3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Jan 27, 2023 at 11:50 AM
    #2101
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    Don't encourage Skynet. lol
  2. Jan 27, 2023 at 5:12 PM
    #2102
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Anyone find an aftermarket kit to create a flat floor in the back seat?
    Piss poor design.
    Would like to figure this out before entertaining the idea of purchasing a new Tundra.
  3. Jan 28, 2023 at 8:42 AM
    #2103
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Overlandaddict makes a rear seat delete kit, but I haven’t seen a great aftermarket kit that leaves the seats in place. There’s a post somewhere in the forums about some DIY options.
    JJtruckon[QUOTED] likes this.
  4. Jan 28, 2023 at 1:05 PM
    #2104
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    After a year of running stock TRD OR wheels with Cooper LT275/65R20 tires, decided to go all out.
    First, coopers are awesome, not my first cooper set. However, these tires are heavy; significant hit on mpg, power and ride quality. For me, the latter two were major problems.
    I decided to go for larger tires, but lighter. Specially, went for Wrangler Territory 315/70R17, which are 9lbs lighter than coopers, wrapped around Methods (MR305 17x8.5 +25mm offset). Total wheel tire package is now about 18-20 lbs lighter per wheel, which is a lot.
    wow, ride quality is awesome now, will have to wait to give an opinion on power and mpg..
    In 2 months, my King suspension is coming, so front will get 1.2 inch lift.
    ps: truck has stock height and suspension. The rear axle has about 400lbs load, my old tires and wheels. Hence it does look relatively level.
    4F9E4DB3-CF59-452F-A839-AF6DDB405021.jpg BDF0203B-3CD9-473F-9E5B-4A5D677FC037.jpg 90EEE359-61F2-4A2B-B72F-9AE7BFC128A0.jpg 8414BF4B-ABE4-41C1-BD12-7E9B4D31EB1D.jpg
    Azrsx, ChiefG, Taikowaza and 7 others like this.
  5. Jan 30, 2023 at 9:39 AM
    #2105
    KroppDuster
    KroppDuster Out with the old and in with the...older?
    Here. There. Everywhere.
    Shawnee Hills Workshop makes one. They offer a kit for both the 60 & 40 sides for CMs and DCs.
    https://www.shawneehillsworkshop.com/
  6. Jan 30, 2023 at 1:22 PM
    #2106
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I’m excited for this one . Great price and super light . Quality feels amazing
    vegask, Soflo, Henry1jg and 2 others like this.
  7. Jan 30, 2023 at 3:22 PM
    #2107
    weign
    weign New Member
    Wayne
    22' TRD Sport
    1.75 Level 275/60-20 Tires Cap
    Rough Country 1.75 up front. I did the same with my 17 4Runner. gives it the right stance without going up too much.
  8. Feb 9, 2023 at 6:07 PM
    #2108
    Efreet6669
    Efreet6669 New Member
    '07 Limited Red Salsa Pearl,'23 TRD Pro Solar Octane
    S&B work with hybrid?
    iiawah808 likes this.
  9. Feb 11, 2023 at 6:56 PM
    #2109
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    Anyone able to point me to directions on installing the TRD running boards (PT767-34221) for the double cab? I see a lot of people say its super easy, just very particular in making sure I'm doing it correctly. Much appreciated!
  10. Feb 12, 2023 at 10:44 PM
    #2110
    Fooyotatundra
    Fooyotatundra New Member
    2022 sr5 trd 4x4
    Not really an accessory but finally got rid of the chrome surrounding using plastidip.
  11. Feb 13, 2023 at 12:24 AM
    #2111
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    Been awhile since I posted here:
    added the iKamper X-Cover 2.0 a couple weeks ago.
    Also the new EEF Qi charger has been working perfectly.
    cruiserhead, iiawah808 and bigjuice like this.
  12. Feb 13, 2023 at 3:36 PM
    #2112
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Finally got rid of the rear chrome bumper caps. Used vinyl, heat and some patience. It’s not a perfect color match but really really close. I’ll take better pictures when I wash it, which will also give a better comparison.
    I also added mats inside by Smartliner. They’re just like the big name folks just priced better. I’ve seen lots of people talking about WeatherTech, Husky and Rough Country. Check out Smart Liners.
  13. Feb 13, 2023 at 3:40 PM
    #2113
    KroppDuster
    Nice. I'm going to pull the bumper caps to cut & in-lay some flush mounts lights back there. I've been toying around with testing my vinyl skills on those caps. I kept thinking those pieces wouldn't be too bad to attempt a DIY wrap job since they're close to square and flat. lol. They seem like good pieces to practice on.
