POWERSTEP WIRING FOR DRIVER FRONT
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2015CM, Jan 31, 2023.
  1. Jan 31, 2023 at 1:28 PM
    2015CM
    2015CM [OP] New Member
    Ken
    2015 CM Limited 4WD
    6" lift, 35x12.5x20 Powerstep XL Powered tailgate lock 12K winch inside Warn Bumper
    The instruction booklet is WRONG, at least on my 2015. The booklet says to connect the blue AMP trigger wire to the blue wire in pin #15 in the bottom white 20-pin connector. It actually needs to be connected to the grayish wire on the opposite side of the blue wire, 2nd wire from the top. Top wire is yellow, next one is it.
  2. Feb 1, 2023 at 5:34 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I had the same issue on my 2016, and I told them about it.
    Did you find the color wire for the rear drivers door and where ? I got frustrated and left it not connected..
