Diode Dynamics SS3 Fogs way too high
Discussion in '2.5 Gen Tundras (2014-2021)' started by raketemensch, Feb 3, 2023.
  1. Feb 3, 2023 at 1:46 PM
    raketemensch
    raketemensch [OP] New Member
    NEVADA
    Hey all, I reached out to Diode Dynamics and they told me their fogs are only designed for stock ride height and to reach out to the forum for help.
    "Thanks for those photos! Because the truck is lifted this may be the culprit as these are designed and fabricated for an OEM ride height. You may be able to checkout some forums that can give ideas on workarounds however, there is not much on my end that I can recommend on a vehicle of that height."
    these bastards are pointed way too high. Anyone else experience this and have a fix? I have billies at 2-2.5" in front, billies in rear.
  2. Feb 3, 2023 at 2:04 PM
    @memario1214 have you ever heard of this? Are the brackets non-adjustable?
  3. Feb 3, 2023 at 2:05 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Welcome,
    Unfortunately there isn’t much room for adjustment. I have a one inch lift in the front of mine and I don’t blind anyone. Yours do look very high from your pictures.
    You may need grind or sand the inside of the plastic brackets (fog light housing) so you can point them down more and attach some zip ties (awesome trick I learned here!).
  4. Feb 3, 2023 at 2:39 PM
    raketemensch
    NEVADA
    Ok thanks, I have the zip ties in place but I'll pull them out and see if I can get more adjustment down. Just to clarify, you recommend sanding down the fog light bezel at the top from the inside?
  5. Feb 3, 2023 at 2:45 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Yes, please take this as an assumption based on what I observed with mine…
    Sanding the top and possibly side of the bezel where the top of the DD light extender (old school, school bus light cover looking thing) should allow it to be tilted further down. And the zip ties would obviously help it stay point downward.
  6. Feb 6, 2023 at 2:03 AM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    I'm on a 6 inch lift and these do point pretty high. There's some adjustment you can make to keep them lower. Avoid the urge to make the housings flush with the bezel. The larger the gap, the more you can angle the lights down.
    That said, I dont really get flashed by oncoming drivers. For the most part, the light is out of their eyes until they're within a few feet.
    I got everything where I wanted, then zip tied to keep them from bouncing.
  7. Feb 6, 2023 at 4:05 AM
    RocknRoll
    RocknRoll I’ll make you famous
    DFW, TX
    2019 MGM TRD Sport 4x4
    5” lift, 37” Toyo R/T’s 20” Fuel AMP steps, Ceramic 20% Tint
    this is solid advice. I had to keep a small gap between light and bezel before I tightened it all down and it helped drastically.
    HulkSmurf14 likes this.
  8. Feb 6, 2023 at 7:31 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Nah, they're adjustable.
    THIS is the way.
    If you loosen the side screws a bit you will notice that the light can be slid back and forth in a little channel in the bezel. Pull the light all the way back in the bezel, find your aiming point, and then push them as far forward as possible at which point you can cinch them down.
  9. Feb 6, 2023 at 2:14 PM
    raketemensch
    NEVADA
    Thanks for the input @memario1214
    My right side bezel is pretty loose so I'm going to order another and give this a shot
  10. Feb 6, 2023 at 9:17 PM
    Tundra2Yak
    2016 1794 4x4 CM
    Both my bezels were loose in the bumper cover. Zip ties are your friend here. Mine are tied down tight to the fog light brackets behind them. Zero play now in the bumper covers and no light bouncing when driving over rough roads.
  11. Feb 8, 2023 at 8:55 AM
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    +1 on this. installed SS3s last weekend. i used 3 zip ties for each fog ... significant difference in aim (lower) after sungging them up. forgot to take photos - sorry! this video shows the bottom zip tie location.
    raketemensch[OP] and bulldog93 like this.
