqiHL7rM
  17. Mar 4, 2023 at 8:15 AM
    #107
    e30cabrio
    That's cool but I'm thinking between that & yours. A 2 bay barn would be perfect so I have the height to have a lift.
    Mater and snivilous[OP] like this.
  18. Mar 4, 2023 at 8:21 AM
    #108
    snivilous
    SW UT
    Mines 40ft wide and 60ft deep for reference.
    Mdl, Mater, ZPhilip and 1 other person like this.
  19. Mar 4, 2023 at 9:22 AM
    #109
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    That is a dream garage/workshop right there. I’m in design phase of adding a 27’x30’ garage.
  20. Mar 4, 2023 at 9:29 AM
    #110
    snivilous
    SW UT
    Shopped houses for 1.5yrs until we found one we liked, and having a shop was a must have.
    Most things can be added after the fact like wiring and air, etc. But some things I suggest thinking about if you haven't:
    -A drain in the floor so you can wash the floor, or vehicles, etc. in the shop.
    -Water line/drain for a sink
    -If you plan to run a gas heater, run the gas line.
    Since my place came with the building, adding a floor drain is essentially impossible. And adding water and gas will require exiting the ground outside the shop and then jogging in. If I was designing a shop I'd add those features from the start. Also have thick enough concrete to add a lift (usually 4" or more).
  21. Mar 20, 2023 at 9:31 PM
    #111
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    I'm at 193k mi and I'm going to do exactly this. :thumbsup:
    Deaner likes this.
  22. Apr 10, 2023 at 7:17 PM
    #112
    snivilous
    SW UT
    289,525 update. Oil and filter change, blow out the air filter, and empty the catch can which had like 1/2" of mostly water and a little gas (looked like coffee with same consistency).
    After my annual trip to KOH in which I absolutely overload the Tundra with the cab over AND the can am, I was seriously thinking about a diesel. But that thought died down until recently when I got my buggy running and took it for a trip, and now I'm pretty certain a diesel will happen in the near future. The Tundras gas mileage is so horrible, I literally go through a tank as fast as my diesel friends even notice their fuel needle has moved. I'll keep the Tundra, I don't think it's worth much and still a lot of fun around town and doing chores, but it'd be nice to have the camper and the buggy or both of those and the can am; just have options for larger trailers and not constantly be overloading the truck when I'm barely hauling anything. In the past two weeks I've taken the buggy out twice and the can am out twice, with each trip being usually two whole tanks of gas just to drive an hour away. Course I could drive slower, but I value my time more than the cost of doing the speed limit. We'll see (could always turn the tundra into a prerunner then too...). Otherwise the truck still runs and drives like a champ, probably hit 300k this year!
  23. May 3, 2024 at 5:55 PM
    #113
    snivilous
    SW UT
    300,066 mile update :D
    Crossed 300k yesterday, took forever since the Tundra doesn't see a lot of miles anymore. Hell a year ago and it's only seen 10k, before that it was 20-25k a year.
    And since I haven't posted in here, I did an oil change at 295769 and ATF drain and fill at 298061. I forget what was going on with the trans, it was acting weird or something and new fluid seemed to make it happier. It was also due for it.
    Up until December or so the Tundra was getting the usual work outs of towing things. Even did a trip across the state for a race, and besides needing to fuel up 4x times it didn't skip a beat! Ole reliable as always.
    But besides longer trips and towing it didn't see much action. I drove the FJ40 a lot this winter, and then we also picked up an old VW Mk1 Cabriolet which the dogs much prefer to ride in, so the Tundra would sit a lot. And then I bought a semi in January to take over the towing duties.
    I had looked at one ton trucks but they just never clicked for me, though I wanted something larger since the Tundra getting 8mpg towing (if it was lucky) wasn't cutting it, and I wasn't gonna put a camper on the tundra with the buggy on a trailer too. Turns out the semi fit my needs pretty well, and cost way less than any one ton truck and is way more capable!
    So with that, the Tundra is more or less in retirement. My goal was to get it to 300k and it finally did. I don't plan to get rid of it, I still need a truck bed, like today going to the dump.
    But it's heavy duty days are over. It'll tow things from time to time when the semi doesn't fit the bill, but it's life will be much more half ton around town focused. With that said, it's still a blast to drive, so smooth with how much power and how old it is. I have three vehicles that are from the 70s-80s and none of those go on trips much beyond the outskirts of town, so anything further is either the Tundra or the wife's GX, so it most certainly still has a spot to fill.
    That was a big reason for the semi, the Tundra isn't worth much, so selling it is pointless. If I bought a one ton truck that ends up overlapping capabilities with the tundra in almost every way and that just seemed pointless. But a truck to do basic truck things, and an absolutely overkill semi to haul the buggy and any trailer setup I could dream of, well those don't overlap at all really. So now I have a semi that doesn't even know (literally at all) if it has 10k behind it, and I have a Tundra that is fun to drive and can go to Home Depot and the dump and is relaxed. Two vehicles massively overbuilt for their roles, instead of a Tundra doing everything and taken to the limit.
    This thread didn't see an update for a year, not sure it will ever again since there won't be much to update or exciting things. Though I may get rowdy with the engine, or maybe turn it into a prerunner... But those would be aways off, I have enough other projects in the mean time.
    Thanks for reading.
