2017 flex fuel not starting
Discussion in '2.5 Gen Tundras (2014-2021)' started by rittkuhn, Feb 7, 2023.
  1. Feb 7, 2023 at 5:18 AM
    rittkuhn
    rittkuhn [OP] New Member
    2017 sequoia limited flex fuel 4wd
    Hello,
    I have a 2017 sequoia limited with flex fuel 4wd. It occasionally has trouble with cold starts. Battery fine, alternator fine. Will run well once it starts and won’t repeat problem for a couple weeks.
    The problem- starter turns and engine doesn’t catch at all. It’s almost like if I started it without spark plugs. Then, pull key and retry and it starts normally. The dealership couldn’t find anything and charged a ton to clean the fuel injectors. Problem persists.
    I hope someone here can help. Thanks for looking.
  2. Feb 7, 2023 at 5:24 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did they check fuel mixture numbers? I bet they read incorrect ethanol %
  3. Feb 7, 2023 at 5:25 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Is the starter not engaging the flywheel?
  4. Feb 7, 2023 at 5:41 AM
    rittkuhn
  5. Feb 7, 2023 at 5:42 AM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    ForeverTundra likes this.
  6. Feb 7, 2023 at 5:46 AM
    rittkuhn
    Very similar, yours sounds like it was catching(almost starting)a little. I’m not sure our ever does. It’s frustrating because Toyotas are usually so reliable.
  7. Feb 7, 2023 at 5:49 AM
    MatD13
    MatD13 New Member
    Mine just did the cold start about 20 mins ago before I took my daughter to the bus stop. It always takes 4 times before it turns over when I have this problem. Frustrating
  8. Feb 7, 2023 at 6:31 AM
    Thought there was a TSB with ECU flash and a fuel pump replacement for this problem, specific to FFV vehicles.
    ZappBrannigan likes this.
  9. Feb 7, 2023 at 4:03 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    this.
    It Is a pretty common problem. Plenty
    Of reading here
    I would get a cheap obd2 reader and check your ethanol reading. Probably way off
  10. Feb 7, 2023 at 4:47 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    There is but it doesn’t help long term. My truck has been to the dealer 5 times for this issue. The dealer readily admits Toyota has no fix for it. Here is the sad part. They will charge you to change the alcohol density ratio even though they know and can’t fix the issue.
  11. Feb 7, 2023 at 4:48 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I’d like to know how to reset it on our own so we don’t have to go to dealer.
  12. Feb 7, 2023 at 5:36 PM
    AZBoatHauler
    So.Arizona
    I believe a recent version of techstream on a 64 bit OS will do it.
    BTBAKER[QUOTED] likes this.
  13. Feb 7, 2023 at 5:42 PM
    MatD13
    MatD13 New Member
    I brought my truck in for the TSB Jan 22, and the truck is still acting up. My truck had the extended start 3 times today. Only when the engine was cold. Besides the frustration with the root problem, I’m getting worried about the starter at this point too cranking as much as it’s doing. Since I operate aircraft on a regular basis, there is typically a starter duty limitation written, but haven’t found one for the Tundra in regards to how long to let it cool down between restarts to prevent failure.
    This time, mine isn’t spitting out codes like it did before on my OBDII.
    I’m not sure if my OBDII reads ethanol levels, so I’ll have to check that tomorrow in the settings.
  14. Feb 7, 2023 at 5:45 PM
    MatD13
    MatD13 New Member
    lucky for me I guess, but last month I brought my truck in, it sat with them for several days, they couldn’t duplicate it and didn’t charge me a dime. I was pretty impressed they didn’t charge the diagnostic fee. I’m calling tomorrow for another appointment and hopefully be able to somehow give them a video of the symptoms
  15. Feb 7, 2023 at 5:55 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Mine has always been the alcohol density. As soon as they reset it my truck fires up, runs better and gets slightly better MPG.
    They told me to pull my key out of ignition when fueling and it “should” extend the time between issues.
    This is a FFV engine issue only and Toyota is fully aware.
  16. Feb 7, 2023 at 6:00 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
  17. Feb 7, 2023 at 7:21 PM
    AZBoatHauler
    So.Arizona
    I just ordered the new version of Techstream so I can reset this if I ever need to. Consumer shouldn’t have to deal with this issue but path of least resistance…
  18. Feb 7, 2023 at 7:24 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    It is. You’re correct. It really pisses me off though.
    I need to learn more about how to use tech stream and how I can reset this myself.
  19. Feb 7, 2023 at 8:35 PM
    MatD13
    MatD13 New Member
    That’s funny. My key is always out of the ignition when I refuel. Did some old timer tell them that and they all agreed? LOL
  20. Feb 7, 2023 at 8:37 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    They told me the computer stays active with the key in. I honestly think they are grasping at straws with this issue.
    MatD13[QUOTED] likes this.
  21. Feb 7, 2023 at 8:39 PM
    MatD13
    MatD13 New Member
    I did a quick search earlier on Techstream but isn’t buying the equipment/subscription pretty expensive? Like way more expensive than just having the dealership change fuel density?
    BTBAKER likes this.
  22. Feb 7, 2023 at 10:14 PM
    AZBoatHauler
    So.Arizona
    VCI J2534 Cable Fit for Toyota TIS Techstream - Latest Version V16.00.017, Firmware V1.4.8, Scanner Adapter Diagnostic Cable Scan Tool, OBD2 Diagnostic Cable, Support Win XP WIN7 WIN10 32/64bits https://a.co/d/figHAOG
    :spy:
    My old 32bit version can turn things off like the seat belt warning but I don’t trust the laptop it’s on.
  23. Feb 8, 2023 at 6:15 AM
    Jeffro22
    Jeffro22 New Member
    The $50 bootleg version works fine for resetting alcohol density.
    AZBoatHauler likes this.
  24. Feb 8, 2023 at 7:46 AM
    MatD13
    MatD13 New Member
    the concept is cool but I’m not trusting Chinese malware to be installed on my computer
  25. Feb 8, 2023 at 8:21 AM
    AZBoatHauler
    So.Arizona
    You have an iPhone?
  26. Feb 8, 2023 at 8:22 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Failing fuel filter/pump?
  27. Feb 8, 2023 at 8:33 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    How old is the battery? Who checked it? I WAS having this issue until I put in a new battery and put a maintainer on it from time to time.
  28. Feb 13, 2023 at 1:22 PM
    AZBoatHauler
    So.Arizona
    For anyone interested - I was able to get Techstream installed and connected to the truck. I performed a relearn for the fuel trim and will see if that takes care of the hesitates start.
    BTBAKER likes this.
  29. Feb 13, 2023 at 2:59 PM
    Alphagunner
    Alphagunner New Member
    Robert
    Oklahoma
    2018 4x4 crewmax. White
    Leather seats. 3/1 ready lift. 17in vision wheels wrapped in 285/75/17 Yokohama mt
    I am having this issue also
  30. Feb 13, 2023 at 3:02 PM
    AZBoatHauler
    So.Arizona
    FWIW, I never had a CEL come on but it did have P1604 code logged when I looked at the ECU in Techstream.
    BTBAKER likes this.