  14. Feb 13, 2023 at 3:47 PM
    #2114
    Rwaters
    Rwaters New Member
    That’s exactly what I want to do but I wanted to see how I’d do wrapping them. The edges and corners sucked and it took some time get shaped and stretched right without having fingers. My first attempt a year ago went horribly wrong but I did way better this time. I really like having less chrome! The Hogan mustache I’m on the fence of deleting. Only because it breaks up the big grille and I like the blue I have on the TRD and Tundra
  15. Feb 13, 2023 at 6:25 PM
    #2115
    Fxclm5
    Fxclm5 New Member
    that was my first ever wrap job, all sorts of angles, text inlay, air pocket openings
    it was not that hard at all, just time and patience, the bumper covers shud be a walk through the park - even if its your first job ever
    KroppDuster[QUOTED] and Rwaters like this.
  16. Feb 18, 2023 at 8:04 AM
    #2116
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Question regarding Retrax PRO MX - is there a way to upgrade to have the channels like the XR that support rack accessories? Or other aftermarket options/suggestions. With the box housing unit dropping into the bed and 5.5 bed really limits space in the bed. I did add the bed extender for weekend projects. But thinking summer travels may need more space.
  17. Feb 19, 2023 at 8:42 PM
    #2117
    Yota802
    Yota802 New Member
    I figured it out - on the Retrax sight I found they sell rail kits. Little expensive, just over $300.
    Now I need to find a rack. Looking for something slim - sleek, ideally telescoping or folding if there is such a thing. Planning for bikes and storage box for traveling.
    Any suggestions greatly appreciate.
  18. Feb 28, 2023 at 10:34 PM
    #2118
    SD.Tundra.858
    SD.Tundra.858 Family man...Toyota fan! Best spices in town!
    Travis
    San Diego, CA
    2023 Black Limited 4x4 w/ Platinum package
    I painted mine midnight black. Was pretty happy with it. I polished a bit more since this picture. Looks pretty good now. Was pretty easy too.
    ChiefG and Yota802 like this.
  19. Mar 1, 2023 at 11:00 AM
    #2119
    Efreet6669
  20. Mar 2, 2023 at 1:18 AM
    #2120
    Front_Range_Pro
    Vail, Colorado
    It literally is just 8 body bolts. Should take 30 minutes tops if you don’t have a power screwdriver.
    just eyeball the bolts based on the mounting locations when you hold the board up to body. These aren’t over-engineered BMWs or Audis here. Lol
    mlive[QUOTED] likes this.
  21. Mar 2, 2023 at 3:49 AM
    #2121
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    Thanks, I appreciate it!
  22. Mar 2, 2023 at 8:19 AM
    #2122
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I installed them by myself in a parking lot, in the rain, in under 10 minutes- super easy with a power drill
    mlive likes this.
  23. Mar 2, 2023 at 9:42 AM
    #2123
    Beams37
    Beams37 New Member
    The only thing i can find on their website is for the last gen Tundra.
  24. Mar 2, 2023 at 10:09 AM
    #2124
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    Any torque specs I should be aware of with them?
  25. Mar 2, 2023 at 11:00 AM
    #2125
    KClav
    KClav MGM Limited
    See attached for the installation guide.
    aogrady22 and mlive like this.
  26. Mar 4, 2023 at 9:07 PM
    #2126
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    Surely this also covers the 2022's, right?
  27. Mar 7, 2023 at 9:11 PM
    #2127
    chill_trd
    chill_trd New Member
    '22 TRD limited
    Nice , Sign me up for the Dual charger pre order when available.
  28. Mar 8, 2023 at 3:02 PM
    #2128
    MF140
    MF140 New Member
    2023 Tundra Platinum WCP Crewmax 4x4
    Ready to switch out the grille surround and front upper bumper cover. Now I just need the truck to get here already!
  29. Mar 8, 2023 at 3:09 PM
    #2129
    Front_Range_Pro
    Vail, Colorado
    Keep following our thread. We will post updates as they become available. But the EEF Universal Charger replacement for Qi-enabled trucks is already on sale and shipping along with the Charger with insert so people can retrofit a charger into their non-Qi-enabled trucks.
    THREAD: https://www.tundras.com/threads/qi-charger-solution-dual-charger-in-prototype-form.115096/
    As for an update on the dual charger, it just hit prototype form and is in testing phase now. :cool:
  30. Mar 8, 2023 at 3:30 PM
    #2130
    Tundra17944Ever
    Tundra17944Ever ‘16 Limited to ‘23 1794
    Tom
    GA
    2023 Tundra CrewMax 1794 TRD 4x4
    Fuel Rebel 6 Bronze 20x9 +20 Nitto Recon Grappler LT295/60R20 PRO fender flares color matched and wired Fox suspension from TRD Pro TRD Pro shift knob Grille surround color matched CBI Covert bumper with bull bar Rear bumper arms color matched BakFlip MX4 tonneau cover WeatherTech mats Gloss black window trim TT cat shield Black TRD grille Tufskinz tailgate letters Tufskinz TRD logo and stripes Tufskinz door sill protector Center console safe TWC 5” exhaust tip TWC slip-on exhaust TWC titanium valve stem caps Beat Sonic amp TRD air filters Diode Dynamics amber fog lights Color matched digital camo fog light bezel OEM Dashcam
    Been there.