  24. May 3, 2024 at 6:12 PM
    #114
    e30cabrio
    Awesome update! As usual!
    Mdl and snivilous[OP] like this.
  25. May 3, 2024 at 6:15 PM
    #115
    koditten
    Kirk
    Midland of the Mitten
    Great reply!
    Thanks!
  26. May 9, 2024 at 8:17 PM
    #116
    boomsling
    boomsling New Member
    ‘18 SR5 Double Cab 4x4
    Magnuson, Rough Country 2” coil overs
    77k on mine. Magnuson at 70k…based on your thread, this truck will outlast me…yaaaassss!!!!
  27. Aug 7, 2024 at 8:53 AM
    #117
    snivilous
    SW UT
    Oil change at 300,900. The windshield washer fluid pump also died so replaced that, I think this may be the second time on this truck it has gone out, though I might be misremembering and it was another vehicle.
    I had some work stuff on the far side of the state, and my buddy bought a truck in Salt Lake City so I said I could pick it up for him. I towed my trailer up (and got to have fun with it blowing a tire), dropped the trailer off, then picked it up on the return south and then got the truck.
    On the way up the Tundra got like 10mpg with the empty flat bed which weighs like 2500lbs and doing 87mph. Unloaded it got 12.7mpg. On the way back got 7.4mpg at 78mph.
    I even datalogged a bit on the way down just to see what the truck would do running 4-5psi for an extended period on hills since I can't monitor knock feedback with Torque Pro.
    The truck did great for MOST of the drive. Had cruise control set in 5th gear, an occasional hill steep enough I'd pop it out of cruise and let it slow down. But she seemed happy chugging at 4psi and maintaining speed up hills. In typical fashion if it's in boost for an extended time (multiple minutes) the engine temps will climb a bit and that's it. The truck is extremely consistent of peaking at 203deg normally, and in boost might go to like 208. Trans was locked in at 190-200deg (thermostat is pinned open, and tune is set to lockup the converter in 4/5/6 always).
    The LAST hill is when something seemed to go wrong. Another hill where the truck hit 5psi or so for a moment or two, but was otherwise fine. Engine temp climbed up a bit, but crested the hill and was home free on the flats the rest of the way. But the engine temp didn't drop. It was at 208 or so, and then climbed to 212 and then locked in there. For the next 30 minutes or so all the way home I experimented trying to figure out what was going on. The engine temp would drop only if the rpm dropped, so upshifting to 6th it would drop a bit with cruise control still on at 78mph. If I slowed down more it would drop more. If I slowed down and downshifted and was on the throttle a bit, the temp would climb. So the temperature was definitely influenced by the rpm, which usually it's the other way of revving the engine up and pumping more coolant tends to cool it down faster (assuming low load). Even once I got off the interstate, doing 55mph the engine temp would climb right back to 212 (saw 214 for one instant) if I was driving in a low gear. So low gear, revved out to 3-4k but essentially just idling along and temps would go to 212 and just hold there.
    And on any of my other vehicles this wouldn't remotely be a concern. The Hilux, the buggy, their temps fluctuate all over the place and when working hard will hit 212 all day. 212 isn't that hot for coolant, and if you're not actively monitoring the exact temperature you wouldn't even know anything was wrong. No hiccups, such a small temp change the gauge isn't registering it (even a good analog gauge probably wouldn't pick it up), but the Tundra is so consistent that I know something is up with it. The whole trip and it's solid and repeatable, and it was in 100+ degree weather earlier in the day with the trailer. But the last flat land at night and all of a sudden the temperature baseline has moved from 203 to 212. Such a small change, but big implications.
    Crawling around it a little this morning, the biggest clue is there is coolant (and lots of stains from coolant it appears) on the lower radiator hose and fan shroud. I'm not entirely sure where these are coming from, but I would bet is the issue.
    A few years ago I had the radiator develop a crack and had similar results then too. I don't know if this is the radiator again or something else. But I suspect it's bleeding pressure and that's what's making the temperature rise, and is so small that's why the coolant level isn't dropping very fast. At one point I had the serpentine belt kissing the lower radiator hose and causing a tiny pin hole that was spewing coolant, maybe that same thing has happened again?
    Won't be until next week that I can really look into this. Will probably tow the truck to my friend's house an hour away, get some more miles on the Tundra and see if that helps reveal where the issue is coming from. All in all, I can't complain too much. The truck just did 650 miles the last two days, 200 towing an empty trailer, 200 towing a truck. The thing is an absolute animal.
    k0diak8o8, blenton, Mdl and 10 others like this.
  28. Aug 7, 2024 at 2:38 PM
    #118
    Saltyhero13
    Saltyhero13 Throbbing Member
    Big gratz! Impressive milestone for this workhorse.
  29. Aug 13, 2024 at 7:25 AM
    #119
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Towing at 87MPH with a 300k mile supercharged V8 Tundra on 35s? "Hauling the mail" dude.
    I have seriously enjoyed reading your posts over the last few years. It's easy to overlook the time an effort it takes to document and write up all the information that you provide here when all this is available for free.
    Thanks :thumbsup:
  30. Jan 18, 2025 at 12:01 PM
    #120
    Trusty Rusty
    Trusty Rusty New Member
    2011 Rock Warrior CrewMax
    Great thread, was just going to browse and went through the whole thing. This truck WORKS!
