2022 with 8.5ft V-plow
Discussion in '3rd Gen Tundras (2022+)' started by porterbc, Jan 23, 2023.
  1. Jan 23, 2023 at 6:20 AM
    porterbc
    porterbc [OP] New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Well plow manufacturers have really dropped the ball lately on making sure that they have up to date mounting brackets and harnesses for new models. Pre Covid you could order the mount and harnesses for your truck before the new model was released.
    I searched and searched and rear hes out to all manufacturers asking for updates for the tundra.. nothing!
    “Western” was the plow I wanted because of its drive in mounting system is far superior to any other brand, and built by Douglas Dynamics which build fisher and snow-ex and prob couple others.
    So they don’t wanna build it for the customers, I had to build my own mounts and working on my harness for lighting.
  2. Jan 23, 2023 at 6:24 AM
    timsp8
    NY
    Looks nice. How much does it weigh? Any sag? I’ve been thinking about a plow but already have a new bumper and winch and think it’ll be too much weight. I’ve seen ads on tv for a 1/2 ton compatible fisher plow.
  3. Jan 23, 2023 at 6:38 AM
    porterbc
    Brandon
    I do have aftermarket springs with 35% increase payload over over stock from @GeneralSpring. Droop is about 3/4” for this plow and I believe it’s about 850lbs, which is about 150lbs heavier then my old 7.5’ fisher straight blade. But need 8’ or wider to clear your wheels when angled off, otherwise you are driving over your snow you just pushed over..
  4. Oct 11, 2023 at 1:05 PM
    TDNH
    TDNH New Member
    2022 Tundra
    Did you have issues with sensors? I
    Just put a boss plow on my truck. And everytime I go from a stop. Tells me an object detected and stops me right away.
  5. Oct 11, 2023 at 1:24 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Probably no mounts being made because Toyota does not recommend using a plow with the Gen 3. Not positive why, obviously it can be done.
  6. Oct 11, 2023 at 4:27 PM
    pwpblue
    pwpblue No loaner no owner F ford!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
  7. Oct 11, 2023 at 4:47 PM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    1. driveways.
    2. driveways/ parking lots. If you cut grass from June- October, you plow November-May.
    Highways-> state roads-> secondaries-> boonies in terms of plowing priority. You may need first responders before they can get to you. 20” of snow on the ground can be a problem.
    3. It is wide enough.
    4. plowing is a real m effer on your truck. ¾ ton is mandatory unless you just want to clear a common residential driveway and a couple of your neighbors/ family members. 1 tons are preferred. You’re slamming a lot of weight around. At least up here you are.
    Hecteasy and pwpblue like this.
  8. Oct 11, 2023 at 4:51 PM
    PermaFrostTRD
    Northern NY
    these aren’t uncommon.
    pwpblue likes this.
  9. Oct 11, 2023 at 4:55 PM
    Username checks out
  10. Oct 11, 2023 at 5:23 PM
    pwpblue
    Greensburg,PA
    @Eurodriver
  11. Oct 11, 2023 at 6:06 PM
    pwpblue
    Greensburg,PA
  12. Oct 11, 2023 at 6:07 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    So the snow can push the Ford around.
    TRDFerguson and PermaFrostTRD like this.
  13. Oct 11, 2023 at 6:23 PM
    PermaFrostTRD
    Northern NY
    God willing.
    Running a zero turn at 8-10mph when it’s 48°-58° with a beanie and winter gloves honks a high hard one.
    pwpblue likes this.
